Question about Dell 5110cn Laser Printer
Black is printing very faint. tried changing the transfer roller and the cartridge, no help.
  • 147 Answers
Make sure paper type settings are correct and the meda you are using is selected in the driver.
Will it print a demo page properly and a document lite?, or is everything lite?
This is a Lexmark printer with dell covers, The drop down PCR Rollers are also a cause of lite print. These can be removed and washed with a clean damp cloth and water.
Posted on Dec 29, 2010
Faint line when printing a letter
hi this may be the toner roller or supply drum for the toner cartridge . if it scratched or worn it leaves marks on the drum or the roller, which in turn fills with toner and leaves an imprint on the page, you can check these , just remove the toner cartridge and look at the green roller and also look at the black roller, it might be a simple case of changing it or cleaning it....hope this helps
Feb 25, 2010 | OKI C5250n Printer
DELL 5110CN PRINTS PRINTS LIGHT GRAY NOT BLACK!
try to print test page and determinate which or colour is fainting. if it is one colour then you need to replace this colour image drum. If all of colors is fainting then its transfer roller.
Dec 29, 2009 | Dell 5110cn Laser Printer
How to print black and white only on Konica-Minolta 2400W
Are using OEM cartridges? What about the transfer belt and transfer roller have they been replaced>
Dec 26, 2009 | Konica Color Stationary Workgroup Laser...
I have a HP laserjet 4P. The print was coming out
You need to replace your transfer roller. Might as well do a complete maintenance kit.(Rollers, Fuser and Transfer Roller)
Nov 08, 2009 | HP LaserJet 4p Printer
Epson aculaser c900
When printing, as thepaper is being transported up the printer, try pressing the right door panel of the printer firmly with your hand. If the colours are much improved then the printer requires a new Transfer roller.
1. Open the Right Door.
2. Remove the Transfer Roller while opening the shaft holder (white color) levers found at the left and right shaft ends of the Transfer Roller to unlock it. Lift out the roller.
Jan 21, 2009 | Epson Aculaser C1100 Printer
Lex 5150 - not printing black well
what you may have to do is clean the rollers, good place to clean is where you insert the cartridges, open the lid so the machine thinks your going to repalce the ink, cut the power from the mains, now you can proceed to to clean the inside, remove both in cartradges and clean where they instert, toilet roll or kitchen roll will do because they soak up the ink, then, and be very gentle, slide the mechanism to the left hand side so you can clean underneath, after cleaning power the printer up so that it still thinks you are changing the ink, the cartridge housing should be where you can access them so you can the put the ink back in, then you need to use the the lexmark software to re-align the cartridges and also print a test page, keep on doing this until the inkjets are performing properly
Nov 16, 2008 | Lexmark X5150 All-In-One InkJet Printer
Fuser
The fusing unit uses heat and pressure to bond the toner to the paper. Normally poor fusing is evidenced by repeating images or by the print smearing when you rub your fingers across the paper. One fuser roller (the heat roller) is probably aluminum with a teflon coating and the other one (the presure roller) is a type of rubbery material and is often orange.
By your description you mentioned cartridges and that the printer is a full color printer. Is this a laser printer having toner cartridges and imaging units? I just want to make sure you do not have an inkjet printer as they do not use fusers.
The washed out prints you speak of sounds more like a transfer issue such as the transfer belt, transfer charge roller, etc...
Please tell me the brand and model of your printer and I will be more specific.
Nov 11, 2008 | Office Equipment & Supplies
Ricoh Aficio cl2000
Most of the time when I find this happening on a printer, not just Ricoh's it turns out to be the PCU (photo conductor unit). The color PCU is one unit and the black is a seperate unit. Hope this helps.
Dec 17, 2007 | Ricoh Aficio CL2000 Laser Printer
Faint mirror image when printing
It's most likely one of 2 problems...the toner cartridge or the fuser. The toner cartridge transfer roller may still be charged and keeping a little bit of the previous page's information on it, to be transferred on the next sheet. I would try a different toner cartridge first to see if that solves it.
Jun 18, 2007 | Tally T8006 Laser Printer
Dell 5110cn Laser Printer Logo
149 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
