Question about Maytag Ensignia 3.3 cu. ft. Top Load Washer
Maytag Ensignia Oversize Cap Plus Washer stopped working in mid cycle
Hello... I have a Maytag Ensignia Oversize Capacity Plus top loading washer. The unit is approx 3 yrs old. It appears to have stopped in mid cycle. I have noticed the auto temperature control light is not lit. I do and have always have the auto temperature control on. I checked power to the unit and it is on. I have checked the water source and it also is on. The unit stopped when it refilled for the first rinse cycle on the whites setting. I changed different setting, such as going back to the end of the wash cycle or trying different setting on the colors setting, with no avail. The unit appears to not have power to engage the timer dial. Please advise any suggestions... Thanks Bob
  • salonje Dec 03, 2008
    My washer has the same problem. It is full of water in the basket and when I turn on the timer thingee it makes a loud noise like it wants to spin but then then noise ends after 3 seconds. Should I just replace this washer? I have been trying to research the problem and it seems there is more than one problem with it. Timer may be old, drive buster, etc.
  • reginapier Dec 15, 2008
    My Maytag oversize capacity plus will not do anything: won't fill, makes no noise at all like it died. Do I need a new timer knob?
    Problem Solver:
  • 10 Answers
Check the water level control, it could be stuck or faulty.
Posted on Jul 07, 2008
Maytag legacy series washer
The drive motor which spins the drum is connected to the drum by a rubber belt. Sounds like the belt is burned through. Make sure you can spin the inside tub by hand to verify that the tub can turn freely before you replace the belt. The hum is from the drive motor just spinning freely.
Sep 02, 2016 | Maytag Legacy Series Top Load Washer
Where is the model number on maytag quiet plus ii washer
Posted on November 16, 2012 M/F FREE VIDEOS, RESOURCES & RECOMMENDATIONS *NEW* Search Parts For Your Maytag Washer On RepairClinic Every Maytag appliance, including Oversize Capacity Plus and Quiet Plus appliances such as washers and dryers, is manufactured with a product label that displays details about the appliance such as its model and serial numbers. The model number is typically located on the top left corner of the label. Although the location of the product labels varies by appliance type and model, finding the model number for your Oversize Capacity Plus and Quiet Plus appliance shouldn't take long. Maytag only attaches the product label to certain areas of an appliance. *Open the lid on your Oversize Capacity Plus or Quiet Plus washer and look for the product label on the inside bottom right corner of the lid. *Check for the label behind the control panel on the top back of your washer. *Look on the back main portion of your washer, also known as the base frame, on the left.
Jun 13, 2013 | Washing Machines
Maytag oversize capacity washer just finished filling up the tub with water. Then it had a burning rubber smell. I shut it off and on a bunch of times and there isn't even any sound. (like the mot
You need to observe and check after disconnecting the power , touch the motor, the element area or the control panel or the valves/pump.
If you notice any heat on these , it can be the culprit.
You can proceed to remove the suspected part to discover what was the reason for the burning rubber smell.
Click this link: Element
Jan 25, 2013 | Maytag 3.3 cu. ft. Oversize Capacity Plus...
Maytag ensignia top load washer will not fill with water at start of the cycle?
The drain hose has to be at least 30 inches above the floor or gravity will drain the machine. Also: If the water hose is jammed into the drain a siphoning affect will occur in some instances.
Aug 04, 2012 | Maytag Ensignia MAV2757AWW Top Load Washer
Clothes Washer stopped running. I have a Maytag PAV2300AWW clothes washer that was mistaken ran with a full load on the small load setting and stopped working mid cycle. Any help with the cause and
first check the house breaker and make sure you still have power. If it does then I would unplug the machine and lean it back against the wall to look at the motor wiring harness underneath to see if it came loose or is wet.
Mar 31, 2012 | Maytag PAV2300 Top Load Washer
Maytag washer very loud on spin cycle
I know the exact sound you are hearing, I had the same thing several yrs ago on my old Whirlpool. I think it was something with the transmission, but what I needed was no longer available. I found a lot of info by entering the make/model nr in search box at You could also look atR44U61
May 02, 2017 | Maytag Washing Machines
How many kilogramos is the capacity of the mytag ensignia
Welcome to fixya
I have a solution for this
Press Ok, Accept or replay so we may get started
Your pre-solution is coming up shortly
My name is Bruce
Jan 16, 2011 | Maytag Ensignia 3.3 cu. ft. Top Load...
Maytag Ensignia 3.3 cu. ft. Top Load Washer Logo
982 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
