What sort of freq do you want ? How far out of band ? Programming of this type of radio is done via a RIB (radio interface box) box and PC with software. The radio is only designed to work within the frequency range stated on the set.
I cannot solve this problem if the shift key trick doesn't work but the www.batlabs.com site DOES still work and is a great resource.
Was this helpful?
Yes
No
Solution #3
posted on Aug 11, 2005
Pasty - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
Batlabs is back! and problem solved!
Was this helpful?
Yes
No
Solution #4
Joey2 - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
Hi Mike, unfortunately the batlabs site does not work any more, and the "out of band" procedure is diffrent between a 5-tone and a standard gp300, the shift key trick does not work on a 5-tone, it is a completely diffrent software, thanks anyway Ian
To program frequencies outside of the rated bandsplit in the GP300/P110/GP350 is very simple, follow the listed steps:
Hold the shift key down while entering the frequency you want You must release the shift key when you enter the decimal point You must fill the entire field-use zeros(while holding down shift) When you are done hit enter like normal and the frequency you entered will appear in regular decimal like any other frequency.
Was this helpful?
Yes
No
Popular Solutions for Motorola GP300 Compatible 2
Motorola GP300 Compatible 2 Way Radio Battery Eliminator
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
