Question about Carrier (52PE315) Thru-Wall/Window Air Conditioner
Problem with remote will not switch unit on or off
  • 2,133 Answers
May be transmission problem. Replace new battery in remote and check. If not,check with camera phone focusing on transmission signal of your remote. Press any button in remote. If ultra light flashes, your remote is o.k. Other wise repair PCB where receiving sensor problem.
Posted on Dec 29, 2010
Remote rc 1030
it must be your remote has been broken (just like my remote on tv) better to buy a new remote or buy a universal remote control.
thank you for using fixya
CHARCOIS
Oct 31, 2008 | Denon AVR-2807 Receiver
My samsung inverter condition does not switch off error C1
Try:
Switch the unit off with the remote (power button) - "C1" appears on unit
Push "Auto Clean" button on remote
Unit should switch off
Nov 16, 2012 | Heating & Cooling
Cant get sound in dvd mode only in radio mode
PS: Check if you car has remote wire or anterna wire.
Details below.
A relatively common problem is installing an amplifier with a factory head unit or other head unit without a remote turn on wire (or a burned out circuit). So the amplifier doesn't stay on 24 hours a day you need a way to turn it on and off remotely. Hence the term "remote turn on wire". Almost every aftermarket head unit has a remote turn on wire. Some manufacturers call it a power antenna wire. But regardless of the label all it does is output a positive 12 volts when the head unit is turned on. It should be noted that some head units have both a remote turn on wire and a power antenna wire. It's important to use the right wire for your amplifier and other electronic equipment. In the case of both remote and antenna wires the power antenna wire will only output 12 volts when the radio is on. If you were to connect your amplifier's remote terminal to the power antenna wire then you would only get output from the amplifier with the radio. When you switch to CD the amplifier would not work because the head unit turns off the power antenna wire when the radio is section is not active.
There are several ways to get your amplifier to turn on and off remotely even if your head unit does not have a remote turn on wire. The cheap and easy way is to run the amplifier's remote terminal off of a switched accessory wire. This is the wire that your head unit uses. It is only powered when the key is in the accessory or run position of the ignition switch. When you shut the car off the wire loses power and the head unit and amplifier will both turn off. Your amp will be on when your car is on and off when you car is off. If you don't want the amplifier to always be on when the car is on you could wire a simple switch inline with this new remote wire. Normally you would leave it on so that it turns on when the head unit is on. But if you wanted to turn the amplifier off you could flip the switch to off which would stop the flow of 12 volts to the amplifier's remote turn on terminal.
Baadaye Mo
Oct 26, 2010 | Clarion VZ709 Car DVD Player
I can't lock the car using the remote key. the light flashes on the key but does not lock the doors
try reprograming the remote, if that doesn't work u may need a new remote these are the factory instructions.
1. Switch ignition on with a key (don’t start the engine!); leave key in the ignition.
2. Mechanically lock vehicle at left front door, using second key.
3. On remote unit, press "Open" button once. A short horn signal will sound.
he "Open" button is pressed once for programming the first, or a single,
remote unit.
�� When programming additional remote units for the second, third or fourth
memory addresses, press the "Open" button two, three or four times, in
one-second intervals.
�� Example: press the "Open" button once, wait 1 second, then press once
again to program the second remote unit.
�� After 6 seconds, press "Open" button once to activate the coding ocess.
4. The remote unit will now be coded, and it can be used to unlock the central
locking system. Switch ignition off.
The key must be removed from the ignition before the remote unit can be used to lock
the vehicle.The coding process can be repeated up to 4 times for additional remote units.
In between each remote unit coding, the ignition must be switched off.
Apr 10, 2009 | 2004 Volkswagen Jetta
I need to change my DVD players Region code to play all regions.
1.Switch on unit 2.Press- Setup on the remote
3.Select the Lock option from the on screen setup menu
4.Press Lock on the remote unit ( under slide cover)
5.Press 0 7 times on the remote keypad
6.A message appears stating the unit is now Code free on the screen
7.Press Enter on the remote.
8.Close Setup menu and switch unit off.
9.Switch on and enjoy Multi-region DVD playing
please donot forget to rate this solution.
Thanks for using FixYa.
Jan 28, 2009 | LG RC199H DVD Recorder/VCR
Require region unlock code for LG RC389H
1.Switch on unit
Oct 19, 2008 | Televison & Video
Ceiling fan and lights with remote control
I got a new reciver installed in ceiling fixture,works fine:Boytin
Mar 15, 2008 | Hunter 52" Ceiling Fan With Light And...
AIR CONDITIONER REMOTE
- Check if the battery is ok.
- Some remote control have reset button, you can find it at the front or back at the compartment of the battery push the rst button with pin or ballpen to reset it and try.
- Some remote control have selector switch in both remote control and at the board inside the unit. Try to transfer the switch button from A to B and also at the board inside the unit and reset the remote control and try.Or need to reconfigure the remote control to select the frequency.
- Try your remote control to other unit with same brand as yours to confirm if your remote control is really need a replacement. If it works then your receiver board in the unit is need a replacement. Or if wont work then you have to buy a new remote control. But if you have no budget then try to switch on the unit using emergency button to operate the unit.
Dec 26, 2007 | Heating & Cooling
Carrier (52PE315) Thru-Wall/Window Air Conditioner Logo
174 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
