Question about liftmaster Garage Door 1/2 Hp
Remote only works in the garage, soon as i step out side the garage it dosn't work help please
  • 59 Answers
Try replacing the battery, if this does not work either the transmitter or the receiver could be faulty, or there could be radio interference. The simplest solution would be to fit a universal garage door remote control, these are cheap and very easy to fit and will certainly solve your problem. Universal garage door remote control
Posted on Dec 30, 2010
Garage Door Remote
Did you happen to put a new light bulb in it? I put an LED bulb in mine and the interference caused the remotes to stop working. I had a bear figuring it out, because it seemed to be totally random. Sometimes they would work and sometimes they wouldn't. Once I switched back to an incandescent, it worked fine.
Jan 17, 2014 | Genie Wayne Dalton 36560U 1/2 Hp Dc Belt...
Garage door opener remote does'nt work when the garage door is shut
Probably you have a weak battery in your remote transmitter. When the garage door is closed it requires a stronger signal. Open the remote and replace the battery.
Oct 20, 2012 | Home Security
I have 2 problems with my Craftsman Garage Door opener: 1. I have a 2 door-garage & 2 remote controls Both remote controls can open one garage door (since they were originally programmed). They...
I can't help you on programming.
If the door goes up as soon as it touches down, it is going too far down.
Locate the adjustment on the box on top. There should be four adjusters:
Door down amount more or less
Door up amount more or less
Force down more or less
Forch up more or less.
Turn the Door down amount toward the "LESS" or "-"
Let me know how you do.
Gary
May 31, 2011 | Garden
I have a pair of Chamberlain Liftmaster Professional openers (Chamerlain Model 2500 belt drive) in my two-car garage. Both systems are identical, so it is easy to troubleshoot. I am able to completely...
It sure sounds like you have a light bulb that is generating a radio signal that interferes with the receiver in that one opener. Remove the bulbs and try. As strange as it sounds it can happen.
Nov 08, 2009 | Sears Craftsman LiftMaster Chamberlain...
Two remotes
One of your units has reverted to an earlier technology or if you just bought the keypad you got the wrong one for your opener.
Apr 24, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door close up to 1/2 of the garage
try adjusting the doors down travel , depending on your brand and also check your sensors and pressure sensitivity ,if none of the above the next step would be replacing the logic board , that also controls the functions of sensitivity and travel adjustments , hope this helps , please leave good review if i was able to help Sincerely Glenn
Mar 04, 2009 | Sears Craftsman LiftMaster Chamberlain...
I have a 51-C Camberline Gar. Door Remote Where can I find match
The klik-1 will code in to this opener. The directions on the manual are very specific, but if followed it will work. There is also a number for step by step help on the directions. Thanks BB
Dec 30, 2008 | Sears Craftsman LiftMaster Chamberlain...
Tv remote dosn"t work
Check with new battries, and if you have a camera phone you could see the front IR bulb lighting up when seen through the phone display. Patrick
Jun 16, 2007 | Symphonic ST419E TV
liftmaster Garage Door 1/2 Hp Logo
381 people viewed this question
Top liftmaster Building Materials Experts
Terry Smith
Level 1 Expert
David Payne
David Payne
Glenn Mayer
Glenn Mayer
Are you a liftmaster Building Material Expert? Answer questions, earn points and help others
