Question about Corona 23-DK Compact Heater
I cant shut the heater off. The knob wont turn to the left. Even the shut off switch on the side wont turn the heater off. What should I try?
    Novelist:
    Champion:
  • 224 Answers
Try tilting the heater so the flame extinguisher snuffs it out. Please do this out side as it really does stink when it is shut off this way. After it cools please take it apart and check the wick you have a problem in your heater and something is bound up in the wick assembly. Take your time and do this outside as well because it is a messy job and kerosene stinks. Your wick should turn up and down with little to no resistance.
Posted on Dec 29, 2010
  • bonpatsun Oct 29, 2014
    that didnt even work
Why won't the main water supply knob turn to allow water to the water heater
Shut off unit then turn off water to house at water main out side. Drain water heater remove old valve install new
Jul 20, 2014 | Reliance Water Heaters
Hi... im at a friends home and am in need of help with the water but cant find an operations manual. The top pilot switch was set to off and the bottom temp control was on vacation. Am i able to just...
Identify gas control valve, with instructions for lighting each type... these instructions also show on side of water heater.
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
Knob rotated to off...means pilot light is off, and water heater is off.
Read instructions shown with each gas control valve shown on link above.
Don't forget that gas supply to water heater has to be ON. Gas shut off valve must be parallel with gas line.
http://waterheatertimer.org/images/Gas-water-heater-89a-350.jpg
Gene
h
Sep 19, 2013 | Water Heaters
My 02 nissan pathfinder interior fan runs even when not turned on.checked all fuses they seem to be fine.
If fan still runs when all your heater control knobs and buttons are off, it is likely a bad heater fan switch. Unless you have something like a body control module found on newer cars that has some control over interior functions. If not, try a new heater fan switch. Good luck.
Jan 18, 2012 | Cars & Trucks
Large left side, front burner, does not shut off when you turn the control knob to, OFF. It gets very very hot and remains that way for a long period of time. I can keep turning the , OFF, knob, but...
That means the switch is shorted(the contacts welded their self together) the only fix for that is to replace switch. AS A SAFETY PRECAUTION UNTIL THE SWITCH CAN BE REPLACED TURN OFF CURCUIT BREAKER TO STOVE
Gene
Aug 01, 2011 | Kenmore 95313 Stainless Steel Electric...
I have a Lochinvar pool heater that on the dispaly is showing Air Pressure Switch Open. I looked at the manual and it talks about air flow from the supply vent and exhaust vent. Than it says about...
Hi and welcome to FixYa, I am Kelly.
Try this before taking anything apart to far:
The pressure switch is located in the front header, behind the
upper side jacket panel, above the water connections. When
required, the pressure switch can be reset with the following
procedure:
1. Clean filter and skimmer.
2. Start filter pump.
3. Set digital thermostat to highest setting.
4. Turn the adjustment knob on the pressure switch clockwise
until the combustion air fan in the front control panel turns
off. Fan will not turn off if system pressure exceeds 5 PSI.
5. Slowly turn the adjustment knob counter-clockwise until the
combustion air fan turns on. Turn knob an additional ¼ turn
counter-clockwise.
6. Turn filter pump off and on several times. The heater should
shut down immediately when the pump stops.
7. If the heater does not shut down immediately as the filter
pump stops, repeat steps 4, 5 and 6 until proper operation
is achieved.
8. Reset thermostat to desired temperature setting.
If after doing all of the above you still have the problem.... you can remove the switch and check for debris in the water passages. If you find debris remove it, reinstall the switch and repeat steps above.
- Still have the problem... Replace the switch.
Thanks for choosing FixYa,
Kelly
Mar 21, 2011 | Lochinvar ENERGY RITE 399000 BTU PROPANE...
I can't turn off my heater. Knob wont turn?
If the knob is still jammed when you read this and the heater is still burning (Gosh, it must be hot), just firmly bump the heater on it's side (don't burn yourself, though) so that the tip over switch will disengage the wick and the heater will go out. The other good thing is that it will also unjam your knob.
Please be very careful doing this.
Feb 03, 2011 | Corona 23-DK Compact Heater
I have an older monterey wall heater that is gas that wont seem to light. I cant even get the gas to start from the pilot can you help me?
You could have a plugged pilot line. You will need to get to the gas valve and shut the gas supply off. Once you did that, unscrew the pilot line that supplies gas to the pilot assembly. You can then turn on the gas supply and rotate the pilot knob to the pilot setting. Depress the knob into the gas valve. You should be able to smell and hear the gas come out of the hole where you unscrewed the pilot line. Don't do this with a cigarette in your face. Once you verify you have gas, release the knob and shut off the gas supply. Take a can of air and blow thru the pilot tube, first from the pilot assembly in the heater then from the open end of the pipe. Replace the pilot tube making sure you don't cross thread the fitting. Tighten well. Again turn on the gas supply, spray or rub some soapy water on the fitting you tightened, depress the knob and hold it. The soap will bubble up if there is a leak. Fix it. Now light the pilot.
Jan 20, 2010 | Heating & Cooling
Blower wont turn off
If you turn the key off and it wont shut off the heater then there are some interesting things you need to check. The first would be the whole ignition switch. When you shut off the key, the power should stop to that accessory. If that is okay then you need to check the controls for the heater. The issue with no heat is one of a blend door being stuck and this could be the controls again.
Aug 19, 2017 | 1991 Honda Accord
My ge dryer wont start
Hi thanks for the question. You could have a problem with the door switch, On that dryer theres a belt break switch.check that
Dec 16, 2008 | GE DWXR483EBCC Electric Dryer
Corona 23-DK Compact Heater Logo
246 people viewed this question
Top Corona Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
Are you a Corona Heating and Cooling Expert? Answer questions, earn points and help others
