Question about Refrigerators
NO AIR FLOW IN FRIDGE - Refrigerators
    Sergeant:
    Champion:
  • 250 Answers
Try defrosting the unit and then restarting . Sometimes there is ice build up(especially if the door was left open) in the path from freezer to fridge obstructing the airflow
Posted on Dec 29, 2010
Why is my fridge freezing?
You do not have proper air flow. Check inside if you are blocking the air vents. Another thing to do is vacuum the coils under the fridge or the rear (unplug the power). If the air does not flow freely or the coils are dirty, the fridge will freeze. An uncommon possibility is a low charge of refrigerant in the system. This would only happen if you have a refrigerant leak. Very unlikely, unless you damaged the coils under or behind the fridge.
Feb 29, 2016 | Refrigerators
Will a house fan running in front if fridge make it work harder or make fridge quit all together
That should be a help not a hinderance. The fridge tries to expel heat from the condenser, normally at the back, any additional air flow past the condenser must be helpful for getting rid of the heat. Any fan close to the fridge must be creating some sort of increased air flow.
Jul 02, 2015 | Refrigerators
Fridge to warm freezer build up of ice at bottom
fridge to warm? check thermistor, the cold control ( sometimes called defrost timer) and the air control assembly, check to see if air control is to far closed or opened? the inlet to the fridge from freezer. sometimes a bad defrost terminator will hinder the air flow and freeze up the fan from operating and freezer section thus no air flow to the fridge..
Mar 12, 2015 | Refrigerators
My ctf1826ar freezer works great but the fridge is not cooling. Nothing is frozen or blocked. When the freezer door is open there is cool air that comes our of the vents in the fridge but when it is...
the frig part not cooling though the freezer works is usually caused by bad air flow due to restriction somewhere. check ur vent settings and make sure not defective, the door rubber insulation may also be defective and not sealing properly after closing? and thus cool air escapes? but if ur feeling noticing air flow from the freezer but not in the fridge, the flow is obstructed, if the flow is off and on, do u notice the sound of the fan always running or does it go off and then on, it may be defective, the only time fan should go off is when in defrost mode?
Sep 27, 2014 | Refrigerators
Fridge ED22RQXXWOO freezer side working fridge side not cooling
Hi JB,
Is there frost in the freezer section at or around the bottom? If so a defrost problem might be the issue.
Here is a test for the air flow issue. At the air inlet of the fridge section, put your hand up there, is there air flow with the freezer door closed? With the freezer door open is the air flow better or increased?
If air flow is increased, chances are the you have an air flow restriction between both chambers and you will need to locate the obstruction.
So with this information this should lead you to a conclusion that is ice is on the evaporator you have a defrost issue, if you have no ice, than look for air flow issue.
Good Luck.
Oct 15, 2013 | Whirlpool Refrigerators
This is a Kitchenaid KSRS22FGBL00 - The freezer works good with a temp of -20c but the fridge side is not cold & has a temp of 8c. There is no frost build up anywhere. The air vents are not blocked. ...
Hello hlook,
I understand that you are having a problem with your side-by-side refrigerator. The Frezzer is staying closed and the fridge is not getting the air flow from the freezer in order to stay cold. The only possibility it can be is the fan. The fan may be turning but not at the rpms needed to move the air in to the fridge. As I have looked at the air flow chart for your fridge that is the only outcome I can come up with. CLICK HERE to view the air flow chart for your firdge.
With the cover off of the fan try and judge how much air is being moved by the fan. It should have pretty good air flow like the low setting on a box fan. You should be able to fell the air flow from two to three feet away.
Thank you for choosing FixYa.com
Justin
May 03, 2011 | Refrigerators
G'day - the 4 y/o rj422v fridge section has stopped working while the freezer is still very good. the rj422v unit has 2 thermostat switches, one for the fridge and one for the freezer section but I assume...
The problem could be caused from the main board not sending a signal to the damper, the damper could be stuck or broke or the thermistor may have failed.
Another possibility is if the return air is restricted. If this happens, the air flow will be very slow. A good way to determine if this is the problem is to feel the air flow coming out of the air diffuser and while checking it, open the freezer door or drawer. If the air flow increases with the freezer section open, the return air is restricted. If the air flow remains the same, the problem will be one of the above mentioned possibilities.
Mar 24, 2011 | Westinghouse Refrigerators
Fridge not cold - freezer fine
ice buildup will most likely block the air flow.
if so the air will not be able to enter fridge section. Check air vent in fridge side if you can hear the fan and get no air flow then its blocked - common defrost thermostat failure.
to temporarily clear the problem just use a hair dryer on the ice build up area
Aug 01, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Freezer working fine but fridge isn't
Either the damper that the air flows up through is closed or the return air flow vents are blocked with clear ice.
Do you feel the air come out all the way at the top of the duct assembly when the freezer door is opened (but it then stops when the door is closed)?
If so, then it sounds like your return air flow vents are clogged. These are located to the left and right of the duct assembly in the rear/bottom of the refrigerator section. Sometimes you may have to slowly pour hot water into these vents to get the clear ice to thaw. The water should go down into the freezer section behind the evaporator and then out the drain in the back.
If you do not get the air to flow out the top of the duct assembly then the damper is staying shut. This could be either a bad damper in the duct assembly or the main board my not be sending voltage to the damper. Hope this helps.
Dec 31, 2008 | LG LRFD22850ST French Door 22.4 Cu. Ft....
FRIDGE NOT VERY COLD - ABOUT 15 DEG C, FREEZER OK
relies on air flow between fridge and freezer but is regulated.
fault is probably ice build up on top of evaporator in freezer. remove back panel inside freezer and check. also check the air ducts are not iced up
Nov 19, 2008 | Bosch Refrigerators
Refrigerators Logo
29 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
