Question about Kenmore 400 6942 Dryer
Dryer runs but will not heat up to dry - Kenmore 400 6942 Dryer
    President:
  • 1,194 Answers
When the dryer won't heat it is the thermostat/thermal fuse that is bad, you can test it with a voltmeter before replacing. This fuse is located inside the rear panel and it cannot be reset.
Hope this will help....
Posted on Jan 01, 2011
Why does my dryer stop heating
Clean your vent!
Try running dryer with vent unhooked if still shuts off could be bad thermostat. Try running on timed dry instead of sensor dry, could be sensor circuit.
Aug 30, 2014 | Whirlpool Dryers
Whirlpool duet dryer
Run the dryer for 2-5 minutes. Check to see if it has heat inside. If not, you have an internal problem.
If heat is generated, check your dryer lint trap. It must be clean before every dry cycle to dry properly and efficently. If the trap is clean and heat is generated, check the tubes behind the dryer for disposing of the lint.
Oct 15, 2013 | Dryers
Dryer is taking much longer to dry clothes than it once did. Took 3 hours to dry clothes last night and had an unusal odor. Dryer is 3 years old, the dryer vent is not clogged up.
If your dryer is STILL heating, but your clothes still won't dry, you may want to check the dryer interior cabinet and/or the entire run of the exhaust ducting from where it exits your dryer to the point where it leaves your home to ensure you have no kinks, clogs, or excessive bends. The following link explains many of the common problems that can cause poor drying efficiency and longer dry times:
http://www.fixya.com/support/r3578821-dryer_takes_too_long_to_dry
Before assuming you have a problem with the appliance, check your installation to ensure you are providing the dryer with proper exhaust and air flow. This is the NUMBER ONE cause of poor drying efficiency. A dryer that is clogged, or has restricted air flow, will not dry efficiently and will cause the heating circuits to OVERHEAT. This will eventually will lead to component failures and is the source of many fire hazards.
If you have any questions, please post back and let me know. I hope you find this information helpful.
FYI: There are no adjustments that can be made to any of the internal thermostats or heating element to make it run at a higher temperature. All these components have a fixed setting. If the dryer still produces heat, the heating element is working. If the dryer is clogged, however, the internal protection devices, such as the Hi-Limit Thermostat and Internal Bias Thermostat will shut the heating element off prematurely to prevent the dryer from overheating, and to prevent damage to the heating element. Eventually, the Thermal Cut-Out (TCO) or Thermal Fuse will trip and the dryer will not run.or produce heat.
Nov 03, 2010 | Frigidaire GLEQ2152ES Electric Dryer
I have a newer but not brand new kenmore dryer. I have to run it twice to get a load dried. Serial number of dryer is ML4641775. Where is the heating element and how do I replace it?
Before assuming you have a problem with the appliance, check your installation to ensure you are providing the dryer with proper exhaust and air flow. This is the NUMBER ONE cause of poor drying efficiency. A dryer in a clogged state, or having improper air flow, will not dry efficiently and will cause the heating circuits to OVERHEAT. This will eventually will lead to component failures and is the source of many fire hazards.
Oct 08, 2010 | Dryers
My GE dryer has no heat but runs. Also when you put the setting on more dry or less dry the dryer will run for hours, but will run the correct time on the timed dry setting. Either way the dryer will not...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Oct 07, 2010 | GE DBXR463EDWW Electric Dryer
Dryer is not heating up to dry clothes
The spark ignitor maybe at fault. Listen for the clicking noise upon starting it up the first 30 seconds it runs. If not heard it is in need of a replacement
May 01, 2010 | Amana NED7200TW Electric Dryer
My dryer runs but does not heat up or dry clothes. What could be the problem?
I have a Kenmore dryer and it runs but won't heat up and dry the clothes. I don't hear the ignition even turn over. Please help. I can't afford to buy a new dryer at this time.
Feb 16, 2010 | Kenmore 62602 Electric Dryer
Dryer runs well but will not heat up and dry
You need to clean your dryer vent and make sure there are no obstructions.
Jan 02, 2010 | Whirlpool LGB6300 Gas Dryer
Electric Dryer Heating problem
Remove the rear vent and run a load on time dry for 45 minutes.
If it dries, repair your exhaust vent.
If not, replace your heating element.
Nov 18, 2008 | GE DBXR453EV Dryer
Kenmore 400 6942 Dryer Logo
89 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
