Question about Samsung WB650 Digital Camera
My new Samsung WB650 camera has just frozen, whilst I was reviewing the various functions. It won't respond to any of the controls, and won't even switch off. If I remove and replace the battery it has no effect. If I then switch it on the 'on' light comes on, but it still wont respond or switch off. Can you let me know what has happened and if there is way to restore normal function?
    New Friend:
Thank you TY Price. Solution no.1 worked for me....Really pleased
Posted on Jan 05, 2014
  • 11967 Answers
SOURCE: camera will not function normally
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Apr 10, 2010
Testimonial: "Thank you for your insight and help, amazing answer, and soooo detailed and thorough. Tried everything,time 4 a new one i think :("
mark sox
  • 24 Answers
SOURCE: Samsung Digimax S700 is frozen with lens open
the beeping sound means that the camera has low battery capacity. the lens is stuck out because there is incorrect battery connection. there is an option on the camera setting for the battery type. try this one:
-turn the camera on
-click on Menu button
-select options using left/right, up/down button
-select Set up 2
-Select Battery type
-Select Alkaline for non-rechargable
or Ni-MH for rechargable
-click OK button
this setting should be done when using camera for the first time and whenever you are switching battery types, from rechargable to non-rechargable and vice versa.
Posted on Jan 13, 2008
SOURCE: my samsung digital L730 wont turn on
Just fixed mine, if the lens is out that's the problem we had, it was jammed and not allowing it to switch on, we gently pushed it back in, then switched on, the lens came out a bit then jammed, pushed it in again & kept doing it until it cleared the blockage.
Works fine now!
Hope it works for yo
Posted on Feb 01, 2009
fathitkf
  • 1871 Answers
SOURCE: My samsung batteries keep dying. I just put new
Hello :
Try to clean the base where the batteries set . Maybe the base became rusty or got some isolation stuff on it . If that didn't help , then there must be a problem with the main PCB [ printed circuit board ] . For that you need to take your CAM to a repair shop .
good luck .
please don't forget to rate !
Posted on Apr 05, 2010
  • 313 Answers
SOURCE: I have been given a gift of a Tl 150 Samsung
Go to the Samsung web site look under support/service and lokk for downloads and updates. enter the model number of your camera and download the manual in PDF format which you can print off.
Posted on Aug 01, 2010
Samsung wb650 keeps shutting off
took the memory card out and then turn on the camera and see the result. If its going off again then camera firmware corrupt and u need to visit service center.
Aug 12, 2012 | Samsung Cameras
Rca 24" tv remote won't operate tv
If set turns on with the power button on set the remote is : not set to TV, not programmed for the set, has bad batteries or is bad.
If it even works one function it may need to be reprogrammed or taken apart to see if works---you can test the remote by pointing it at a digital camera with a LCD screen and pressing buttons to see if it makes the screen flash on the camera.
Test the remote first
Apr 09, 2012 | RCA Televison & Video
My samsung LED TV turns on sometines and other times the red light stays on and won't respond to remote control
leave the tv disconnected for a while because if you keep messing with it like my kids did and it will cause the bulb inside to burn out and will not even be worth fixing
Dec 13, 2011 | Televison & Video
Downloaded firmware update for olympus vr-310 and now its frozen with the lens out, wont turn on and the camera is not detected through the usb cable
It's always dangerous to download a firmware update because if you don't follow the directions perfectly, you could end up with a "brick" instead of a camera. Review what you did and compare that to what the directions said. Also, when you were done, (if you connected the camera to the computer) did you remember to use the "safely remove hardware" function?
Sep 04, 2011 | Olympus VR310 Digital Camera
The touch screen is frozen and won't respond to anything. Is there a reset?
Try this, unplug it for about 10-15 second. All these modern appliances use microprocessors for control. Unplug is doing hard shut down on your computer. stewbison
Aug 20, 2011 | Samsung RFG297AARS (285 cu ft) Bottom...
REQUIRE OPERATING MANUAL FOR MODEL WB650
-this is the link of where you can view a pdf manual for your camera. click here . you can save it once its fully loaded.
Jun 05, 2011 | Samsung Cameras
Samsung TL205 Battery Charger http://www.samsung-battery-charger.com/Battery-Charger/Samsung-TL205-Battery-Charger.html Samsung ST50 Digital Camera Battery...
What a battery of information you have accumulated - you must be a bright spark. Please put a plug in it now.
Jun 27, 2017 | Samsung Cameras
Question to your answer
in playback mode, press the up/down arrow and it should change through various settings until you are back to normal, non-flashing highlights.
Sep 24, 2008 | Nikon D40x Digital Camera
Camera is frozen
My camera is frozen and it won"t turn off in less
I take out the batters.
Aug 18, 2008 | Samsung Digimax S630 Digital Camera
Samsung WB650 Digital Camera Logo
268 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
