Question about Sony DW-Q28A (DW28Q) DVD±RW Dual Layer Burner
Lb@aol.comsony dw-q28a will not play getting a code 41. do i need just a up dated driver or a new dvd/cd? thanks any help appreciated. lisa
    Sergeant:
  • 320 Answers
Hi Liglb,
    • Download and install CCleaner (free) from Piriform
    • Run the cleaner to remove old un-needed temp files
    • Select the StartUp tab and look for any programs that you know you installed but no longer use or need, and disable them. Caution, do not disable any system files unless you absolutely know what they do and that you do not need them.
    • Run the Registry cleaner, when asked if you want to backup the registry, select YES, and save to a file you will remember just in case. I have used this program hundreds of time on many different system and it has never caused a problem, but you want to be safe, backup the Registry.
    • If asked about a particular file that it wants to clean, select "yes to all"
    • Reboot
Windows should reinstall the drive when the computer boots back up.
If this does not resolve your problem, try the following.
If you take all these step and you still can not play a CD/DVD, chances are your CD/DVD componet needs to be replaced. Good Luck,
    • If this helps resolve your issue, would you please rate the solution.
Posted on Dec 30, 2010
Hi, I have SONY DVD/CD rewritable drive unit, Model No. DW-Q28A. CD or VCD working but DVD not able to work .
The drive is compatible with the following DVD Disc:
WRITE SpeedDVD+R DVD+RW DVD-R DVD-RWDVD+R DL
DVD-R DL
If you are unable to burn using those disc then the burner is defective.
If you want to watch a dvd then you would need to purchase or download a program to watch the DVD movies.
Feb 28, 2011 | Sony Computers & Internet
August 2005, I purchased this powermac g5. There has been a steady deterioration in the DVD player. Presently, no rented DVDs play. SONY DVD RW DW-Q28A: Firmware Revision: KAS7 Interconnect: ATAPI Burn...
OK. The movie industry strikes again! Your RENTED DVDs are the key.Hollywood made some adjustments to prevent the copying of the movies. So they put software to detect the kind of drives in which the movies are inserted. DVD/RW are capable of copying a movie, so they are disqualified as playing devices. Have it be a normal DVD player you won't be facing any troubles.
Apr 20, 2009 | Apple Power Mac G5 Desktop
Code 41
This error occurs when Windows does not detect a non-Plug and Play device.If the device was removed, uninstall the driver, install the device, and then click Scan for hardware changes to reinstall the driver. If the hardware was not removed, obtain a new or updated driver for the device. Hope this helps
Feb 16, 2008 | LG GSA 4163B DVD±RW Dual Layer Burner
My DVD drive reads only Dvd's but doesnot read and CD's?
Two lasers - one for CD one for DVD CD one possibly dirty - so get and run a lazer cleaning disc set and run it or laser burnout -new drive
Jul 04, 2007 | Sony DW-Q28A (DW28Q) DVD±RW Dual...
Sony DW-Q30A Problem
the dvd writer needs to be replaced,the laser is faulty or miisaligned, the cost of a repair is no longer viable because a new one would cost about $60 (£32.00)
May 30, 2007 | Sony (DWQ30AB2) DVD RW Dual Layer Burner
Sony dvd drive installation
What software and procedure are you using to burn the DVD?
Mar 04, 2007 | Sony DW-Q28A (DW28Q) DVD±RW Dual...
Numerous errors when attempting to burn dvd's
1. go to device manager / right click on cd drive / uninstall driver / reboot and windows will reinstall driver 2. go to My computer right click on cd drive properties - check digital cd playback recording - check enable cd recording on this drive driver - update or uninstall reboot your computer
Nov 11, 2006 | Sony DVD+/-RW |DW-Q30A BG w/o SW %...
Blank disc not recognized
Sorry no solution, but why burn with mediaplayer/realplayer? you get better results with nero, or other burn dedicated software. Hope you work it out
May 18, 2006 | Sony DW-Q28A (DW28Q) DVD±RW Dual...
Sony DW-Q28A (DW28Q) DVD±RW Dual Layer Burner Logo
110 people viewed this question
Top Sony Computers & Internet Experts
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
