Question about Kicker SX1250.1 Car Audio Amplifier
I have a kicker sx 1250.1 amp with 2 cvrs 12's in a ported probox will that work
JULIANFIX
  • 975 Answers
SOURCE: 2006 12" Kicker L7 4 ohm
first whats the range in terms of WATTS that your 12" sub can handle in 4 OHMS ? second , lets check the AMP , POWER ACOUSTIK 1800 WATTS , Now thats a lot of power to drive a single 12" sub speaker . your amp is 1800 watts , per channel is around 500 watts , if BRIDGE thats around 1600 watts rms for ONE channel , if your sub can handle that kind of wattage fine , but it will not blow the amp , what it does is shuts down , some kind of protection mode , it will come back on after a minute or so. I suggest to use one channel in stereo mode , or purchase another sub to use the other channel. i hope this helps AJ
Posted on May 06, 2008
CAYPIANAN
  • 227 Answers
SOURCE: Kicker amp shutting off
hello my friend you should have the input signal set to 500 miliamps do not go over, another thing is that if you have good ground and the battery is good and it has the sufficient amps to push it.also the ohms of your spkrs are not too low,you need to check all that.
good luck
caypianan@yahoo.com
Posted on Nov 03, 2008
SOURCE: nedd help kicker kx1200
the kx1200.1 should be able to handle 3 cvr's just fine. do not let the ohm load go below 1 ohm however. this amp is stable at 1 ohm, i have 2 of these amps and they are incredible, let me tell you...
Posted on Dec 18, 2008
  • 273 Answers
SOURCE: What amp need to use for Kicker (2) S12L7 12in Solo Baric
you should use an amp with approx half the power of the speakers max output (i.e 1000 watt speaker use no more than 600 watt amp)
Posted on May 13, 2009
blueextc3221
  • 15935 Answers
SOURCE: 2 channel amp with 2 Kicker Cvrs 15"
Assuming the amplifier is 2 ohm mono stable... the amplifier is bridgeable... and the subwoofers are Single 4 Ohm Voicecoils, You would wire them as follows....
Both + on Both subs to the + bridged terminal on the amplifier.
Both - on Both subs to the - bridged terminal on the amplifier.
This will net a 2 ohm mono load for your amplifier.
If you have something different - let me know... and I will give you the proper wiring for what you have.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Posted on Jun 10, 2009
I have a Kenwood 720 amp powering 2 12 inch kicker cvrs..the amp will work fine for a few second then the bass starts skipping out and the amp shuts off..
check speakers impedance are matching amps. example: if you drive a 4 ohm amp with lower imp you are close to blow your amp or it goes to protect itself from you. anyway your amp provides 140watts maximum on 4ohm in bridged mode, so if you connect two 12" kickers with 4ohm, they will have 2ohm in parallel connection. solution would be to connect them in row (serial) but impedance will go up to 8ohms then.
Thanks for using FixYa - a 4 THUMBS UP rating is appreciated for answering your FREE question.
Feb 26, 2011 | Kenwood Car Audio & Video
I dont have the blast port wire and it wont play.where can i find the wire?
  • BLAST Port (Bass Level And Signal Transfer) Provides Remote Bass Level Control and control signal transfer between multiple SX amplifiers
  • Here is the manufacturer's accessory page to the remote: http://www.kicker.com/zxrc
    Here is one on eBay: http://cgi.ebay.com/KICKER-2010-10-ZXRC-AMP-AMPLIFIER-REMOTE-BASS-CONTROL-/360328112100?pt=LH_DefaultDomain_0&hash=item53e53aa7e4
    And here is a note from Kicker on how to make a control yourself for strapping multiple amps together: I have two or more Kicker SX or KX subwoofer amplifiers. I don' t want to use all those separate bass level controls. Is there a way to make them all work with a single Kicker control knob?
    Yes. You can visit your local Radio Shack or home improvement store and purchase an RJ-11 modular adapter. You then plug the sub level cables from the individual amplifiers into the adapter. Then run a cable from the adapter to a single Kicker remote knob. All amps will now work with a single knob.
    Dec 28, 2010 | Kicker SX400.2 Car Audio Amplifier
    I have two kicker cvrs 2003 model wired at a 2 ohm load, one
    Sounds like the sub is blown. Swap the two subs and see if the sound comes from the other sub in the original location as well. If not, then you have a bad sub. If the bad sound happens with both subs then you need to look at wiring and the Amp.
    Mar 07, 2010 | Kicker CVR12 Car Subwoofer
    Best way to connect a 15'' kicker cvr15 4 ohm dvc [single sealed box] and a volfenhag zx-4712 1000w 12'' 4ohm+4ohm dvc to my pyle 885 1000w 4 ch. bridgeable amp and how to wire the voice coils that are in...
    best way is to just run the volfenhag with a set of wires for 2 channells(one set per coil) left and right @ 4 ohms per channell. The CVRs you can parallel the coils(2 ohms) and run a set from each sub to the amp in stereo left and right. This will give the kickers a little more juice than the 12 but should be fine.
    Jan 25, 2010 | Rockford Fosgate Car Audio & Video
    Jun 10, 2009 | Kicker CVR12 Car Subwoofer
    Mono amp
    well first check ur wireing next the amp is turned down or just bad amp let me no if that helps
    Sep 26, 2008 | Kicker CVR12 Car Subwoofer
    Best wiring and best sub boxes for my solo x 12"
    I did not realise yall used these boomers over there. search the internet I bet you can find every thing yoy want threre. just searrch car stereo
    Mar 04, 2008 | Car Audio & Video
    Would this work
    Yes, that amp works great with the CVRs as long as they are 12" subs and you get 2-dual 2-ohm subs. I started off with the same setup and it pounds HARD!!
    Jan 29, 2008 | Kenwood KAC-9102D Car Audio Amplifier
    Kicker SX1250.1 Car Audio Amplifier Logo
    104 people viewed this question
    Top Kicker Car Audio & Video Experts
    Professor_V
    Professor_V
    Tygh Duval
    Tygh Duval
    Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
