Question about RoadPro AIR SEAT BLOW GUN KIT
How do I connect air seat blow gun kit to semi front seat....thx and have a nice day
Air blow gun kit
You must tap into the existing air line that feeds your air ride seat There should be a brass fitting about the same size when you have On the air blower hose itself Take the videos and pictures underneath your seat so I can see what you looking at
Apr 28, 2013 | Tools & Hardware - Others
My airace framing air nail gun blows air when i try to shoot it
Look for an O ring kit,,many times the firing cap seal splits thus loss of air
Mar 30, 2013 | Air Tools & Compressors
Seat height is a little to high. How can I lower the bike a little or lower the seat height?
Hi Bighoot18, and the usual options are:
1. Thinner less paded seat.
2. Rear shock lowering kit.
3. Shorter shocks.
4. Shorter air shocks.
5. Front fork lowering kit.
6. Low profile tires.
Good luck and have nice day.
Feb 19, 2011 | 2005 Harley Davidson FLHTC - FLHTCI...
The seat height is to tall for me on my 2008 105 anniversary road king classic. What are my options?
Hi Evansryan30, and the usual options are:
3. Shorter shocks.
Feb 16, 2011 | 2008 Harley Davidson FLHRC 105th...
My Dewalt framing gun blows compressed air thru the nailer nose? Thx Kurt
Rebuild gun with gasket repair kit.
How it works: Compressed air enters through air hose and fills gun cylinder.
When trigger is pulled, air inside cylinder rushes out and pushes firing pin that shoots nail.
Inside the gun there are gaskets that seal the nose, the trigger and the cylinder head.
When any of those three gaskets fail, then air starts leaking.
Putting a few drops of nail gun oil into gun before connecting hose is supposed to protect gaskets.
But everything wears out, and sometimes folks use 3-in-1 oil instead of gun oil.
3-in-1 is detergent type oil and will cause gaskets to fail.
Another thing is guns that are not used frequently and gaskets get dry.
Putting in a few drops of oil and then immediately shooting gun will cause gasket to fail, because gaskets are still dry.
Best to put in plenty of gun oil, and let oil go down into gun for a few hours before connecting hose and shooting. Even so, nail guns are designed to be used every few days with continual oiling.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 31, 2011 | Tools & Hardware - Others
Blowing air through trigger area. Need rebuild kit? Longer version...started blowing air out of small hole in left side of casing. Leaked oil out of there as well but still worked fine. This has been...
If the trigger still works to fire the single shot, then the o-ring kit should be sufficient. If the trigger area continues to leak air, then the trigger should be replaced as well. Keep the gun well lubricated as well.
Dan
Oct 02, 2010 | Duo Fast Duofast Cn350 Cn350b Sh Nailer O...
My heatet is blowing semi-warm air. Could this be
Verify the the engine is running cold first with an infrared gun or a scanner. . A shop can do this for you in a couple minutes. Or if you have a temp gauge you should be able to tell by looking at it. Thermostats are easy to swap out.
Dec 25, 2009 | 2000 Chevrolet Blazer
99 4Runner heat blowing from console behind driver's seat
It sounds silly but there is a separate unit in your console that you can only turn off if you go in from back seats. You probably already did that, but if not try. You can not turn it off from any controls on front panel. If it doesn't work, I would think something is wrong with the switch. Open it up and look at wire connection from switch regulator. It also has a heat regulator on the console facing back seats? Mine does anyways.
Jan 17, 2009 | 1999 Toyota 4Runner
My nailer blows out air when I connect to the hose.
Skinney70
Have you been lubricating it regularly with nail gun oil. We use framing nailers every day at the commercial tree farm I work at and one of the operating instruction is to put 6 to 8 drops of oil in the air hose connection on the nailer before every use. I suspect the O ring on the piston is worn out/
Hope this helps Good luck Loringh PS Please leave a rating if appropriate Thks
Nov 15, 2008 | Tools & Hardware - Others
RoadPro AIR SEAT BLOW GUN KIT Logo
99 people viewed this question
Top RoadPro Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a RoadPro Tool and Hardware - Other Expert? Answer questions, earn points and help others
