Question about Dyson Ball DC24 Bagless Upright Vacuum
I do not know how to remove the canister that catches the dirt. I do not have a manuel.
  • 1,772 Answers
Sorry to read about your problem, I hope this helps you out.
Emptying the Clear bin caution: (i) switch 'off' and unplug machine before emptying the bin.
Empty as soon as the dirt reaches the level of the MAX mark - do not overfill.
To remove the clear bin from the machine press the button at rear of carrying handle. to release the dirt, press the button again to open the bin.
Please note: (i) Do not use the machine without the clear binin place.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
Posted on Dec 29, 2010
Release button to empty cylinder wont work cant get it off manually
Hello, the canister empty function works by pulling a long plastic rod that moves the catch on the bottom access door. It sounds like either the puller is stuck or that the rod may be broken. If the puller does move upward when pulled, then the later in most likely. You can check by removing the Torque screws and pulling the top section off very gently, because the canister really needs to be opened and removed first, do this outside to avoid a dirt spill in the house, either way I would look for a used canister from another machine, which is really a much cheaper and less dirty option.
Mar 07, 2015 | Dyson DC07 Bagless Upright Cyclonic Vacuum
How do I take the barrel off a Dyson DC59 animal stick cleaner so I can clean it properly
Hi there, it's Jack at Dyson.
It's quick and easy to remove DC59's clear bin, which will allow you to remove any fluff or debris from the mesh shroud using a soft brush or dry cloth.
Press the red bin base release catch once, as if you were emptying the machine. Then with the bin base still open, press the same red catch down firmly a second time to disengage and remove the clear bin.
When the clear bin has been removed, you can wipe the bin and the rubber seals with a damp cloth to remove any clinging dust. Make sure all parts are completely dry before reassembling the machine. Please do not wash or submerge the clear bin or cyclone pack - this can cause damage to your DC59 not covered under guarantee.
I hope this helps, but if you'd like any additional guidance you're welcome to call the Dyson Customer Helpline on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Mar 02, 2015 | Dyson DC59 Animal Bagless Cordless Stick...
How do i clean canister of dirt devil featherlight bagless caniter vacuum
Hi there! To clean the canister or dirt cup, first remove the dirt cup from the vacuum. Twist off the dirt cup lid. Remove the pleated filter and empty the dirt cup. Tap the filter against the trash can until the dirt stops falling. If the filter is really dirty it may need to be replaced. The filter should be replaced every 6 months. I have included a link where you may go to purchase a replacement filter if needed.
Thanks! Hope this helps!
F1 HEPA Filter
May 18, 2014 | Dirt Devil Featherlite Bagless Vacuum...
How to empty it
1. Push down on carry handle and
pull dirt container away from unit.
2. Once it is pulled back lift it out.
3. Hold dirt container over trash can and push down on bottom
release lever to release debris.
4. Close bottom cover on the dirt
cup until it snaps shut.
While you have the dirt container out you can also clean the Lifetime HEPA filter. It is on the top of the dirt container.
1. Twist lid to the left to remove lid and filter from
container
2. Remove foam filter from dirt container and dump out
any loose dirt. Wash the foam filter.
3. Remove the HEPA filter by Twist filter handle to the left and
pull out of lid. Wash the Heap filter.
4. Once the filters are thoroughly dry (I recommend set out for 24 hours) then installer filters in lid and thread back on top of the dirt canister.
Before replacing the dirt canister you can also clean the exhaust filter install below the dirt canister on the top vacuum cleaner head.
1. Loosen the exhaust grille by pressing the locking tab, and
remove it.
2. Remove and shake out the exhaust filter and wash it.
Note: Scented filter are not washable.
3. Once the filters are thoroughly dry relace it and snap the
exhaust grill into place.
Replace the dirt container
NOTE: Dirt container will not
align on base if filter is not
aligned properly.
May 15, 2014 | VAX Appliances Vacuums
I have a dirt devil easy lite... how do I empty the top canister? I know how to empty the bottom half.
The upper half is where the filter is.
Here is the manual:
http://dirtdevil.com/file/172/
Page 7 shows after emptying the lower container, "Twist and lift to remove dirt container lid."
Aug 06, 2013 | Dirt Devil Easy Lite Quick Vacuum
Not picking up dirt
Have you tried cleaning out under te plastic cover? Remove it as you would when you replace the belt I get stuff caught in there or just inside hard metal tube there is a small magnet that will catch things and sometimes block it up. Use hose to **** it all out and clean. I find this helpful when it doesn't want to pick up as well I know it is time to clean it up.
May 16, 2012 | Rainbow E series Canister Wet/Dry Vacuum
Thehow do you clean the black piece n the dirt canister
It is possible to separate the clear bin from the cyclone pack. Open the bin base to discard any dirt in the clear bin, then use the coloured catch on the rear of the clear bin to detatch it from the cyclone pack. The black rubber seal can then be cleaned with a dry cloth, and you can remove any debris from the shroud (the section with the small holes) using a soft brush.
Please note, the cyclone pack must never be washed or submerged in water as this can damage the machine.
I hope this helps - if you'd like any further assistance or advice, please call us on 0800 298 0298 (UK), or 1-866-693-9766 (US).
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
Mar 27, 2012 | Dyson Ball DC24 Bagless Upright Vacuum
Dirt is being trapped in the filter area instead of canister.
The canister has a filter as well. It needs to be replaced or cleaned. A damaged canister filter will feed dirt into the HEPA filter. (and the motor)
An improperly installed filter can allow dirt to bypass the canister filter and collect in the HEPA filter.
I suggest a new canister filter and then clean it carefully every week.
Here is a list of the filters for your vacuum.
Apr 16, 2010 | Eureka 5893AVZ Bagless Upright Cyclonic...
I am unable to open the canister to remove the old bag, unclipping the 2 clips on the side does not release the canister. What am I doing wrong?
Overtime the dirt canister can get somewhat stuck. Once you unclip it, you will need to apply some force and pull down. The dirt canister should release.
Apr 18, 2009 | Broan-NuTone CV350 Central Vacuum
Dyson Ball DC24 Bagless Upright Vacuum Logo
180 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
