Question about Keurig Platinum B70 Coffee Maker
HOW TO DISABLE AUTO ON/OFF FEATURE ON KEURIG B70
  • 1,772 Answers
Sorry to read about your problem, I hope this helps you out.
when you goto your menu, you will see auto off/time use the hour button, then select off
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
Posted on Dec 29, 2010
  • 2 more comments
  • ls1cowboyz Mar 15, 2011
    That is to disable the auto off setting (after a certain number of hours)... I think the OP was talking about the auto on feature that wakes the machine up, an then the one that puts it to sleep at a certain time. To disable that set both of the timers to 12:00AM Once you get there it will display as off, and remove the text on the LCD.
  • David Monroe
    David Monroe Jan 22, 2014
    @ls1cowboyz... thank you so much, it's been driving me nuts how it keeps turning on
  • Liz Carreiro-Onuwa
    Liz Carreiro-Onuwa Mar 25, 2014
    Ditto! Thanks so much! The instructions in the manual are useless
  • NOLA GALLAGHER
    NOLA GALLAGHER Jan 16, 2015
    four thumbs up thanks for the help
What is the auto off button on the keurig coffee maker
It enables you to shut the machine at a predetermined time without your presence. You can also select it on "OFF" to disable the feature.
Feb 25, 2017 | Keurig Coffee Makers & Espresso Machines
Every morning my Keurig is turned off
The Keurig B70 has an auto off feature that needs to be programmed. You can find the instructions here:
http://www.ehow.com/how_7389997_reset-keurig.html
Oct 17, 2014 | Keurig Platinum B70 Coffee Maker
I cant change the Auto Off feature
You should be able to press the Auto Off button and it cancels the automatic option. Hold it down and while keeping pressure on the button, pull the power cord from the Wall. keep holding the button and reinsert the Power Cord once again. Lift up and see if it did a Reset.
Jan 24, 2014 | Keurig Platinum B70 Coffee Maker
The temp set is at 0 so the water is not getting hot
Have you gone into the menu and changed the temperature setting? You can also change the auto off feature in the menu that is probably causing it to turn off.
Jan 16, 2014 | Keurig Platinum B70 Coffee Maker
How do I reprogram my platinum Keurig so it does not shut off
With unit powered on, Select Menu button, scroll down, and turn "auto off" to off selection. Cup size is selected after you put K Cup in. The display should flash on a default (1 of 5) cup sizes. You can manually change to the size you want. Alternatively, you can select the Menu button and change the default cup size (same process as stated above).
Nov 25, 2013 | Keurig Platinum B70 Coffee Maker
Keurig B70 coffee maker Not Ready and auto off set
Needs priming. See instrauctions for new unit setup.
Sep 29, 2012 | Keurig Platinum B70 Coffee Maker
How do we stop the auto time ON/OFF feature and have the B70 on all the time?
Go to the "On/Off Time", set the minutes to 00, then start pressing the hour button. An "Off" will be an option available after you get past 12:00.
Aug 29, 2010 | Keurig B50 Coffee Maker
I have the Keurig Platinum B70 brewing system. It worked fine the first few days and now it won't stay on....it shuts off automatically. I have made sure the auto off feature is in the 'off' position.
This also happened to me. Keurig sent me a replacement and it happened again. I called them this weekend and they said all platinum brewers sold around Christmas and all replacements had a faulty sensor. If you call them they will replace it free with a brewer that doesn't have this problem.
Jan 01, 2010 | Keurig Single Serve Ultra Brewer
It is a model #B70 and says NOT READY no matter what I do. I have changed the clock, set the auto on/off (which I would like to disable permanently) and I can't get it to brew!
Clean out the upper needle. It may have become clogged w/coffee grounds. Do you use tap water? If so, limescale may have prematurely ended the life of the machine. The air pump may be out of the unit as well. You can call Keurig and they will make you an offer to purchase another unit. Sell it for scrap on ebay or Crystal Pure. If you want to disable the auto on/off feature that is easy. Menu: time clock scroll to "Off" click and see if that doesn't help to "jump start" your B70! Best wishes, Melba
Nov 09, 2009 | Coffee Makers & Espresso Machines
Keurig Platinum B70 Coffee Maker Logo
21,600 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
