LS-180 handheld x-factor karaoke microphone wont work on tv/dvd combi? Where do both sets of r, y & w wires go?
SOURCE: BUSH TV/DVD combi
connection between tv and dvd might be wrong or need to be checked
Posted on Dec 03, 2007
  • 416 Answers
SOURCE: tv/dvd combi - dvd read problems
No it is not worthy, you will spend around $100, but brand new combo 13'' cost $80 and DVD starts from $22. You can use an external one.
Posted on Dec 02, 2008
SOURCE: LS 3700 Leadsinger Microphone
We had the same problem just this weekend. However, we investigated it ourselves and discovered that you can take the microphone apart by unscrewing the two small screws inside the mic, under the music chips. Once the screws are out pry the two halves apart very carefully. Once we were inside, we discovered that the soundcard was loose and all we had to do is plug the sound card back in. Close 'er up and start up the show. Good Luck!
Posted on Dec 23, 2008
SOURCE: karaoke not working
Hi, got this info from philips customer service. Was desperately trying to get the karaoke function to work for 2 weeks! Plug in your microphone. Press "KARAOKE" button until you see "MIC OFF" text, and immediately press RIGHT button. It will now shows "MIC ON"! "ECHO", "KEY" options will now shows up when pressing "KARAOKE" button repeatedly. However, microphone sound will not be available on digital output, you'll have to use the audio RCA. Happy singing!
Posted on Sep 27, 2010
dunnbiker
  • 8546 Answers
SOURCE: (1) Is it possible to
1) Not with this unit. WHY bother? Sending identical program to two drivers over separate wires is the same as sending it over one pair.
2) No. Insertion of a microphone tells the unit you're doing setup. The microphone picks it up and sends it to a microprocessor for evaluation. The sound from the mic never finds its way out to a speaker. THAT would be a feedback loop and the tweeters wouldn't like it. (sizzle sizzle)
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Harman-Kardon-AVR-435-Receivers-manual/id/386bh037/t/2/
Posted on Apr 07, 2011
Ls-180 x factor karaoke mic
A lot of newer tv you'll have to change the input of the tv to receive the signal. Most should be labeled. If it's red and yellow connectors it will be a composite connection. Some tv companies require a signal to be present before they will switch or even show the different inputs
Apr 22, 2014 | Audio Players & Recorders
Tip
Set up, volume, and manual issues
I got my EAKAR100 for $5 at a second hand/thrift store. Kind of expected it would just work or not. 'Nuf said. But after having no luck with the set-up, I took a long second look. Here's what I discovered:
The manual is VERY minimal... if you don't have one, don't waste much time looking for one.
What I did wrong: The microphone has one wire that splits into TWO leads, each having 3 RCA plugs (Video & L/R Audio plugs... also a 3rd "pigtail" lead that is for an optional extra microphone for duets). Although the two main leads were clearly labeled, I had put the one for the TV input socket, into the DVD output (and of course the other lead was plugged in wrong, too). Oddly enough, this DID produce music AND lyrics from the DVD player; but I had no sound from me, singing into the mic. My excuse for this obvious error is the manual had a diagram for installation that showed the SHORTER of the two leads going to the TV. It doesn't. Luckily mine had blue tape labels on the leads. I switched them and though I continued to get music and lyrics, alas: still no microphone. (I tried new battery, and yes, the red "power" light lit up on the mic.)
Up until now, the music had been playing at a reasonable volume, but I then tried my mic w/o the music plugged in. As I began talking ever louder into the mic, I thought I could hear it on the TV, so I cranked up the TV volume from 11, up to 26; and suddenly the mic was delivering my vocals out the TV speakers. I would not have learned this w/o unpluging the DVD, because if I hadn't, I would never have cranked up the TV volume high enough to hear the mic.
The microphone's own volume control was minimal (almost imperceptible; low to high), but there were clearly 3 functional reverb-settings, controlled by the other button on the mic.
I re-attached the plugs at the DVD player and selected a tune. I had music, lyrics, and my voice, with some distortion depending on my volume, and the TV's, and distance from my mouth to the mic, but it was manageable.
However! the balance between the volume of my mic, and the music from the DVD was such that I was being drowned out by the music. I could find (via manual, online Electrohome website, my little brain's theories) NO way to adjust the BALANCE between these two sound sources.
As for the DVD menu, and song selection: The music arrangements are awful. VERY disco-style, even for the Christmas Carols!! The kids songs are bad too, but not as tacky. My DVD player is old, and teeny (the TV by the way, is a pretty new Vizio VL320L), and the DVD remote is very obscure in its button assignments and descriptions --- even with DVD movies. But maybe the Karaoke disc is awkward in itself, too. So, getting from the menu, to a particular song was haphazard at best. What worked best was pressing "Go To" on my DVD remote. That produced a header that read: "01/30 ... 1/1", which turned out to mean "song #1 of 30 songs; [and] folder #1 or 1 folders". By highlighting the song number field, using the left/right arrow buttons, and then entering a number "24/30" for example, and then pressing "OK" , the song would start up. My DVD's "pause" button worked, but many other buttons did nothing except cause a hand-icon (like the hand in a crosswalk light) to show I should "stop".
Sorry to be so long winded, but I don't know what small comment might be of help to any of you. I, myself, was groping through the dark all the way. Good luck.
on Mar 13, 2014 | Electrohome EAKAR100 All-in-One Handheld...
Karaoke not working
Dec 31, 2009 | Philips Televison & Video
Downloading
you could have downloaded a different format. try to read the manual of your karaoke, look what kind of format used, then download the same format.
Dec 26, 2008 | LeadSinger LS-3222 Consumer Microphone
Cable conexion is broken
I removed the cable from microphone circuit board  and shortened cable by 20 cm. to eliminate damaged wires, stripped the individual wires and soldered the pins to the new wire ends and reassembled.  Used black heat shrink tubing  [10mm dia.] to reinforce cable end at mic to prevent future damage from careless handling.
Document wire colours to pins before disassembly
Red                   Audio L
White                 Audio R
Blue                   DC Power
Shield [ground]     Ground
Yellow                 Video
Dec 13, 2008 | LeadSinger Wireless HiFi Remote Duet Mic...
Karaoke microphone and wireless mic
Cord rolling might generally cause damage to the internal wiring.the only possible repair option is change the wire inside.A suggestion is to try not to wrap the cord tightly with the microphone.fold it separately and use a band to hold it.
Dec 10, 2008 | LeadSinger LS-3222 Consumer Microphone
My pro silver wirless mic ro phone will not work wireless
* Make sure microphone is on * Check battery level, replace if necessary * Make sure the system is turned on, and appropriate audio levels are turned up * Check that audio "Mute" on the control system is not selected * Make sure microphone cord is securely plugged into belt pack * Check that the Mute switch on the microphone is set to "ON" and not "MUTE" goog luck!
Jan 07, 2006 | Matrix Pro Wireless Black Handheld Karaoke...
64 people viewed this question
 Grubhead
Grubhead
