Question about Samsung SyncMaster 940MW 19" LCD Monitor
Samsung hi my lcd tv samsung syncmaster 940 mw seems to not turn on any more ive changed the lead but it still dosent work before i just had to hold the channel up button for more than 5 mins but now not even the green light flashes on any more i was wondering if you could help me with this problem thanks
  • 4 more comments
  • Anonymous Nov 20, 2008
    Pulsandoelinterruptor de encendido del monitor Samsung SyncMaster 940 Mw nose enciende,necesitoelesquema de montaje paradesmontarlo y comprobar el interruptor.
  • byuwill Jan 20, 2009
    I am having the exact same problem -- I guess I will call Samsung and see what they can do for me
  • Anonymous Apr 02, 2009
    doesnt cut on, try disassembling and replacing the t3.15a250v sautered fuse, worked for me!
  • metalgear696 Apr 28, 2009
    i'm having the same god damn problem, whats the fix for this, i dont wanna sound stupid but i tried to take it apart and couldnt, i got all of the screws i could find and the damn thing wont separate. my tv is getting bad, i hit the power button and now the screen does some weird flashing thing and i dont even have a flashing green light like i used to, took me 2 hours yesterday to turn on my tv. i dont wanna buy a new tv though, i love this thing to death. 19 inches and this thing runs 1080p
  • lshap12 May 18, 2009
    Would you please give step by step on changing the power supply
  • Anonymous Mar 23, 2014
    Can I change the settings on the TV so that I auto skip passed numbers like 3-1, 3-2, etc. There is nothing on those channels and it's a drag to click passed them to get to normal/actual channels on TV.
    I have digital cable going to this TV - Samsung Syncmaster
I have two of these, both of which were just dead. The back snaps off after the screws are removed and the power supply board is the small one with heat sinks and a number of vertically mounted electrolytic capacitors (cylindrical, maybe 1/2 inch in diameter, dark plastic covering, aluminum showing at the top). Some of the capacitors were bulged at the top which is always a bad sign. I decided to replace all of the capacitors in the area between the two heat sinks (six of them). The total cost from Digi-Key Electronics was under $9.00 including shipping.
820uF 25V (2)
1000uF 10V (2)
330uF 25V
330uF 10V
Get ones rated for 105 degrees centigrade.
Good as new!
Posted on Jun 20, 2009
    Problem Solver:
  • 17 Answers
If you hit the power button do you get the green light then do it flash? if not power sply need to be shanged out vancebaldwin.com place to buy this part
Posted on Apr 19, 2009
  • jewel banks Apr 21, 2009
    IF YOU HIT THE POWER BUTTON DO THE GREEN LIGHT FLASH? IF SO AND STILL WONT POWER UP TRY HONDING IT DOWN BY HOLDING DOWN THE POWER BOTTON YOUR BYPASSING THE POWER UNIT POWER REG AND SHOULD POWER UP AFTER SOMETIMES A MIN OF HOLDING THE BUTTON IF NO POWER AFTER THAT GET A POWER SUPPLY UNIT VANCEBALDWIN.COM THEY ARE EAZY TO INSTALL JUST POP HIT ME BACK FOR STEP BY STEP INSTRUCTIONS HOW TO INSTALL.
I took the advice of wa7utv and found two bulgded capacitors the 1000 uf 10v. Ordered them online from digi-key and replaced just the two. My TV now works like new!! Thank you to this website and the fine gentlemen that posted the advice! IT WORKED GREAT!!!
Posted on Sep 17, 2009
  • 3 Answers
I experience the same "power on" problem with mine, bought february 2007.
Just called the Dutch servicedesk of Samsung Electronics, just gave the serialnumber, next tuesday I will receive a new monitor.
Thumbs up this time for Samsung service
Posted on Sep 12, 2008
Why do I have no signal on the Samsung syncmaster 940 mw tv
Check your cable connection on both ends. Try to change the cable.
Oct 06, 2014 | Samsung SyncMaster 940MW 19" LCD Monitor
Syncmaster 940 mw says 'digital' on the front but I cannot receive digital tv after the switchover. Do I need a set top box?
Yes, You will need a digital decoder box. The tuner in the Samsung 940MW TV does not decode digital signals. The digital input that you are seeing is for the DVI video input on the back that you use when you connect the unit to a DVI port on a computer. Any of the digital decoder boxes from Radio Shack, Walmart or Best Buy type stores will work just fine.
I hope this helps, If so please rate my solution.
Sep 24, 2011 | Samsung SyncMaster 940MW 19" LCD Monitor
Do i need a converter box for a samsung syncmaster 940 mw
It depends. What are you using the monitor for? If you want to watch digital TV, you need a digital to analog converter. (It has an NTSC tuner.) Note: the digital to analog converters that were subsidized by the US government coupon only gave SD out.
If you are connecting to a PC, it has DVI-D (21 pin SCART) and VGA connections (15 pin SCART). (An HDMI to DVI cable or adapter would connect to HDMI video cards.) Most other set-top boxes will connect to the component, composite or S-video connectors.
I hope this helps.
Jan 07, 2011 | Samsung SyncMaster 940MW 19" LCD Monitor
Samsung 940 BW Monitor Not working (Black screen)
Hi...there,
That's indicated your backlight inverter are busted. Need to replaced a new one or repaired it. To repaired look for a bad capacitors with a bulged on top of each caps. Not sure, just replaced all the caps... Have a nice weekend!
Oct 09, 2008 | Samsung Syncmaster 940BW LCD Monitor
Samsung LCD "keys locked"
Hey it taken me a few years to find a solution to this problem.
I also own a Samsung syncmaster 2032mw.
BTW you must hold / use the "Menu key on the side of the TV", as holding the remote key dosen't work!!
Many thanks dopeNL
Dec 28, 2007 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Sound cuts out for long periods of time
I have had the same problem. Only differance is that I run a freeview box though my 940 mw. I thought it was that playing up. Also I all the keys are locked on the unit itself. The remote works everything but when I press any buttons on the monitor you get a 'keys locked info' up on screen. Its doing my head in!!!
Nov 21, 2007 | Samsung SyncMaster 940MW 19" LCD Monitor
No sound when on pc mode
Check if your PC can play audio on some other speakers or headphone. If yes, check your monitor audio cable connections. If no something's wrong with your PC audio drivers. Try re-installing them or could be a hardware issue with your PC. Get it checked.
Sep 29, 2007 | Samsung SyncMaster 940MW 19" LCD Monitor
Samsung SyncMaster 940MW 19" LCD Monitor Logo
1,942 people viewed this question
Top Samsung Computers & Internet Experts
phoenix chi
phoenix chi
Brian Sullivan
Brian Sullivan
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
