Question about Omega Iwatsu ZT-24KTS-SP Speakerphone - GREY
HOW DO I TURN THE AUTO ANSWER OFF. I HANG UP ON PEOPLE OR THERE IS SOMEONE ON THE LINE WHEN I PICK IT UP.
How does a regular headset work? I plugged it into the back of the phone, but don't know how to make it pick up...
if the headset is a wireless one there is a button on the headset itself you need to press to pick up or hang up a call. alternativly look for a headset or pick up button on the phone needs to be pressed. this i diffulcult to answer further without knowing the model of your headset.
download user manual for the phone at the following
http://www.tc.mtu.edu/voice/equipment/Mitel5220/5220userguideR4.0.pdf
check page 23 regarding using heaset.
when the phone rings press the headset feature on your phone and then select the ringing line button.
then press cancel to hang up.
I hope this was useful.
Jan 05, 2011 | Mitel 5220 IP Phone
Picking up and Haning up problems. "Rls" key "Line 1-4" keys
Can you sheck something for me; under your phone where the cables are plugged into, there are 3 types of jacks... 1 jack is to plug the phone into the wall 1 jack is to plug the handset into(picture of phone handset) 1 jack is to plug a headset into(picture of headset)
Check and make sure that the handset is plugged into the handset, and NOT the headset jack... and move the cables if that is the issue. Your problem sounds very familar to your handset being plugged into the wrong jack on the bottom of your phone, and it is more common than you think.
Aug 20, 2009 | NorStar M7324 Telephone
AT&T 964 won't free phone line when incoming caller hangs up
Verizon is right, it's out of their hands. You may have a defective unit or it may be sharing the line with other equipment that is fooling the phone in thinking the call is still there. Or, you may have DSL on the line and it may not be filtered.
You'll have to start by eliminating other devices from the line, fax, computer, credit card machine etc. Now try the auto attendant voice mail. Add those devices back and check each time.
Jun 16, 2009 | AT&T 964 Corded Phone
Call Park Issues..
Well to place a call on Park:
-> you should answer the call -or- be on a call
-> press FEATURE 7 4
-> then look at the display as it will give you a park number
Anyone can pick up a phone now, then dial that park number which you've seen - to answer the call.
To Transfer:
-> press FEATURE 7 0
-> then dial the extension you want to transfer to...
Now you can either stay on the line to tell the person who you are transferring and then hang up the phone -or- just hang up after dialling the extension to complete the transfer.
Jan 26, 2009 | NorStar M7310 Corded Phone
How to configure call forwarding on RCA RCA Phone model 25425RE1-
CALL FORWARDING HAS TO BE DONE THRU THE PHONE COMPANY IF YOU HAVE CALL FORWARDING - AND I DO THIS IS WHAT I DO - I HAVE AT&T IN MEMPHIS TN PICK UP HAND SET AND HIT *72- YOU WILL GET A BEEP- DIAL THE PHONE # YOU WANT TO FORWARD THE PHONE TO - SOMEONE MUST BE AT THAT PHONE NUMBER TO ANSWER IT! ONCE THE LINE IS ANSWERED- THEY HANG UP AND THEN YOU HANG UP AND PHONE SHOULD BE TRANSFERED- I ALWAYS TEST IT TO UN- TRANSFER IT PICK UP PHONE AND HIT 73# AND IT WILL BEEP 2 TIMES- NOW PHONE IS NOT TRANSFERED ANY MORE
Jan 16, 2009 | RCA 25425RE1 Phone
Fax machine
You need to set the machine up to AutoAnswer as follows per HP:
Receiving faxes automatically If the Auto Answer option is set to On , the unit automatically answers incoming calls and receives faxes after the number of rings specified by the Rings to Answer setting. Press Auto Answer to turn on the Auto Answer option. 1: Setting the Auto Answer option
  1. 1 - Auto Answer button
    NOTE: The Auto Answer button is lit when the Auto Answer option is turned on.
  2. Press Auto Answer again to turn off the Auto Answer option.
Dec 30, 2008 | HP Officejet 6310 All-In-One InkJet...
At&T 984 Two people can pick up the same line
This is a feature for in-house conference calls. The problem lies with two people answering the phone very close together. In the handbook, it states that if you want another party in your office or home to join in on a conversation, push the Line button twice. This allows another individual in on the phone call. This also happens in our office. One party answers the phone, while someone else is trying to answer the phone. One of the two individuals inadvertently is the first one to answer and pushes the button 2x. This automatically lets the other individual in on the line. The solution is to make sure if you answer the phone, don't push the button 2x and assume someone has already answered it.
Dec 22, 2008 | AT&T 984 Corded Phone (att00148)
I HAVE A MFC 8220 AND CANNOT SET THE FAX TO PICK UP WHEN SOMEONE SENS A FAX THE FAX IS ON A SEPERATE LINE BY ITSELF
You need to enable AUTO ANSWER in the menus.
Try unplugging an replugging to see if auto answer comes back on.
Aug 25, 2008 | Brother Office Equipment & Supplies
HP G85 auto-answer
yeppers...same thing happens to mine. So, I simply set it to receive faxes manually now.
Jan 18, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
Brother IntelliFAX 5750e Laser
Is tel line going into correct socket of fax? (Line not Ext.)
Is Fax set to auto answer or manual?
If you pick up line or press speaker button can you hear other fax sending if so press start and hang up you should receive fax, and you have just proven that machine is in manual receive mode!
I think you will find it  will wake from sleep automaticly if setup correctly.
Oct 11, 2007 | Brother IntelliFAX 5750e Laser Fax
Omega Iwatsu ZT-24KTS-SP Speakerphone - GREY Logo
49 people viewed this question
Top Omega Lands Phones Experts
Computer Repairing
Computer Repairing
Are you an Omega Lands Phone Expert? Answer questions, earn points and help others
