Question about Tunturi Cycling
Mid workout, my recumbent bike started squeaking. Then it made made a clunking noise and got harder to pedal. It is an old one (mod 504E) that does not have the option of variable-difficulty workouts! I loosened the tension and it got better temporarily, but after more squeaking and clunking it got harder again and I smelled a friction/burning smell. Now it will hardly pedal -- but when I took off the cover the friction belt and spring look fine. Help!
3 Suggested Answers
  • 603 Answers
SOURCE: Scraping/Squeaking noise on recumbent stationary bicycle
There are most likely some sort of bearings inside the wheel hub that are causing this.
Posted on Jan 14, 2010
  • 456 Answers
SOURCE: My pedals are squeaking while pedaling on my
hi.
i cannot see any problems with wd40 on any bike and have used it myself for many years.
just wipe away any excess, and do not spray it on the pedal tops (where your shoes go) as they may get slippery.
light oil (3in1 or simillar) is also excellent on bikes instead of wd40. same advice as above.
i find wd40 works faster, especially on squeaks, but oil works for longer.
i usually use wd40 first to cure the imediate noise, and then use a few drops of the oil to keep it quiet for longer.
hope this helps
Posted on Apr 24, 2011
How do I stop the squeaking noise when pedaling the bike or using the elliptical option? I've tried lubrication. Only getting worse.
Have you lubricated all moving parts. Wheel bearings Chain and sprockets? Are there fenders if so are they a little loose?. Anything that is loose will vibrate and make a noise. Even dry pedals will make a noise. Crank also.Just a thought.
Dec 23, 2016 | Exercise & Fitness
If want my workout to concentrate on my abs, should I buy upright or recumbent exercise bikes?
Most defiantly recumbent bikes, the recumbent bikes concentrate the workout on the mid-section core muscles such as abs, Oblique and Core stabilizing muscles.
Aug 09, 2012 | Exercise & Fitness
What is an upright exercise bike?
The upright is a traditional looking bike and gives you the option to stand up on the pedals and really crank up the intensity of your workout. These bikes also work on many muscle areas that are not active while riding recumbent bikes.
Programmed workouts do not start
i just want a manuel for a champion 33t recumbert bike
May 26, 2012 | Stairmaster 3800RC Recumbent Exercise Bike
My pedals are squeaking while pedaling on my Schwinn 240 recumbent exercise bike, can I use WD40?
hi.
hope this helps
Apr 24, 2011 | Cycling
The bike goes to Pause mode frequently throughout the workout. I have tested all the exercise modes and made sure my RPMs stay the same but it just flips to pause and then starts working again...
Star Trac Pro Upright Bike Owner's Manual - ManualsLib
www.manualslib.com > ... > Exercise Bike > Pro Upright Bike
Exercise Bike Star Trac Upright Sport Bike Owner's Manual. Stationary sport bike (28 pages) ... Pro Upright Bike Pro Recumbent Bike ' W N E R A N U A L..
Jan 20, 2011 | Star Trac Sport Recumbent Exercise Bike
Jan 13, 2010 | Cycling
Proform XP110 R recumbent bike makes clanking noise.
I have the same problem with my XP 110. After taking the ENTIRE thing apart and independently testing every single moving mechanism, I found out that it wasn't the motor, pedals, armbars, or any internal mechanism. Instead, it was the front stabilizer foot that made the annoying noise. There is a plastic mechanism around the front stabilizer legs that holds the front wheels in place (for moving the elliptical). Whenever a rotation forward occurs, the plastic squeaks and the noise resonates to make it sound like the pedals or motor is squeaking. I am still trying to find a solution to fixing the feet, but may end up ordering a new set from the manufacturer. Good luck with your elliptical!
Mar 22, 2009 | Exercise & Fitness
Cycling Logo
73 people viewed this question
Top Tunturi Cycling Experts
Handyman
Tom Chichester
Are you a Tunturi Cycling Expert? Answer questions, earn points and help others
