Question about HP LaserJet 1020 Printer
NEED TOTAL COUNT OF PRINT OUT . PLEASE DO THE NEEDFUL
  • 77 Answers
Press and hold the go button until the green ready light begins to flash. The configuration page will be printed.
Posted on Dec 29, 2010
Copy count infoprint counter
Press "System Settings" then "Total Count" then "Job Count" and then "Print"
Good Luck
Follow me on Twitter @CDOS_Service
Jan 16, 2014 | Sharp MX-2300N Color Copier
Hopw to get meter count
Total prints B/w with FAX and total b/w copies equals total B/w color is prints and copies color scans? utility/counter button and do you want a print out?
Feb 21, 2013 | Konica Minolta Drum Cartridge for Bizhub...
The ribbon will only print red ink
While in the D position or PD position, N Count
is OFF. In the N Count N position every
Plus, Minus, Equals Plus, Equals Minus,
Memory Plus or Memory Minus key depression
is counted. The Accumulator and its N Count
or the GT N Count can be printed by
depression of the Subtotal or Total key. When
either Memory Subtotal or Memory Total is
depressed, Memory N Count will print. N Count
is always printed in red, left justified. If the
Equals key is depressed immediately after the
Subtotal Total, Memory Subtotal, or Memory
Total the average of the entries is printed.
When the N Count prints on the 7150, an audit
symbol will print to the left of the N Count.
The audit NA will identify the Accumulator
register N Count, NG will identify the GT
register N Count and NM will identify the
Memory N Count.
Apr 23, 2012 | Monroe 7130 Calculator
Hp 1020 printer total page count information
Hi, what operating system are you using? In Windows XP you can view the page count by doing the following:
- Go to the printer's Properties window (click the Start button, go to the Control Panel and click on Printers and Faxes, right click on the printer and choose Properties).
- On the General tab, click Preferences.
- On the Basics tab, click About.
You can see the page count in the About window, toward the bottom.
For page count or configuration page instructions on other printers and copiers, check out the How to Print Configuration Pages website. Thanks for using FixYa!
Aug 31, 2011 | HP LaserJet 1020 Printer
Need to get a print count off the machine
Press SETUP
Arrow up or down to MAINTENANCE
Press OK
Arrow down to PRINT TEST PAGE
Press OK
Test page will print, total pages printed will be under Product Information.
Total pages that were printed with the installed printhead will be
under Printhead Information.
Jan 21, 2011 | Lexmark Prevail Pro705 Wireless All-In-One...
How do I print the total amount on my ticker tape of what I've added? I pressed the equals sign but that didn't work.
OFF • P P•IC
ON POWER SWITCH; PRINT / ITEM COUNT MODE SELECTOR:
"OFF": Power OFF
"•": Power ON. Set to the non print mode.
"P": Power ON. Set to the print mode.
"P•IC": Power ON. Set to the print and item count mode.
1) For addition or subtraction, each time is pressed, 1 is added to the item
counter, and each time is pressed, 1 is subtracted.
• The count is printed when the calculated result is obtained.
• Pressing of , clears the counter.
2) When the grand total/rate setting mode selector is in the ON position (GT), the
counter will count the number of times that the calculation results have been
stored in the grand total memory. To print and clear the count, press the key.
3) The memory item counter will count the number of times that the key has
been pressed in the addition.
Note: • Each time the key is used in the subtraction, 1 will be subtracted from
the count.
• The count is printed when the memory is recalled.
• Pressing of the key clears the counter.
Note: The counter has a maximum capacity of 3 digits (up to ±999). If the count exceeds
the maximum, the counter will recount from zero.
Dec 17, 2010 | Sharp EL-1801P Calculator
Konica Minolta Pagepro 1350 page count or Print Config sheet?
please go printer utilty option on your pc then you can print a testpage
Feb 10, 2010 | Konica Minolta PagePro 1350W Laser Printer
Panasonic Drum Unit reset - DP-150FX
someone else has hadd this problem. go to.
http://www.copytechnet.com/forums/panasonic/28772-dp-150fx.html
Note: To see total count of copies, press and hold % Select key, then press CLEAR/STOP key.
To print total count of copies, press and hold % Select key, then press START key.
Dec 19, 2017 | Panasonic DP-150FX Laser Printer
We have a 1025iF Canon copier. I'm trying to
hello.
the first counter 101 is total of the machine every paper that gets out of the machine(print,fax,copy,reports)and the 201 its only about copys.
Oct 27, 2009 | Canon Office Equipment & Supplies
HP LaserJet 1020 Printer Logo
190 people viewed this question
Seeker5211
Seeker5211
