Question about Samsung Star GT-S5233 Cell Phone
I have drop my cell phone in to the water suddenly i have dry my phone what to do its not oning
  • 37 Answers
Try to use a hair-dryer to dry it up.
Posted on Dec 29, 2010
Tip
What To Do if I Drop My Cell Phone in Water?
The small convenient size of cell phones unfortunately also makes these electronics accident-prone, especially when it comes to water. If you drop your cell phone in water it is often possible to salvage it. If you drop your cell phone in water, you may have only seconds to retrieve it, so you need to act fast even if it means retrieving it from the toilet!
The next thing to do if you drop your cell phone in water is to remove the battery immediately without even hesitating to turn off the power. Dry the batter with a towel and set aside to dry thoroughly. The battery itself may or may not work again, fortunately batteries can be replaced fairly inexpensively. Even if the battery does work, it is a good idea to get a new one.
After you have removed the battery, dry off the cell phone with an absorbent towel as best as you can. Use cotton swabs to soak up water in crevices and on any fragile, exposed circuits. It is also helpful to disassemble it if you can and let all the parts dry separately. Just be sure that you know how to put it back together. If it is a flip or sliding cell phone, leave it open.
If you drop your cell phone in a beverage or in salt water, rinse the phone off with fresh water once you have removed the battery. Once you drop the phone in water, the additional rinsing will not do further damage, however, minerals or other materials will.
If you drop your cell phone in liquid that isn’t pure water, you may want to try giving it an alcohol bath. The alcohol will displace minerals and microscopic substances as well as aiding in the evaporation of the fluid. If it is available, you should use an alcohol concentration of 95% rather than rubbing alcohol that usually contains only 70%.
Once your phone is clean, leave it in a warm dry area or near an air conditioner for three days before you attempt to replace the battery and turn it on. This is very important, because although you may think that you have thoroughly dried it, the slightest moisture can react with the battery and cause it to short circuit. If droped your cell phone in water, and want to save it, resist the temptation of turning it on to see if it is working until you have waited at least 72 hours.
on Mar 10, 2010 | Cell Phones
Htc one how to dry it out after being drop in water
UGH! Sorry to hear that. You could try the old Bowl of Rice method, where you place the phone inside a bowl of rice, or inside a ziplock back full of rice, and then leave it there for a couple of weeks. (the rice is UNCOOKED!!!) Hopefully, that helps. If not, your phone might be toast. Check and see if you have insurance with your carrier, and whether they insure against water damage.
Jun 29, 2014 | HTC One X Android Smartphone Glamour Gray
My iphone 4 drop in my dishwater with bleach will it dry out and work again
Dropping a switched on cell phone into bleached water will certainly damage the electronics in the cell phone.
You can remove the battery and dry it out, but most likely it is damaged beyond repair.
Mar 10, 2013 | Apple iPhone Smartphone
SonyEricsson T707 was dropped into water. On recovery (2mins ) later stripped outer covers off and removed battery and sim card. Used hairdryer on unit for about 20mins. Can you suggest anything else I can...
The next thing to do if you drop your cell phone in water is to remove the battery immediately without even hesitating to turn off the power. This reduces the risk of a short circuit which would render your phone useless. Dry the batter with a towel and set aside to dry thoroughly. The battery itself may or may not work again, but fortunately batteries can be replaced fairly inexpensively. Even if the battery does work, it is a good idea to get a new one so as not to risk it leaking battery acid in the future.
After you have removed the battery, dry off the cell phone with an absorbent towel as best as you can. Use cotton swabs to soak up water in crevices and on any fragile, exposed circuits. If you have dropped your cell phone in water, it is also helpful to disassemble it if you can and let all the parts dry separately. Just be sure that you know how to put it back together. If it is a flip or sliding cell phone, leave it open for maximum evaporation.
If you drop your cell phone in water that isn’t pure such as a beverage or in salt water, rinse the phone off with fresh water once you have removed the battery. Once you drop the phone in water, the additional rinsing will not do further damage, however, minerals or other materials will.
Once your phone is clean, leave it in a warm dry area or near an air conditioner for three days before you attempt to replace the battery and turn it on. This is very important, because although you may think that you have thoroughly dried it, the slightest moisture can react with the battery and cause it to short circuit. If drop your cell phone in water, and want to save it, resist the temptation of turning it on to see if it is working until you have waited at least 72 hours. Unless you have insurance for your cell phone which covers water damage, there is no point in sending it to the manufacture with the hope that they will replace it under warranty. If you drop your cell phone in water, the technicians will be able to tell immediately due to moisture sensitive stickers that are contained inside almost all cell phones. The best thing to do is to try the tips mentioned above and repair it yourself.
Jan 03, 2010 | Sony Ericsson T707 Cell Phone
I dropped my cell phone in the water
http://www.fixya.com/support/r3771170-phone_water_damage
Oct 08, 2009 | Motorola Mobility RAZR V3
I droped my voyager in water
HI,
PLEASE USE HAIR DRYER TO DRY IT AND DONT CHARGE OR SWITCH IT ON FOR A DAY....................................
thank you for using fixya,rate my answer,
vijay
Oct 04, 2009 | LG VOYAGER VX10000 Cellular Phone
My cell phone fell into water bucket for five minutes
DO NOT USE HEAT. You will damage the tiny components of your phone.
The best thing to do is that the moment you get water in your phone, disassemble it. Remove the battery as soon as possible. this is very important. Then, open the casing and seperate whatever you can, like the memory card, the back cover, the keypad etc. Shake out any water that you can from the openings. When you shake it you will most probably get some water out.
Now, use a dry cloth to dry your phone. Dry as much as you can.
Next, take a bowl and fill it with dry, uncooked rice. Yes, rice. :) Put your unassembled cellphone in this bowl. All of its parts should be in the rice. Now leave this overnight atleast. If possible, leave it for 2 days.
Then, assemble your phone again. It should work fine now. Atleast mine did. :)
Hope it works for you too.
Plus, as you have already done the first part and dried it, just leave it open under a fan etc overnight and it will work fine.
Apr 03, 2009 | Nokia N73 Cellular Phone
Water damage
1) Take the battery, sim card (SD card if there is one) out and dry
2)Dry the battery compartmant
3)For about 24 hours turn the phone upside down, or so the water will drip OUT
4) Then for about 2-3 minuets dry with a blow dryer, on low
5) YAY your cell phone SHOULD work, if not then the damage is serious
Dec 30, 2008 | Cell Phones
Samsung Star GT-S5233 Cell Phone Logo
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Bill Long
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
