Zanussi td 61/b dryer not heating up? is there a reset switch or button to press to fix this or is the heating element gone. got this a while ago from a second hand shop. had it on for an hour or so and seems to be no heat generated.
SolutionGuy
  • 331 Answers
SOURCE: Fisher and Paykel DEGX1 Electric Dryer Stays Warm
Yes, get a new element. The reason it's on all the time is because the element coils have broken and one of the coils is touching the canister that encloses it. This creates a direct short to ground. By the way, the element has 120 volts to it all the time. It will only HEAT when 240 is applied through the centrifugal switch of the motor. Your 120 volts is shorting to ground... not enough amps to trip the circuit breaker, but enough to glow the element.
Posted on Aug 23, 2007
  • 83 Answers
SOURCE: Won't heat
Not sure how old your dryer is but earlier models had the element around the door.
As a rookie you would have to remove the rear cover, the drum, the belt around the drum and then you would sse the element held in place by clips on the inside of the front panel. The thermostat would placed not too far away. I have just purchase a new dryer (very recent model) and was told the element is located away from the door. I guess I won't know until I have a problem with mine.
As usual, heed the warnings about electrical appliances and the risk of electrical shock.
Always unplug the appliance from the power point as you can still get a stock on the neutral connection even if the swith on the power point is turned off. (tunrs of the active connection only).
Posted on Sep 14, 2008
  • 17 Answers
SOURCE: zanussi tc7103w tumble dryer not generating heat
There is a thermostat inside the drum if you open the door and feel up the front you will feel a disc with 2 screws holding it in remove the screws to expose the stat pull the stat out there will be 2 wires attatched to it. If you have a ohm meter check for continuity across the 2 conections or If you connect those 2 wires together and try the machine it should heat if so you will need to replace that stat. If still no heat i would suspect the heater to have failed
Posted on Dec 18, 2008
  • 95 Answers
SOURCE: must hold start button to run. no heat
disconnect power and remove lid. Test the door switch w a volt meter do so opening and closing the door not pushing switch if circuit stays open try pushing switch with finger. If pushing closes circuit then adjust switch.If circuit stays open replace switch. If switch operates with no problems then it is the motor. Check all connections and vacuum lint from motor
How old is this dryer?
Posted on Dec 30, 2008
SOURCE: Zanussi tumble dryer spinning but not heating up
I have same problem and been tol its either the heater or the thermostat inside the front of the drum open circuit hope that helps
Posted on Sep 07, 2009
Dryer on zanussi zwd1471w not working,new element has been fitted
Most often that I have found that when a dryer doesn't heat it's not the heating element. But more often one of the temp limit switches. Either the upper or lower limit. An ohm meter can check these.
Nov 30, 2014 | Zanussi Washing Machines
My 20 year old Zanussi dryer model TD 260 has stopped rotating, but the heat is on. Does this mean the belt has gone and where do I get an engineer to fix this.
More than likely is belt, remove the top cover, and you should see if it is the belt.
If you are in the u/k, then go to---
WWW.SERVICEFORCE.CO.UK
You should be able to arrange for an engineer to visit, or look in yellow pages for local repair company.
Jan 26, 2011 | Zanussi Dryers
Zanussi white knight dryer - the dryer is not heating up. i have pressed the red reset button the back but no heat? the drum still rotates.
It is possible the heater element is faulty or a thermostat problem.
You need to test the element and stat's with a meter to check for continuity.
Dec 22, 2010 | Zanussi TD4100W Electric Dryer
My doesnt get hot do i need to replace element took back cover of noticed reset button on element box was kicked do i need to replace element and re set switch to
Hi!!
Before spending money on another heating element, clean filter, vents and exhaust pipe (take it off and check both, the pipe and inside the dryer). A restricted hot air passage will make the heating elements thermal protection (reset switch) to activate.
Once unclogged, press the reset button and try again.
Good luck!!
Mar 20, 2010 | Dryers
Dryer does not heat model td-v75120E
Hi, open the back panel. You will find a black cutout switch with a red button on it. Press the red button to reset the heating mechanism. Close the back panel and test the machine.
Sep 10, 2009 | LG DLE2532W Electric Dryer
LG TD C70045E dryer not heating up, this has happened before and the guy just pressed a switch but cant remember where it located, please help!
On the LG TD-C70045E the reset button for the heater is located inside the back air-way cover. This is easy enough to remove and the button is obvious once the cover is off. The button will 'click' satisfyingly if it has tripped. Don't forget to switch off and unlug first...
Aug 22, 2009 | Dryers
Td 4212 w Drier is not heating
Check if it still turns but no heat. If it's a kenmore or whirlpool, it's like a fuse in back of dryer. I would need mor info if it's not these models
Jul 28, 2009 | Zanussi TD4212W Electric Dryer
Reset button
your heating element may have burned out
Jun 17, 2009 | Zanussi TD4112W Electric Dryer
Zanussi TD 4112 W Not warming up
I've taken the back cover offf the dryer and found a burnt connection to the heating element. Will try and repair.
Oct 14, 2008 | Zanussi TD4112W Electric Dryer
Aug 23, 2007 | Fisher and Paykel DEGX1 Electric Dryer
Washing Machines Logo
163 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
