Question about Dryers
Will not dry my clothes purchased in 9/9/082 - Dryers
  • Dryers Master
  • 7,482 Answers
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Check the Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the thermostat/thermistor due to overheat.
Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape or with an ohm meter to test the thermostat/thermistor. (Should have/show continuity)
If the coil heats up then replace the thermostat/thermistor.
(Thermal fuse.If it overheats the dryer will not operate. It's located on the blower housing. It cannot be reset. A vent clogged with lint can cause it to overheat. You can test it with an Ohm meter or continuity checker, if no continuity, replace it)
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST.
This could cause a FIRE, as you have removed the safety of overheat from the machine.
Right after replacing a dryer element, always run the dryer on 'air fluff' / 'no heat', and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
For video and pictures on how to replace the element go to the following website:
davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
This is a FREE answer, Please rate me
Posted on Dec 29, 2010
Small dent in stainless steel fridge door how can I fix it?
Purchase a small piece of dry ice to aid in repairing any small dents. Carefully hold the dry ice with clamps or another utensil over the area to pop the dent out. If you have a dent with sharp, well-defined edges the dry ice method may not work as well, and you should either contact the manufacturer to purchase a new panel or a local auto body shop offering paintless dent repair to determine which avenue to pursue.
Finish the repair by wiping the repaired area down with a damp cloth and buff with a separate soft, dry cloth to make the surface shine. If you had to use any touch-up paint or sealer wait until the area is fully dry before you wipe the area.
Apr 05, 2011 | Refrigerators
Dryer element is not drying clothes like it use
if it takes too long check your vent
Feb 07, 2010 | Dryers
Brand new Maytag Centennial electric dryer does not dry clothes!
It may have shipping damage, such as a loose or broken connection or heating element.
But if it's brand new, it's under warranty, and they will fix it free.
You can find your nearest Maytag-authorized servicer here.
Jan 09, 2010 | Maytag Appliances Over-the-Range Microwave...
I have a Bravos clothes dryer and when the cycle is finished, it is very damp, wet and the clothes are not dry. What can I do?
This dryer automatically starts in the "sensor dry" mode. DO NOT use the "sensor dry" mode - use the timed cycle where you manually set the time. The sensor is in the back of the drum, and it frequently misreads the wetness of the clothes, especially if there is a t-shirt or something light in the back and towels or something heavy in the front (near the door). If you are still under warranty, you can have the sensor replaced (or purchase one), but it only helps slightly.
Oct 18, 2009 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
LG Dryer not Drying clothes
well there must be some problem with the motor engine you should get it checked.
Jul 23, 2009 | LG WM3431H Washer and Dryer
Prolem drying clothes
I just contacted Samsung Tech Support for my wash/dryer combo WD-J1255C.
The reply.."it is not a full dryer ...and it is not sold as a full drier.. and don't expect it to be completely dry". I queried why it is advertised as a dryer and got the same reply.
Its a great washer but why did I pay extra for the dryer combo?
May 18, 2009 | Samsung Washing Machines
Dryer is not drying clothes.
well im not going to look up the model # to see if its gas or electric,but check the exhaust tube for blockages
Apr 21, 2009 | GE DBSR453EBWW Electric Dryer
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
