Question about Germ Guardian GGU300 Bagless Vacuum
I have a Germ Guardian GGU350TT. The Beater Bar Brush is seized up on the ends and no longer rotates. Can it be fixed or can I buy a replacement Beater Bar Brush? I've called the company and they were no help.
My XV 11 Vacuum keeps on bringing up the message " My vacuum is stuck"
This message generally means that the beater/brush bar is not turning. Try rotating the beater/brush bar manually to see if it can turn freely. If not, you will need to remove the beater/brush bar and ensure that it is clean; that the orange end caps on the brush are free of hair and dirt, and that the bar housing area is free of obstructions.
Note, when I said "beater/brush", it could be either/or, depending on whether you're using the "standard" beater bar, or the upgraded pet brush.
May 31, 2014 | Neato XV11 Vacuum
Belt no longer turns the brush
JKGonzo:
You'll need to open the vacuum head and remove the beater bar. Clean up the bearings at each end of the beater bar and reassemble the head.
May 25, 2013 | Rainbow Vacuums
The brush on my Electrolux Versatility will not spin. You can spin it by hand, but the motor will not spin it.
Hello, W/D here.
Since the brush will not spin, but the motor works, either the belt has come off of the motor shaft, the belt is worn past it's useful life, or the beater bar has seized.
1. Turn off the power (unplug).
2. Remove the bottom plate. With the plate off, use your finger to test the tension of the belt. It should be tight, and roll when you roll the beater bar by hand.
3. Remove the beater bar and belt. Inspect the beater bar, particularly by the bearings. Remove any twine, hair, etc.
4. Inspect the belt for abnormal wear. If there is any significant wear in the belt, replace it.
5. Reassembly is in the reverse order. Place the belt on the beater bar. While holding the beater bar close to it's position, place the belt on the motor shaft. Rotate the beater bar bearings to their proper position and install the beater bar. Replace the cover plate.
Best regards, --W/D--
Jan 29, 2011 | Electrolux EL8502 Versatility Bagless...
Hello. i only have one arm and am trying to figure out why my beater bar wont turn on my dyson dc14. the belt smells a little too. thanx, trixie
Sounds like the beater bar is frozen in place. This sometimes happens when the ends of the bar become stuck in the holders. The solution is to remove the beater bar and clean the small holders on each end removing any debris that has built up. Spray with a little WD40 and then manually rotate the beater brush around the holders until it is free, then replace. Be sure the belt is installed properly.
Sep 09, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
Roller brush will not rotate. Brush motor and associated shaft are spinning. Belt has been replaced. Appears that the Brush Bar is frozen..... Is there a bearing in the roller brush that is frozen? ...
More than likely there is gunk underneath the endcaps. In the small airdriven attachment those end caps come off. It's likely true of the beater brush underneath too.
Jun 18, 2010 | Bissell 3750 Lift Off Bagless Upright...
The beater bar on my Dyson DC14 All Floors Bagles vacuum cleaner doesn't turn. There is no hair or thread caught up in it. All air-flow areas have been checked and there are no blockages that we could...
If it is not on the bare floor setting then you most likely have a belt issue it is not an easy fix I am sorry to say if your mechanically inclined I can tell you how to replace it.
Dec 17, 2009 | Dyson DC14 All floors Bagless Upright...
I sucked up a piece of fabric and turned it off ASAP. Now the beater bar won't work, but the beater bar does turn. Help!
If the clothe is jammed in the power head you will need to clear it. Have the unit unplugged and manually rotate the beater bar to work the jammed material out. Sometimes a pair of pliers helps to grip the material while turning the beater bar. If there is no longer a jam then the drive belt may have been damaged and needs to be replaced. Usually when this happens the brush does not rotate. You can get a belt often at hardware stores such as ACE, or as a last resort, the dealer.
Nov 25, 2009 | Vacuums
Kirby Heritage II. Beater bar does not turn. One end rotates freely, but the other sticks, preventing the bar from rotating. No obvious means to disassemble the end of the bar. Is there a way to repair...
The bearing is bad on the end that turns hard. You will need to purchase a new brush roll assembly. If the roller is older that 4 or 5 years, it should be changed anyway. The brush strips that scrub the carpet loose their strength after many years of combing through the carpet, so it's a good idea to change it every 5 years or so.
Oct 03, 2009 | Vacuums
Ratchet noise, beater will not turn, belt not broken, in carpet mode the Dyson d07 makes huge ratchet noise and the belt will not turn the beater brush.
Ok, so I had the same ratching noise and took the advice of many sites directing me to clean the brush. But like most I cleaned the brush and the noise continues and the brush does not spin. Reluctant to take it to get serviced I dug a little deeper and now it works just fine. This is what you need to do as removing any hair from just the brush part will not be enough.
Remove the entire brush bar from the bottom of the Dyson, this means pulling the bar out of the drive belt. This is not to difficult just use a little muscle as the belt will stretch. Once the bar is out grasp hold of the two plastic end caps on the brush bar which the brush bar actual spins in. These two caps are connected by a slim metal rod which runs through the brush bar. Place one hand on each side and begin to twist and pull until one of the caps comes off. Once the cap is off of the one side you can pull the other cap from the other side through the brush bar as this cap will be the one attached to the slim bar I mentioned above. If like mine you will see a ton of hair wrapped around these caps and inside the ends of the brush bar. Clean them out as best as possible.
After you clean it out, run the cap with the rod back through the brush bar, attach the other cap and twist and push together. Make sure the caps lineup which each other just like they were when you pulled it out. You'll notice how much more freely the brush bar spins between the two caps then before you cleaned it. Now, pull on the drive belt and feed the brush bar back through and attach as it was to begin with. This did the trick for me.
Apr 25, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Bissell 6579-2 bagless vacuum. Beater bar siezed up. motor turns. took bar out, no movement from either end cap on bar.
1. Uing the appropriate sized drift punch, tap out the steel axle rod which passes through the beater drum.
2. Each end cap houses a 608ZZ ball brg.
3. Check each brg for freedom of smooth rotation. Replace both if either is seized.
4. Replace with either 608ZZ (dbl shielded) or 608 2RS (dbl sealed) brgs.
5. Inspect and be prepared to replace the drive belt since it may have been damaged in the seizure event.
Mar 16, 2009 | Vacuums
Germ Guardian GGU300 Bagless Vacuum Logo
Top Germ Guardian Vacuums Experts
JoeVacs
Are you a Germ Guardian Vacuum Expert? Answer questions, earn points and help others
