Did the time slows on the outer space? - Computers & Internet
  • 89 Answers
No. Word "time" is relative
Posted on Dec 29, 2010
Why does it take my computer a long time to boot up, loading, and shutting down?
indicates that then hard drive is on the way out
first step is to save everything onto an external hard drive
then take it to a computer repair shop for an inspection
check how much space is on the hard drive because if you have a lot of junk on it , that slows down the start up and shut down p[rocesses
you can go to device manager and do a defrag of the hard drive to free up space
Aug 09, 2017 | Time Computers & Internet
Hasee laptop
your System may be slow due to following reason
- Too many programs running at startup or in the background
- Data Corruption, hard disk fragmentation
- Missing Windows updates or outdated drivers
- Not enough hard drive space, too many unused programs
- Left over programs, old cached and temporary files
So Follow these steps to fix computer freezes problem::
- Delete all the temp files
- Remove unused programs
- install latest drivers from the manufacturer site
- Install and run antispyware software
- Free up wasted space with Disk Cleanup tool
- Defragment your hard disk drive
If you are unable to perform above tasks then use a single utility tool like PC Fresher that will fix windows errors that cause of system slow
Sep 10, 2013 | Crock Pots & Slow Cookers
Why does my smartbook run slow
Hi Sharon,
Run a full scan of your smartbook with an updated antivirus.There could a viral attack on your machine making it drag.Also,the free space on your hard drive.Low disk space makes the machine to slow,delete old and unneccessary files from your machine to create as much space as possible.
Hope this helps.Thanks!
Dec 24, 2011 | Sylvania G-Netbook
I have 1981 yamaha maxim xj550. just replaced speedo cable for second time in 9 months. how do I know if speedo gear is bad or should I just replace it??
Probably its the bushing it the speedometer. Look where the cable spins in the speedometer...and where the cable sheath screws on.
You need to get some light grease sparingly into the space between the rotating head and the stationary part...I use white grease on my fingertip to push some in.. If the bushing is dry....it slows down the rotating head and the cable starts twisitng till it snaps. Normally a dry bushing starts making noise though.
When you say you replaced the cable....you meant the cable and the outer sheath correct....if the cable only was replaced there may be an issue in the sheath that is snagging the cable.
Apr 04, 2011 | 1981 Yamaha XJ 650
Computer is running slow, usage space is almost full
If by "usage space" you mean RAM, it is time to install more RAM, I'd recommend ~2-4GB RAM. If by usage space you mean the hard drive, clear a BUNCH of space. It will make Windows be able to use virtual memory, which will speed things up a hair.
Dec 19, 2010 | Acer Aspire 3680-2633 Notebook
Kenmore 253 9280413 freezer keeps running
The coils are embedded in the outer walls and will make the cabinet feel warm outside when the compressor is running. It needs about 4 inches of clear air space around all the outer case walls to properly get rid of its heat. If you have items stored too close to the outer walls they will act as insulation to keep heat from being dissipated. This can cause long run times.
A unit that has lost freon gas due to leakage, while unlikely, can also extend run times. Normal temperature should be about Zero when the dial is set to halfway.
Good Luck
Sep 15, 2009 | Freezers
Computer slowed down considerabily.
Check whether this is not a viral slow down. If not i suggest this
1. Give enough space to the hard drive.
2. Uninstall unused application for a long time and not needed anymore.
3. Install Ccleaner, this can clean your registry, cookies, and other junk files.
4. Defragment your drive. If you have enough space already.
May 03, 2009 | Computers & Internet
SET TIMING ON 2.4 TWIN CAM 1999 MALIBU
bring the piston no 1 on the top position check the cam shaft si moving freelyon the outer side of the shaft there are 2 gear with 14mm bolts and 1 extra whole, put a long bolt in the empty space and try to turnthe engine the bolt will go further in the space than the timming is set put the chain on that should do
Dec 08, 2008 | 1999 Chevrolet Malibu
Hard drive
When you say it's slow what I often found is that
1.not enough memory on your laptop
** so your CPU have to use your harddisk as memory,instead of working directly your CPU have another work to manage thus cos your system to slow down.
** you can check memory usage by right-click on your taskbar and click on Task Manager.Go up to Performance and check
Physical memory and see your available memory.
2.use more than one anti-virus program.Its just like before your work has been check by one program and now somebody is calling your same work to be recheck.Thus cos your system to become really slow.
3.Something is running all the time.A virus or something is running all the time.Shut it down by right-click on your taskbar and click on Task Manager.Go up to Performance and see CPU
usage that its 100%!!!! If so go up to process tab and right click
on the process you think is creating problem and End Process Tree.
3.The combination of not enough muemory and also not enough
harddrive space.When I say not enough harddriver I mean really low about 100-300 Megs.
so in your case not the problem with Harddrive..cos you have 1.5G
takecare.
Apr 27, 2008 | Computers & Internet
Slow spinning
time to replace your belts or something is stuck between the inner and outer tubs
Jan 11, 2008 | Washing Machines
Computers & Internet Logo
14 people viewed this question
David Payne
David Payne
