Question about Hoover Self-Propelled WindTunnel Bagless Upright VacuumVacuum
The roller is not working on the carpet but works on the tile. What could cause that?
  • 1,772 Answers
Sorry to read about your problem, I hope this helps you out.
it sounds like your belt is loose, when on the floor, their is no Resistance, but on the rug their is.
So i suggest you replace the belt.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
Posted on Dec 29, 2010
Rainbow vac brush won't turn on carpet. It does turn on tile or hardwood.
The belt is stretched and does not have enough friction to keep the roller running on a carpet surface.
Sep 05, 2017 | Rainbow Vacuums
I have a simplicity 7350 vacuum. The belt and roller have recently been replaced. It runs fine on floor mode and has no problems with suction. When I put the vacuum in carpet mode, I do not hear the motor...
the motor spins around a steel shaft that sticks out on one end, and the belt is driven by that shaft, belts are easily damaged and broken, meaning roller wont spin. Often a burning smell of rubber is noticed after motor shaft spins on stuck belt. cause is always hair./string/something at the three contact points. motor shaft and belt, roller and vacuum body become clogged. become familiar with taking cover off roller/belt, and cleaning Checking moving parts roller/belt come out easily and simple to clean...keep spare belts.
Mar 10, 2014 | Vacuums
What causes my Shark Vacuum to work only intermittently?
If the brush roller operation is intermittent, there may be hair jammed inside the end caps. The brush roller can be removed and the end caps also for inspection. Intermittent operation also can be caused by a stretched drive belt.
The periodic failure to pick up may be caused by something such as a ball of hair migrating through your vacuum cleaner and stopping from time to time to test your patience
Jun 26, 2013 | Shark Navigator Bagless Upright Vacuum
How do I make the noise stop?
Seems like the bearing on the side of the roller has gone bad. If there is a dirt gone deep inside, it is hard to clean it. It can also go bad if the roller hits the uneven surface like the transition strip between carpet and tile. It can unbalance the roller causing it to go off its axis and get misaligned.
This is the roller for the Hoover Elite Rewind
http://www.ezvacuum.com/hoover-93002124-brushroll-for-u5509-u5511-u5512-elite-rewind-p-3607.html
May 20, 2013 | Hoover Elite Rewind Bagless Upright...
Dyson DC21 All Floors Stowaway
Simply answer Yes it would be but try and make sure the the old head is clean before dumpin it just in case
Jul 20, 2010 | Dyson DC21 All Floors Stowaway HEPA...
Works in FLOOR position but not in CARPET.
The power nozzle has a reset button. Push that and that should fix the issue. You could of sucked up the corner of a piece of carpet causing the brush roller to become jammed. If that doesn't work, there could be a problem with the hose. The hose perhaps isn't providing the power to run the power nozzle.
Oct 12, 2009 | Kenmore 23612 Progressive PowerMate Bagged...
Carpet roller will not turn. Vacuum still sucks up dirt
You may need to replace the belt that drives the roller head. They wear out and break, or maybe it has just come loose. Also check for string and thread wound around the roller wheel axles, that is a common "culprit"
Jul 21, 2009 | Kenmore 23913 Progressive PowerMate Bagged...
Bissel proheat 2x main suction problems
bissel pro heat x2 does not suction up the cleaning fluid
May 25, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
Dyson suddenly hard to push on carpet
I know this sounds silly, but it works. Turn it over and wipe all the black residue off the bottom of it (off the plastic on the bottom that rubs on the carpet as you push and pull it). I thought my husband was out of his mind when he told me that was the solution, but it really works.
Jun 02, 2008 | Dyson DC14 Animal Bagless Upright Cyclonic...
Hoover Self-Propelled WindTunnel Bagless Upright VacuumVacuum Logo
27 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
