Question about American DJ Dyno-Fog-II Fog Machine W/ Remote System
Dyno fog doesn't pump juice and the motor is very quiet. Do I need to prime the system?
Do you have to prime a fuel pump after it has been rebuilt
when you put a new fuel pump on whatever type mower you are working on,yes its good to prime it a little so that your not cranking the juice out of your battery and easier on starter.when you prime it ,myself I put the new fuel pump on,and I pull the plug out and put a little fuel in cylinder head so when it fires it pump the fuel up faster to your carb! good luck!
Nov 12, 2014 | Briggs & Stratton Garden
Pump not working
need more info does system have power to pump motor? if not check breaker if voltage from breaker check switch if you do have power to the pump motor sounds like bad pump motor
Feb 12, 2014 | Zodiac Pool Systems Pool & Spa
No juice to my windshield wiper motor (2004 Hyundai Sonata)!
Clean washer pump connector with de ox-it or replace connector , clean corrosion
Jan 22, 2013 | Hyundai Sonata Cars & Trucks
How can you tell if your fuel relay is bad
Most vehicles have a "system prime" that occurs when the ignition key is moved to the "ON" position. This is where the key ends up after you start the engine. This prime runs the fuel pump a second or two to get the fuel pressure high enough for the injectors to work once you crank the engine. The prime is performed by the fuel pump relay. In a quiet area (minimal noise, no radio), sit in the vehicle and turn the key to the on position without cranking the engine. You sgould hear a 3-5 second buzz or hum. This is the fuel pump coming up to pressure. If this is not occurring, then either the relay or the pump is most likely bad.
Nov 13, 2011 | 1997 Chevrolet Blazer
Pump motor will not turn over without manual priming?
All pumps need to be primed. The Self-Priming pumps still require water in the basket.
If water is not staying in the plumbing system when it is turned off, then you have a leak in one of the o-rings or the shaft seal.
Sep 04, 2010 | Hayward 1 12 Hp Super Swimming Pool Pump...
I had to take the motor out and put it back together now its not getting water what do I have to do. The motor works fine
If this is a self priming pump you will just have to fill the pot with water. If not you will have to open a valve and force some water through the system to prime the pump. This being done, if you still have no water you may have a suction leak keeping the pump from priming and may need a repairman at that point. Good luck.
Apr 25, 2010 | Sta Rite Ds3hf 1.50 Hp Self Priming...
Gas Pump doesn't get electric juice, unless I jump the fuse? I change the pump and still doesn't get juice when start switch is turn on to start the car
check mas air flow sensor they used to put power to fuel pump when cranked also check engine computer ,its puts ground to relay when first turned on to give a 2 second shot to the fuel pump to prime fuel system
Oct 04, 2009 | 1984 Porsche 928
Shoots out liquid instead of fog...
that thing(the heater) just doesn't work well,
bring it to someone to repair it
Apr 23, 2009 | American DJ Dyno-Fog-II Fog Machine W/...
Low fog output
I had the same problem with an American DJ, I removed the pump took it apart and cleaned it. It had a stuck valve in it. It now works fine.
Oct 27, 2007 | American DJ Dyno-Fog-II Fog Machine W/...
American DJ Dyno-Fog-II Fog Machine W/ Remote System Logo
106 people viewed this question
Top American DJ Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an American DJ Audio Player and Recorder Expert? Answer questions, earn points and help others
