Question about Sony CDX M60UI Marine Receiver
The unit was working, then i washed my bike, some water did get on the face, i dryed it off but unit face will not work, do i have to return this item back for replacement, the face comes off, so i did also clean all connection and dry everything still no good, can i take apart the face, it does have screws? i also put it in frount of a heater very carefully, " plow dryer " but still no good,, help,TERRY
bmwrider
  • 215 Answers
SOURCE: My mom washed it
A good washing certainly won't cause dry joints. I'm afraid your unit will be well and truly By Byes. Hold a funeral, play the last post (with someone else's MP3 player) and go buy a new one. And empty your pockets next time you want Mom to do your washing. BMW
Posted on Jul 07, 2006
Jexx
  • 148 Answers
SOURCE: face does not come down and remote won't work
EXTREMELY common problem for these units. The faceplate ribbon cable has gone bad and needs to be replaced.
Posted on Oct 31, 2006
Cerfer39
  • 709 Answers
SOURCE: submerged in water
hi Inga,
Remove the battery for 2 days, Run hair dryer on it for aout 15 minutes too. keep it in a dry place for at least 2 days with no power from battery at all. If this doesn't work your probably not going to get it to work again with sending it to a repair shop for estimate of damages and repairs needed to recover.
Check out my website www.playstationclinic.com, we may be able to get it working again for a reasonable price.Just get the battery out  and keep it out for at leat 2 days. Hit it with a hair dryer again before you put the battery back in.
Posted on Oct 18, 2007
  • 53 Answers
SOURCE: laptop speakers not working after water spill, everything else is ok
I'd say a wet speaker will never sound that good again, have it replaced, it's not that expensive.
Posted on Feb 13, 2009
SOURCE: volume control
If you did not fix this, I would like to purchase the antenna from you. My ex wife returned my radio with a missing antenna! So please email me at christian2002ad@aol.com
Posted on Aug 20, 2009
I bought edifice casio watch and when i use while washing hand the water goes inside at the first moment ???
unless it is waterproof you should remove electronics before going near water....
even water proof and water resistant electronics can get hairline fractures that will allow water to seap in.
once wet it will stop working.
BUT - - if you dry it thoroughly and replace batteries (if they also got wet) it can work again but you must be sure all water is dried before returning power to machine
as an example, a CRT tv i owned years ago was submerged in water for a while... of course it no longer worked.
but after three days of having a fan blow air over it it was completely dry and again worked
WARNING: only works for CRT tvs the flat screen tvs likely will allow water to seep into the screen so while you think it is dry it is still wet in the screen
Jul 02, 2014 | Watches
I have a whirlpool gold quiet partner III Black dishwasher. All of a sudden it stopped working. I push the accusense button and start the cycle for washing, it looks like everything is working normally, I...
Hi
If clean light is blinking then it may be an issue with heater circuit, door switch or wash pump, please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry or High Temp Wash-Heated Dry-High Temp Wash-Heated Dry . Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset. If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back if you need more information.
Daniel
Aug 30, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool gold quiet 3 dishwasher flashing clean light nothing works i had to push 2 button and cant remember code to reset unit
Hi
If clean light is blinking then it may be an issue with heater circuit, door switch or wash pump, please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry or high temp wash-heated dry-high temp wash-heated dry. Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset. If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back if you need more information.
Daniel
Aug 28, 2011 | Whirlpool Dishwashers
We have Kenmore dishwasher and the clean light is facing. It will not let you cancel the clean status and will not allow you to start a new cycle. What can be done to fix this issue?
Hi
If clean light is blinking then it may be an issue with heater circuit, door switch or wash pump, please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry. Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset. If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back if you need more information.
Daniel
Aug 04, 2011 | Dishwashers
I have a Kenmore elite dishwasher. The Pots and Pans red light is flashing and the Heated Dry light is solid red. Nothing I do will change that. I've tried pushing any combination of buttons and ...
Hi
Daniel
Jun 19, 2011 | Kenmore 24 in. 17482 / 17484 / 17489...
Morning i do a water wash on my pulsar 180dtsi and then later half hourse when i try to start the engine, i heard a "gulg" "gling" sound from the engine and it stop, i tried to push the...
i too faced the same problem with my pulsar 180dtsi ug3...
when i inquired it to my mechanic he said that pulsars come with CDI unit(used for ignition) if this unit get wet the engine will behave erratically. You must allow the unit to dry or blow jet of air in the unit.
after this bike will start normally....
sarath
May 16, 2011 | 2011 Bajaj Pulsar 180
Washed bike.Engine light on Wont start. push started bike. Bike ran. Directionals, horn dont work. Headlights / breaklights dim. Drove but misfires. Fuel injected. Never had a problem with bike ever. 2003
Sounds like you have water that is pooled in a connector or in the wiring harness water conducts electricity time to take covers of and expose areas and blow dry with air suspected area where water would settle relays multi plugs check each one for water.
May 23, 2010 | 2003 Harley Davidson FXSTB Night Train
Washer-dryer # wm3677HW will not dry,heats up, run, on and on
You're a moron. This unit washes and dries. That's the whole point of it. Perhaps you should do some research before answering the question. the most likely cause is the water lever sensor.
Aug 09, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
I washed the bike and it wont start now. the
have you checked for a spark at the plugs. You may well have got water in the coils.The cure for this is natural drying. if this is the case the coils will need to be sealed. and the leads silicone sprayed
Jun 04, 2009 | 1999 Suzuki GSX 600 F (Katana)
Sony CDX M60UI Marine Receiver Logo
42 people viewed this question
Top Sony Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Sony Boating Expert? Answer questions, earn points and help others
