Question about Apple iPhone 3GS Black (16 GB)
How do i set my contacts to both sim an phone?
How do I move contacts from my sim to my phone
go to contacts..then to tabs on settings ..there should be setting allowing you to move sim contacts to phone. Just make sure your phone has enough space to hold data from sim. seems you are missing some details... new phone? differnt size sim? etc?
Dec 12, 2017 | Cell Phones
How do I copy contacts from phone to sim card on my Samsung 7272r
  1. Find "Import/Export contacts" Tap Contacts. Tap MORE. Tap Settings. ...
  2. 2a - Copy contacts from your SIM to the phone memory. Tap IMPORT. Tap SIM card. Tap Device.
  3. 2b - Copy contacts from the phone memory to your SIM. Tap EXPORT. Tap SIM card. Tap EXPORT.
Nov 28, 2016 | Samsung Cell Phones
Htc t8697 mozart
I believe you can copy the contacts to the sim card. Once you copy the contacts to your sim (that is if you can) insert the sim to the new android phone and copy the contacts from sim to the phone via Settings manu > Contacts > Copy sim to phone.
Hope this helps :)
Jul 25, 2013 | Cell Phones
Phone contacts or Sim contacts I have copied my sim contacts to my phone as per set up but contacts are still showing on sim. How do I have all contacts shown on my phone and delete contacts off my sim. I...
With Peoples contacts, you canchoose (Peoples - Menu button - View - check box SIM).
With the phone book, the only way is to delete the contacts on the SIM.
Please note that it's not easy to write back the contacts to the SIM.
Jul 13, 2011 | SKYPE Android Apps
I transferred all the phone numbers from my old sony ericsson cell phone to my sim card, but cannot figure out how to copy all the sim numbers onto my new sony ericsson vivas pro.
To transfer your contacts through the SIM card:
  1. Copy your contacts from your old phone to your SIM card. If you need help with this, please consult the old phone user guide.
  2. When the copying is done, move the SIM card to your new phone.
  3. Select Menu > Contacts.
  4. If the phone asks you to copy info from the SIM card, skip steps 5-10.
  5. Otherwise, tap Options > Settings > Contacts to display.
  6. Select SIM memory > OK, then tap Back.
  7. Tap Options > Mark/Unmark > Mark all.
  8. Tap Options > Copy > Phone memory.
  9. Tap Options > Settings > Contacts to display.
  10. Select Phone memory > OK, then tap Back.
Feb 28, 2011 | Sony Ericsson Vivaz Cell Phone
My phone is a Samsung B2100, all my contacts in my phone book have mysteriously disappeared! When I try to add a new contact, it is unable to save it, however I can see that my contacts are still on the...
if the contacts are on the sim then remove the sim and put it in a new phone, put a new chip in the b2100 and search for the factory code in the phone's manual go to security search for factory setting and enter the factory code the phone will restart then put back the old sim.
Feb 26, 2011 | Samsung B2100 Cell Phone
I have a set N91 Nokia set and want to transfer all my contacts from phone memory to sim card. I have tried by navigating to Contacts -> Copy all options and then tried to paste to sim card but that...
Please check your phone contacts settings .If yuor contacts visibility in "Phone and Sim " mode put it in Phone mode only.Then mark all phone contacts and take option then you can copy the phone contacts to sim.
Sep 27, 2010 | Nokia N93 Cellular Phone
How can i reinstall the software in lg kp500?
I think ur contact list settings have been changed from SIM to phone...
So, plz, change ur contact list settings to Phone & SIM or SIM or Phone as required....
If U want contacts 4m SIM, then change the setting to SIM......
Menu>Contacts>Settings>Contact list settings>SIM......
Njoy......
Jun 13, 2010 | LG KP500 Cookie black on T-Mobile U-Fix...
Contacts duplicate in messaging tocco f480
select the proper memory either phone or sim
if phone and sim is then youll have this issue
When you copy contacts from sim to phone or phone to sim we will face this issue as well
Instead move contacts between phone and sim
Jan 12, 2010 | Samsung Tocco F480 - Pay Monthly Cellular...
HELP!!!!
go into your you phone book settings and change the setting to save on sim card and that should automatically save them there then there's another setting where you can copy all the contacts saved on the phone to the sim to save putting all your contacts on the phone again hope this helps
Sep 29, 2008 | Nokia 2630 Cell Phone (Unlocked) - Black
Apple iPhone 3GS Black (16 GB) Logo
16 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
David
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
