Question about Aloha Housewares (93645) Ceiling Fan
Chain pulled out of the light assembly. not sure which replacement piece would be correct.
  • 1,772 Answers
Sorry to read about your problem, I hope this helps you out.
take out the old switch, and take to home depot or ace hardware, this is a very common switch.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
Posted on Dec 29, 2010
Why does do I only get one fan speed, and not three on Model 27185?
The light is only a battery indicator light. Check the capacitor in the switchcup. Small, usually black box with wires going to pull chain switch. Also, the fan has to be set on high at the pull chain for the remote to work correctly.
Aug 17, 2014 | Dryers
Tip
Drive Hub, Spring Pulley & Chain Replacement for Steppers
Video about the Drive Hub Replacement Procedure for Stairmaster Steppers
  • This videocovers replacing the spring pulley, the step chain and the drive hub assembly on the Stairmaster steppers
  • Tools needed:
    • Snap Ring Pliers
    • Tip Kit for Snap Ring Pliers
    • Socket Wrench
    • 7/16" Socket
    • 7/16" Wrench
    • Needle Nose or Standard Pliers
    • Safety Goggles
  • Begin by disconnecting the spring
  • Do this by pulling up on the spring and unhooking the spring from the frame post
  • Next, using the snap ring pliers and proper tips, remove the snap ring from the spring pulley shaft
    **Important: Be sure to wear safety goggles when working with snap rings**
  • Remove and inspect the spring pulley for any flat spots replacing the pulley if necessary
    • Flat spots develop over time and can result in roughness in the pedals
  • On the side that the pulley was just removed, slowly press the pedal down
  • Remove the step chain retainer brackets (if equipped) using the 7/16" wrench, 7/16" socket and socket wrench
  • Once the retainer bracket is removed, the spring can be lifted up over the drive sprocket and disconnected from the chain
    • The spring is opened at one end to allow for maneuvering over the link
  • Using the standard or needle nose pliers, remove the master link attaching the step chain to the pedal arm
    • Place one jaw of the pliers against the open end of the clip (if installed correctly, the open end of the clip is opposite the direction of chain travel) and the other jaw of the pliers against the far side of the nearest rivet coming through the keeper link; and squeeze pliers together
    • This should pop the clip free allowing you to remove it from the master link
    • Next remove the link bar
    • Finally remove the master link disconnecting the chain from the pedal arm
  • Inspect the new step chain making sure all the chain links flex
    • Manufacturer recommends lubricating the step chain with 30W motor oil using a clean rag to remove any excess
  • Attach the new step chain to the pedal arm reversing the steps taken to disconnect the chain
  • Relieve tension on the opposite spring by lifting up on the spring and unhooking it from the frame post
  • Slowly press the pedal down
  • Feed the spring around the pulley and lift the chain up over the sprocket to move it out of the way
  • Disconnect the remaining two bolts from the drive hub assembly
  • Lift the drive chain over the sprocket and pull the drive hub from the frame
    • As the drive hub assembly starts to develop problems, you may feel clicking, hear some grinding sounds, or a pedal may stick in one position (which usually happens on one side); All of which are indicators of a worn drive hub assembly
    • The drive hub can be replaced as a complete unit
      • The drive hub consists of (3) sprockets
        • Two one way clutch sprockets that drive in one direction and slip in the opposite direction which are for the step chains
        • A larger sprocket that spins either direction and is for the drive chain
    • An inspection of the drive hub can help determine need for replacement
          • If either of the one way clutch sprockets slip in both directions, they need replaced
          • If there is a catch in any of the sprockets in any position, then it likely needs replaced
  • Reinstall the drive hub the same way it was removed
  • Slip the drive chain over the drive sprocket before mounting the hub assembly to the frame
    • The drive hub assembly on the SC916 stepper only has 4 bolt positions. The drive hub assembly on the 4400 and 4600 steppers has bolt holes all around the hub allowing the hub to be rotated for chain tension adjustment. The SC916 stepper has a preset tension and the adjustment is no longer necessary
  • Once the drive hub is bolted to the frame, reinstall the step chains on each side
  • Place the free end of the step chain (opposite the pedal arm connection) up over the step chain sprocket
  • Lift up on the pedal and pull down on the step chain
  • Place a hand on the sprocket keeping the step chain from feeding back and allowing the pedal to drop
  • Grab the spring with your opposite hand and join the spring to the step chain
  • Once the spring is attached to the chain, press the pedal down again
  • Reinstall the spring pulley and the snap ring onto the pulley shaft
  • Lift up on the pedal and pull the spring to route through the pulley, hooking the spring onto its frame post
  • Repeat these steps to attach the step chain and spring on the opposite side
  • Reinstall the step chain brackets (if equipped) making sure all bolts face the same direction
  • This concludes the video demonstration of replacing the drive hub, spring pulley and chains on the Stairmaster steppers
Spring Pulley Chain Drive Hub Replacement Video for Stairmaster Stepper...
on Feb 25, 2015 | Stairmaster Exercise & Fitness
Hunter ceiling fan light will not turn off when I pull the chain. No remote. I replaced the switch, thinking that was the problem, and still the light won't turn off. I have to keep the lights on if I want...
Make sure it's wired correctly to the fan.The light should turn off when you pull the chain weather you have a remote or not. Also the model of the fan should be 5 digits starting with a 2.
Aug 31, 2013 | Hunter Ceiling Fan Remote Transmitter...
How do I assemble the bar and chain on my 1.5hp chain saw MS1415?
Start by removing the bar nut/nuts, and remove the side cover, if the chainbrake is in the cover make sure this is off by pulling the hand guard fully back to the top handle, before removing the side cover, wind the chain adjuster screw fulley in toward the rear of the saw ( it may be in the crankcse, or in the side cover ) now assemble the guide bar onto the bar bolt/bolts, loop the cutter chain over the sprocket,and into around the tip of the guide bar, and into the bar rails, make sure the sharp end of the cutters on the top of the guide bar are facing away from the saw ( the chain rotates clockwise as you look at it ) now align the adjuster hole in the bar with the adjuster pawl on the machine, now re fit the side cover, if the adjuster pawl is in the cover make sure this lines up with the adjuster hole in the bar, assemble the bar nut/nuts finger tight, adjust the chain so as it touches all the way around the guide bar ( not sagging on the bottom of the bar ) with a gloved hand pull the chain around the bar to make sure it is free and sitting in the sprocket correctly, re adjust the chain if required, now lift the nose of the bar and fully tighten the bar nut/nuts
Feb 10, 2011 | McCulloch 14" Electric Chain Saw Mcc1514
How do I refit chain
Start by removing the side cover held with one or two nuts ( make sure the chainbrake if fitted is de activated by pulling the hand guard fully back toward the rear of the saw until there is an audible click ) if the chain has de railed you need to check for damage to the drive links, file away any burs, or fit a new chain, screw the chain adjuster fully back, assemble the guide bar onto the bar bolts and push fully back toward the rear of the saw, loop the chain over the sprocket and into the guide bar rails with the cutter teeth on top of the bar facing away from the saw if the bar adjuster pawl is in the crankcase make sure it fits into the hole in the guide bar, assemble the side cover, if the adjuster pawl is in the cover make sure this lines up with the hole in the guide bar ( adjust the pawl screw if required ), assemble the bars nuts finger tight, now adjust the pawl screw so as the chain sits snuggley around the guide bar, pull the chain around the bar with a gloved hand to make sure it is sitting into the bar and sprocket correctly, lift the nose of the guide bar and tighten the bar nuts.
Jan 22, 2011 | McCulloch Garden
Good Day I have got a RYOBI Planer Thicknesser Model AP13 and one of the chains did broke. Are these chains ordinary Bicycle Chains or are these chains spesial chains. Regards Karl Schweizer
Part # 827794 Chain
They sure do look like bicycle chains, but without measuring the links with a micrometer and comparing them with a bicycle chain, i wouldn't be comfortable installing one you made based off of eyeballing it alone. You may know this already, but be sure to remove both sprockets the certain chain rides on, and assembling the 3 pieces as one assembly back on the shafts, its much easier then loosening the shafts from the main unit.
Nov 24, 2010 | Ryobi Garden
McCulloch 3200 won't run
sorry but really does sound as its only ran for 15 secs on the choke cleaner , we usually change the fuel filter ( thats inside the tank , use a hooked piece of stiff wire to pull it up ) , you will likely need to do a full strip and clean of the carb and fit a new diaphragm the small needle valve may well be stuck into its seat , also watch for the fuel line being perished , and very important , make sure its full of of chain lube oil and pumping correctly ( do this before you even fit the chain and bar )and the chain is tensioned correctly and the clutch and chainbrake operates properly
Nov 18, 2009 | Dryers
Chain broke off ceiling fan
Is it broken off inside the pull switch? If so, I would recommend replacing the switch. The chain attatchment assembly is riveted onto the electrical part of the switch. It is possible to drill out the rivets to separate the two sides of the assembly to replace the chain, however you would need to use small bolts with nuts to reattatch pieces together after installing new chain. It's a pain in the back side.
(of course all this repair work needs to be completed after removing the fan from its ceiling location and disconnecting the wiring)
Sep 17, 2009 | Hampton Bay Dryers
I need a pull chain DIMMER switch for my fan light. Only one set of wires supplies the fan and light. Surely SOMEBODY has a pull chain dimmer ??? Thanks. Bill
Bought three fans for the bedrooms, all hunters with pull chain dimmers. Less than one year and two of the three dimmers are shot. Can't find a replacement so I bypassed it. Remove light assembly and unplug 9pin connector. Remove black vented dimmer assembly by removing wire nuts and disconnecting the 2wire connector(black and white wires). Cut the 2wire connector off and save it in case you find a part someday. Wire nut black to black(hot) and white to white(neutral). You will disable the pull chain by wire nutting those two wires together.
Jul 29, 2009 | Hunter Ceiling Fan Light Switch Control
Mazda Millenia tail light bulb replacement
Problem has been solved. I very gently pulled on both ends of the lens assembly and it popped off. The white plastic pieces housed plastic attachment 'tabs'. They can snap right back in place once pulled out to put assembly back.
Jan 03, 2009 | 1999 Mazda Millenia
Aloha Housewares (93645) Ceiling Fan Logo
273 people viewed this question
Top Aloha Housewares Dryers Experts
Steve
Mike Carew
john h
Are you an Aloha Housewares Dryer Expert? Answer questions, earn points and help others
