Question about Dishwashers
The middle arm on my Evolution dishwasher isn't spinning - the top and bottom one seem fine. Glasses especially on top shelf aren't getting clean at all (obviously!). Any suggestions?
    Sergeant:
    Champion:
  • 250 Answers
Check if the holes are blocke dwith dirt the arms spin by newtons law that every action has a reaction (like a rocket) if the holes are blocked it wont spin as there is no force.
Posted on Dec 29, 2010
Dishes on top shelf not getting clean
Check your upper wash arm.... check the holes, especially the ones at the end of the arm. Are they possibly clogged with debris or hard water? This is the usual cause of dishes on the top rack not getting clean. The holes at the end of the wash arm are angled to eject the water at an angle to use the reaction to push the wash arm around. If those holes are clogged, then the arm won't rotate, and only those few dishes or glasses right under the arm will get clean, and the remaining 80% of the dishes on the upper rack won't get clean!
Sep 13, 2014 | GE Dishwashers
My Whirlpool Quiet Partner II does not clean the upper rack of dishes properly. They are greasy. I have checked the top spray arm for blockages. There were none. I am fairly certain that water is
Make sure the center loading is not obstructing the water jet to the top shelf. Top shelf is only for glasses and saucers , use Jet-Dry .Pre rinse and clean bottom pan strainer from dirt debris.
May 14, 2012 | Whirlpool GU2400XTP Built-in Dishwasher
Tablet keeps coming out of the dispenser on my hotpoint fdl 570 dishwasher on all cycles and falls on to the floor, result is that the crockery isn't always clean on the top tray. Machine is still...
Hi Jeanette,
Maybe I misunderstood your question, but the tablet is supposed to come out of the dispenser and fall into the bottom of the dishwasher. It needs to fall into the hot water in the bottom of the washer to dissolve. The dispenser releases the tablet at different points in the cycle depending on which wash cycle is selected. On a shorter cycle it will be released soon after starting. On longer cycles, there is usually a rinse first, so the tablet will be released a little later. There would only be a problem if the tablet wasn't being released, or wasn't dissolving completely.
There are a number of reasons for poor cleaning on the top rack. The most common are the upper spray-arm not spinning, incorrect stacking or overloading. If the upper spray-arm isn't spinning, there may be caused by a blockage in the spray-arm or the water delivery system, but, as the dishwasher is new and it's not happening every time, it's possible that the dishwasher isn't levelled correctly. The spray-arms aren't motorised, they use water pressure to spin, but they wont spin if they aren't balanced, i.e. the dishwasher isn't level.
You can check whether the spray arm/s are spinning by pointing them front-to-back, or left-to-right (so you can remember the position) and allow the dishwasher to run for a few minutes. Then open the door and check the position of the spray arms. They should continue to rotate slowly for a short while after opening the door, but if they're in the same place and static, they're not spinning. I'd suggest repeating this a couple of times to eliminate the possibility of them having stopped in the exact same place you left them.
If the spray arms are spinning, test the dishwasher with only a small load in the top rack. If the top rack comes out clean with a small load, you may be overloading it or stacking it incorrectly some of the time. There should be a correct stacking guide in your user manual.
Hope this helps. If you need further assistance, check whether the arms are spinning then post back.
Regards,
BElectric
Jul 03, 2011 | Dishwashers
Top rack - glasses etc... not getting clean - bottom rack and utensils seem fine?
There is a pipe/tube that runs up the back of the inside of your dishwasher. This provides water for the top spray arm. The spray arm has a feeder tube that covers the pipe in the back. If for some reason the feeder tube has come dislodged, the water just drips back down into the dishwasher, never touching your upper shelf. My kids used to jam cutting boards and other large items into the lower shelf and in so doing, would dislodge the upper spray arm feeder tube. Just pull out the upper shelf and check to see that the tube is in the correct position. This should solve the problem.
If not, then the spray arm may have debris in it that keeps the water from being forced through the jets. You'll need to flush the arm with the spray attachment on your kitchen sink. I sometimes use tweezers or a toothpick to dislodge bits of peelings, paper, or bone that manage to get into the sprayer arm.
I hope one of these tips helps. If it does,please come back to fixya and rate my answer.
Jul 02, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
I have a KitchenAid Dishwasher Model KUDT03FTSS0. I am having a problem with the glasses on the top rack not being fully cleaned. There seems to be an amount of residue left on the glasses. I have...
Check that the arms spin freely when spun by hand, then check the outlet jets at the trailing end of the arms are not blocked with food particles and other solid matter. This often happens and the arm is unable to turn because the water jet that is supposed to drive the arm does not have the force to rotate it with the result is that the upper dishes do not get enough water and chemicals. It may also cause water to continue dripping onto dried dishes after the the drying cycle has stopped.
Jun 25, 2011 | KitchenAid Dishwashers
Hello, Im trying to diagnose poor cleaning of glasses in the top rack of my Fridigaire FDB751SCB0. everything seems to work fine but while testing I noticed the upper arm isn't spinning. the lower arm...
Hello; first thing to check, which you don't mention, is which side of the glasses aren't coming clean; the outside, which would be caused by the TOP spray not working properly, or the INSIDE, which would be caused by the spray BELOW the top rack not working. The most common problem causing a spray arm not to turn, and/or poor cleaning, is debris blocking some or all of the spray holes in the arm. Best and easiest way to check them is to remove them; they usually are easily removed with a large wing nut or screw in the center. (Don't drop the screw, if you do it will ALWAYS find it's way to the hardest spot to retrieve it from in the whole dishwasher!)
Once you have the spray arm(s) out (this might be a good time to clean them all) you may notice pieces of debris partially protruding from the spray holes. DON'T pull them out; use something to push them back inside the spray arm. Pulling them out can enlarge and mis-shape the spray holes.
Dislodge any pieces inside the arm by firmly rapping it against a firm but padded object, and shake the debris out over the sink, catching it in a paper towel so it won't go down the drain. Be careful, as broken glass is often inside the spray arms, picked off the bottom of the tub and fed through the pump to the sprays.
Once you don't get any rattling inside after several "raps" on the padded object, the arm should be clean.
Cleaning these spray arms periodically is a good idea even before you have trouble.
Hope this helps, and good luck!
Alec
Jun 04, 2011 | Dishwashers
My Professional series dishwasher does not work properly. It is only 1.5 years old and glasses on top rack get sprayed with fine layer of particles every time I use it. Other items, top and bottom, are...
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
jgkljhk;
Mar 13, 2010 | Frigidaire PLD4375RFC Dishwasher
Dishes on top shelf not cleaning
heatman101
4w56er
Mar 02, 2010 | KitchenAid 24 in. KUDP01DL Built-in...
GE dishwasher Quiet Pro 3 middle washing arm
Try unscrewing it from the bottom, remove it and give it a clean. If it is full of food it will not turn.
Check the funnel on top of the basket is free of food too.
Jun 10, 2008 | Dishwashers
I have the same problem with dirty dishes on the top shelf and the utensil baskets
Dump the Kenmore on the seller's doorstep - when the place is full of customers!!
Dec 27, 2007 | Kenmore 24 in. 16264 Built-in Dishwasher
Dishwashers Logo
104 people viewed this question
Top Dishwashers Experts
