Question about Garden
Any special instructions for vacuming water with wet/dry shop vac? its a 12 gal and doesn't have a filter.
    Sergeant:
  • 223 Answers
Just keep the machine upright and don't put more water in it than you can lift if you're going to have to pick it up when you're done.
lp
Posted on Dec 29, 2010
My rigid shop vac 4 gal 5.0 WD4070 wont start
Check elecrical connection, or switch may be bad.
Apr 14, 2013 | Ridgid Wet/Dry Vacuums Wd4070 4 Gal...
Trying to vacum and it starts to blow
There are two outlets on a shop vac one to blow and the other to vacum.
Dec 13, 2012 | Craftsman 12 gal 5.0 peak hp Wet/Dry Vac -...
How to use 9 gal wet/dry for wet use?
to use for 'wet' use --- just remove the foam and paper filter from the inside of the unit. it is now ready for wet use.
make sure you let the unit dry out before you reinstall the filters and use it for dry use.
c...
Feb 15, 2011 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
Ridgid shop vac is not sucking
Check the intake hose for a blockage. Attach the hose to the exhaust outlet and turn the vacuum on. If no extracted air is blowing out of it the hose is totally clogged up
Apr 10, 2010 | Ridgid 25648 Wet/Dry Vacuum
Vacuuming up water with Shop Vac model 84M200
when picking up dry materials use the foam sleeve that slips on and the blue cloth (assuming there all blue) over it, there should be a ring that slides over blue cloth to hold it in place over the foam sleeve, for wet pick up u can use the foam sleeve minus the blue cloth but let it dry out before picking up dry stuff, you can pick up both wet and dry with a cartrige filter that looks simular to a car air filter and it slips over the foam sleeve, but let it dry out after picking up water before picking up dry cause itll just clog it up
Oct 25, 2009 | Shop Vac 84M200 Wet/Dry Vacuum
What if i use my wet dry vac to pick up water without a filter
DO NOT USE A FILTER WHEN PICKING UP WATER!!!!!
Im certain if you check the instruction manual it says to remove the filter.
Oct 13, 2009 | Shop Vac 925-13 Canister Wet/Dry Vacuum
How do i go from dry vacuming to wet vacuming with the rigid shop vac
can I run my sears shop vac without the paper bag, for dry pickup?
Jan 29, 2009 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
Automatic pump for 10 gal shop vac
first you have to remove the filter in the vac then at the bottom of the vac tyhere should be a cap you remove and screw a water hose on and run it out side then when the vac fills the water will run out put the main hose on the suction side
Mar 21, 2008 | Shop Vac 584-06-00 Canister Wet/Dry Vacuum
Shop Vac Model 758.17871
I would suggest it if it gets dirty muddy you can always clean the filter alot easier than replaceing vac
Dec 21, 2007 | Shop Vac 925-13 Canister Wet/Dry Vacuum
Garden Logo
43 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
