My Shure SM58 T2 radio mic (frequency; 173.800MHz) is picking up other radio mic users. There doesn't seem to be a frequency selector located on the reciever box so I am unable to rectify the problem. All I can see on the reciever box is a squelch control (what does this do?) Also on the mic itself there is a small gain adjustment screw inside the battery cover (what does this do?) Any help or advice would be appreciated. Thanks:) Pete.
SOURCE: SHURE VHF CORDLESS T3 Receiver and T2 Vocal Artist SM58 Mic
had a prob with my 58 cutting out re soldered the connections that connect the boards no cutouts
Posted on May 31, 2008
  • 6 Answers
SOURCE: i have a shure sm58 wireless microphone when i
Unfortunately the sm58 capsule is very hard to get apart without damaging the contact surface.
You would have to take the contact side apart 1rst
bend all the little tabs away which hold the brass plated disk in place
then its a matter of edging the disk out....CAREFULL any scratch is bad!
Once you have the disk out you will need a 1/4" socket to remove the shaft bolt,
unsolder the green and yellow wires taking note where they were soldered.
Then the element can be pulled out.
What to after that, I'll let that up to you.
Be wary, you will void warranty.
Posted on Jun 30, 2009
SOURCE: Shure T2 SM58 intermittent transmit
Two screws on the back of the battery casing, then prise out the battery tray (it's a detachable moulded tray in the mic body) using a small screwdriver in the slot near the power button. Under the threads of the battery cover is screw which holds in the PCB, unscrew this. Take the full mic head off (not just the ball, but an inch further down with the capsule in it), and remove the circlip inside. The PCB then slides out towards the head end of the mic.
Posted on Mar 30, 2010
  • 417 Answers
SOURCE: shure sm58 mic stopped working ...
Check the wire connections where the xlr cable connects.
Posted on Apr 15, 2010
  • 611 Answers
SOURCE: I have a Shure SM58
Unfortunately, there is not much that can be done. It would take a highly technical service center with about $100,000 worth of test gear to retune it after the circuit board was swapped out.
Also, these frequencies are now illegal to use in the U.S.
Posted on Dec 26, 2010
How can I sync a Shure T2 mic to a LX4 receiver
There is no sync. They simply need to have the same frequency listed on their sitickers.
May 13, 2014 | Shure SM58 Professional Microphone
T2i have a shure SM 58 wireless mic and nack in placeeed to know where wires are on the mic section so as to solder b
The wiring diagram can be found in the User Guide for the SM58. It can be downloaded on Shure's website.
Dec 01, 2013 | Shure SM58 Professional Microphone
I have 2 sm58 radio mics these are very old when i switch off the mic handset it gives an ear spiltting spiltting sound like consant interference can any one help
Sounds like your wireless transmitters (mic) and receivers have drifted from their original factory set frequency. Also, older units may fall into the "illegal " 700Mhz frequency band and should not be used...
Feb 17, 2013 | Shure SM58 Professional Microphone
Have Shure T2 Wireless transmitter - no audio - can fix?
There is a company in Chicago that can still repair old Shure wireless. Delta Audio 877-764-3634.
Oct 19, 2011 | Shure SM58 Professional Microphone
Can anyone please tell me how to use a shure sm58 radio antenna wireless microphone or manual as ive just purchased this of ebay and no instructions came with it so a little lost as no sound coming from...
Shure SM58 is not a wireless microphone, so clarify me the exact model for your wireless device in order to help you.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
direct FixYa link:
Sep 06, 2011 | Shure SM58 Professional Microphone
I bought a new T2 SM 58 Shure Microphone with freq. 171.845 Need a receiver. Don't know where to go.
Unfortunately, there are no new receivers available that can be used. You'll have to try to find a used Shure receiver on that exact frequency.
Dec 21, 2010 | Shure T2/58-CL SM58 & Wireless Transmitter...
I need a Shure T2/58 transmitter
These were discontinued several years ago. You'll have to watch eBay or Craigslist. If you find a used one, it will need to be on the same exact frequency as your receiver in order to work. It won't be easy to find one on the same exact frequency, so good luck with your quest.
Oct 26, 2010 | Shure T2/58-CL SM58 & Wireless Transmitter...
Lost user guide sm58 wireless mic
The User Guide can be found on the Shure website.
Dec 19, 2008 | Shure ULX Standard Series Wireless...
116 people viewed this question
