Question about Refrigerators
Icemaker leaking where it meets the frigs' rear wall, ? bad o-ring? I would love a exploded view of the ice makers componets, Thank you!!!!
  • 10,865 Answers
Helloo spayl.... Go to the website searspartsdirect.com
Enter your model number. This site has exploded views of most brands and models of appliances. If your model is there, it will show you exactly what you need to know. Joe
Thanks for choosing Fixya!
Posted on Dec 29, 2010
We have a Samsung side by side. Ice maker on the top as part of frig. water is leaking and I see the ice stopper is not closing to keep the warm air from entering the ice compartment. Any ideas
If the icemaker is leaking water onto the floor:
  • Turn off the icemaker and then turn off the water supply to the icemaker. See Icemaker On/Off Switch.
  • The water supply line is usually located under the kitchen sink.
  • Locate the cold water line and look for a small 1/4" copper line attached to it. Where these two lines meet, there will be a saddle valve. This is the shut-off valve. Turn this valve in a clockwise manner until it stops. This will shut off the water to the icemaker.
Aug 11, 2017 | Samsung Refrigerators
How can i turn off the water function on the door but not the ice, the water line keeps leaking on the back of the frig
When I had this problem the water was coming from the top right rear where the water tube feeds the ice maker. The water line INSIDE the frig that feeds the ice maker occasionally freezes up causing an obstruction which causes the water to leak out the rear. This can only happen when the icemaker activates the water feed. You can remove the tube fitting without fear because the valve that feeds water through the line is at the bottom rear of the unit. If the line is frozen inside I remove the ice bin and tray and use a hair dryer to melt the ice.
I have a similar problem with the condenser fan making a tapping/clacking noise which is also a result of ice building up on that. Wish I had a different frig but for now the hair dryer will have to do.
Feb 06, 2012 | LG LSC26905TT Side by Side Refrigerator
The Ice Maker is making little to no ice. should the hoses replaced after so many years?
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects theb you need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking same part needs replaced.The water valve at the bottom rear of fridge.
Thank you for using fixya
Leo Ponder
Please rate me if this helped.
Jul 24, 2011 | Whirlpool Refrigerators
Water dispenser on frig is not working, water trickles out, therefore no ice can be made either.
Leo Ponder
Jul 24, 2011 | Kenmore 56563 Side by Side Refrigerator
I have an Amana refridgerator, BRD18V13, and the ice maker stopped making ice. What's wrong?
Leo Ponder
Jul 23, 2011 | Amana Refrigerators
Water leaking. Mongram zic[s]360 (frig on top, pullout freezer on bottom with ice maker. no water dispenser). Leaks with water supply cut off to icemaker. Ice forms on bottom. Several years old but we...
Have the fridge pulled out and check behind it. I had same model and it was leaking into my walls/floor and caused thousands of dollars in damage to my kitchen. BLACK MOLS Covered my walls/cabinets and made me sick. Please be very careful with this excess water coming from this model. GE should recall it but will not unless forced. Not Cool.
Jan 16, 2010 | GE Monogram ZICS360NR Bottom Freezer...
Leaking water in icemaker. water from icemaker leaks into freezer and freezes on freezer wall
If you are sure that it's coming from the ice maker I believe that you possibly have a leaking water control valve on the side for the ice maker on the rear of refrigerator near floor there is a dual water valve control. Many times when this happens the water will freeze in the fill tube that fills the ice maker in the rear of freezer. You can defrost the frozen water in the fill tube with a hair dryer but that will not stop the problem from coming back. When that happens water tends to at times go everywhere but the ice maker. You can test the water control valve several ways. By unplugging the side to the ice maker and if water continues to flow slowly to the ice maker then the dual water control valve will need replaced, Sea Breeze
Sep 10, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
1. I am getting black spots in the ice cubes.
multiple probems you have my friend the black in the cubes is the telfon coating on the mold of the imkr and the best thing to do is replace the complete icemaker then this will solve the leak issue as well the mold is cracked and for the some how the 1/4'' tube has sprung a leak pull away from wall take off the back panel and have some one try to get water from the dispenser then you find the leak then its off to the menards to buy a plastic 1/4'' push connector about 5.00 once you got the coupling shut off the water to the tube that goes to the frig once done use a razor to cut the bad part of the tube (don't use sissors or ****to cut tube it will squeeze the tube and not allow it to seal properly in you new coupler you just bought) then after you cut off the bad part out just push into the coupler it will go in to the coupler about 1/4'' into the coupler install the other side turn water back on and test again...... congrat's you fix it but your not done unplug the frig get your vacuum and clean the dust bunnies out of the rear of the unit once done plug back in and make sure you see the fan blade turn freely and nothing is holding it up did it turn ............. ok then put back on and push the frig back to the wall allow at least 2'' away from the wall
Sep 06, 2009 | Amana Refrigerators
My Ice maker stopped working (no water for ice) I replaced the water supply solenoid and plugged it back in. Ever thing worked fine except when the water valve cycled open. Water began leaking from the...
Yes, the short tube that goes from the back of the refrigerator to the icemaker can freeze up solid preventing any more water to pass thru. this is caused by a bad water valve that is slowly leaking water to the icemaker.
Jul 05, 2008 | Refrigerators
Refrigerators Logo
82 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
