Question about Williams 3003622 Ceramic Wall Mounted Panel Heater
My wiiliams heater will run for a while sometimes most of the day then just shuts down pilot goes out also.
  • 1,772 Answers
Sorry to read about your problem, I hope this helps you out.
Sounds like you have a defective thermocouple. since this Gas product, I suggest you contact a service company, I dont think you have the proper tools, to check for gas pressure's and leaks
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
Posted on Dec 29, 2010
Any idea why my Atwood water heater will shut the main burner and the pilot light off at the same time? Sometimes runs for 20 minutes, sometimes 2. I hear a clicking sound, then they both shut off.
The thermostat shuts off the main burner.The pilot light gas is controlled by the thermocouple which the side of the pilot flame has to envelop. If the flame is too small or too far away from the flame, it shuts the gas off to the pilot. The thermocouple generates a small voltage which keeps the pilot gas open. It can over time fail itself, so look at replacing it. The thermostat sounds like it's failing too.
Apr 27, 2016 | Water Water Heaters
Mod232le ssfbd32r
You need to clean out the pilot fixture or replace it.
Jan 27, 2014 | Heating & Cooling
Pilot gos out when burner shuts down wall furnice
Usually thats a sighn of a bad thermocouple,thats the copper tube that goes from the gas valve to the actual pilot assembly it senses that the pilot is burning and allows the main burner to light. If there is no pilot lit the bur will not light. Its there to keep you home from exploding from a release of gas with no pilot. The good thing is that most ofthem are universal and most water heaters use the same one. And you can buy one for a water heater at lowes or home depot for about ten bucks. If you get one thats longer than the origional thats ok because you can just coil it in a circle just be carefull and dont kink the tube,if you do kink it you must get another one. even if you straighten it.
It wont work. Hope that gets you going and warm.
Jan 12, 2013 | Vanguard International Blue Flame - Medium...
Pilot light keeps going out
pilot light keeps going out! more then likely its the thermal coupling doing this. if bad it shut all gas to heater for a safety measure. just shut power off, then turn gas off and replace it. then you should be ready to go. to relight heater hold down on gas vavle knob in the pilot position, hold down and light it at the coupling where gas comes out. when it is lit, continue to hold down for 60 seconds. release knob very slow. then if its lit, turn to the run position. if flme goes out, wait at least 5 minutes to expel the gas fumes and turn to pilot and try again. good-day !
Mar 31, 2012 | Water Heaters
WATER HEATER GOES OUT OVER NIGHT
you either have a back draft blowing out the pilot light, or a bad thermal coupling. if coupling is bad it will shut down the gas flow therefore shutting off pilot light. its a safety measure to stop the gas flow if pilot goes out. replace thermal coupling, that may do it. good-day ! but shut off gas first !
Mar 21, 2012 | Water Heaters
Dyna-glo parts
thermocouples you can buy from any heating spares oulet or national energy a hone well is most common for useing as a replacement
Feb 03, 2009 | Dyna-Glo D-E36 Infra-Red Wall Mounted...
Heater runs for appox 2-4 minutes and then shuts down..
what kind of furnace do you have? Is it electronic or standing pilot? If you have electronic then it could be flame sensor if you have standing pilot and the pilot goes out and you have to relight then it is probably the thermocouple what is going through an 1/2 flex pipe explain this a little more. Have you checked filter.
Jan 21, 2009 | Procom ML300EBC Heater
Bosch gwh-425ef nat gas on demand heater
sound like pcb board is failing - control board
Nov 09, 2008 | Bosch & Power Vent Water Heater
Pilot lights fine, furnace fires up, when it turns off the pilot goes out
need to have at least 3 feet of vent out of the roof, if it is to low the coll air will cold soak down to the pilot and shut it down.
Nov 08, 2008 | Cozy (W352E) Heater
Williams 3003622 Ceramic Wall Mounted Panel Heater Logo
241 people viewed this question
Top Williams Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Mack Baxter
Are you a Williams Heating and Cooling Expert? Answer questions, earn points and help others
