Question about RCA HD52W59 HDTV Projection Television
When u turn on the tv green light on power button lights up for about 5 seconds then it goes off there is no picture that shows when this happens. Then it got to set awhile before u can get to turn on again.
  • RCA Master
  • 6,993 Answers
This problem is more or less like a bad capacitor on the power board which is making the TV switch on and off by itself.
I know of someone that had this same problem and the cause was because the capacitors used on the TV were only 10V and the welding was poor. The capacitor was replaced with 25V capacitor and re-soldered the bad welds. Now it's working normally again.
The value of these capacitors will be different, most likely they will be somewhere around-820 to 2200uF/25 V( or /10V sometimes)
You can replace them with same values but I would recommend the voltage rating to be higher(like 35V for an original 25V) for reliability purposes.
What happens is,these bulged top capacitors will cause a low and unfiltered DC voltage=main board will malfunction(the relay will keep clicking until the caps are holding enough charge to bring the voltage up over a threshold point).
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors).
After replacing these capacitor(capacitors) most likely the normal operation will be restored.
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you. Also, note that TV stores a lot of current, so wait a while before opening the TV back cover.
I hope this helps.
Compliments of the season.
Posted on Dec 30, 2010
Sony bravia kdl55hx729 3d led tv turns on 3 seconds shows picture than four red flashes
the error light sequence that you are seeing is indicating a "backlight error". Most likely you have a bad inverter board -the board that powers up the back-lights behind the display panel. They might be available via ebay if you are a DIYer, or you need to call for sony service.
Good Luck!
Rich Lilja
Dec 07, 2013 | Sony Bravia KDL-55HX729 LED Internet TV...
WHAT IS WRONG WITH MITSUBISHI TV MODEL WS65819 THAT POPS ON AND OFF?
shutdown is happening= If set has been unplugged plug it back in and turn set on--when green power light goes off in a few seconds:
On front of set (not the remote) press and hold both the Menu and Input (Device) buttons at same time and hold for at least 5 seconds---then release both.
Power light will blink an error code like 2 blinks, 2 blinks pause and repeat it for a total of 5 times.
Let me know what error code is and I will tell you what it means.
SD TECH
Apr 26, 2012 | Mitsubishi WS-65819 TV
My toshiba 40ft2u1 will not turn back on
I'm having the same problem right now. I get the green light for about 5 seconds (not Blinking) then the light goes out. No sound or picture.
Apr 05, 2012 | Toshiba Televison & Video
I am currently working on a Sharp Lc37sb24u. I was originally thinking it had a bad inverter board but now I am not so sure. When I turn the tv on the picture comes up with audio for about 2 seconds the...
Did you check the service manual troubleshooting guide yet. You can try disconnecting the power to the inverter board and see if it will stay on and have sound.
Service manuals:
http://elektrotanya.com/?q=showresult&what=Sharp%20LC37SB24U&kategoria=&kat2=all
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Oct 27, 2011 | Sharp LC37SB24U 37 in. LCD TV
I have a Sharp LC-46E77UN TV. Remote will start TV green light on. No picture, just stays black. PVR is on and connected to TV via HDMI cable. Cannot turn off green light. Must use power button on TV and...
THe problem is in the set top box. Or common called the tuner box. IT looses the 5 volts to the main display and thus the monitor will go into a shut down state. THESE boxes are factory repair only and must be sent off to repair.
Feb 20, 2011 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
I turn on my KDF-55WF655 Sony TV. The green power light flashes about 10 seconds and then the picture fades in to full intensity for about 305 seconds then goes blank. The green power led flashes about...
If lamp has not been replaced in tv in last 2-3 years, then replace the lamp as symptom shows that lamp has reached to end of its working life span and causing that problem.
Lamp is not dead or broke but weak so you get above said problem in tv.
Thanks.
Oct 05, 2010 | Sony Grand WEGA KDF-55WF655 36" Rear...
55" TV keeps shutting off automatically
Green light flashes 5 and then red light flashes 6
Sep 14, 2009 | Sony KDF-E55A20 55 in. LCD Television
Sound and picture on and off green light blinks
1st try this....unplug tv...hold power button for 10 seconds...wait 2 minutes....plug back in, if this doesn't fix it you probably need to replace the lamp
Jul 13, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
SONY KDF-E55A20 5 red blinking lights on power button
Symptom shows Lamp is weak in result and causing restart of TV again and again. Your TV requires new lamp as per following part number...
A1085447A* LAMP BLOCK ASSY XL-2200U
It is available in Sony Accessories Store for $200 and replacement procedure is written in instruction manual of TV.
Always buy Sony original lamp for TV and avoid aftermarket / cheap lamp for TV safety.
May 18, 2009 | Sony KV-36FV26 TV
Won't come on
hy i got a toshiba 42" LCD tv ,when i press the power boton
iget the red light,& it stay that way ontil i pressthe power back off
thanks for any help
Jun 26, 2008 | Toshiba 62HM95 62" HDTV
RCA HD52W59 HDTV Projection Television Logo
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
