Question about Maytag Atlantis MDE7400AY Electric Dryer
No heat is coming out of the dryer. - Maytag Atlantis MDE7400AY Electric Dryer
  • Maytag Master
  • 7,482 Answers
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Check the Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the thermostat/thermistor due to overheat.
Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape or with an ohm meter to test the thermostat/thermistor. (Should have/show continuity)
If the coil heats up then replace the thermostat/thermistor.
(Thermal fuse.If it overheats the dryer will not operate. It's located on the blower housing. It cannot be reset. A vent clogged with lint can cause it to overheat. You can test it with an Ohm meter or continuity checker, if no continuity, replace it)
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST.
This could cause a FIRE, as you have removed the safety of overheat from the machine.
Right after replacing a dryer element, always run the dryer on 'air fluff' / 'no heat', and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
For video and pictures on how to replace the element go to the following website:
davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
This is a FREE answer, Please rate me
Posted on Dec 29, 2010
My Maytag dryer, MDG4658AWW, will turn on heat for one cycle then heat never comes on again. Also, when using permanent cycle the heat cycle comes on once, dryer continues to run then shuts down (cooling...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Sep 25, 2011 | Dryers
Heat comes and goes, most of the time no heat but sometimes heat comes on
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
Check out this tip that will give more details…
Gas dryer not working gas dryer not heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
Check out this tip to see the things that can fail to cause your electric dryer not to work.
Dryer Troubleshooting Electric dryer wont heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Aug 21, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Heat comes on and heats the drum, then it shuts off but doesn't come back on.
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
heatman101
Aug 01, 2010 | Kenmore 400 6943 Dryer
Why won't my dryer heat up and dry clothes. The light comes on and the drum turns, but no heat comes from the dryer. It is a gas dryer and there is gas available. The settings are in the same cycles I've...
check out this electric no heat tip...
heatman101
Aug 01, 2010 | Whirlpool LGR7646E Dryer
Gas dryer -- heat doesn't come on.
heatman101
Jul 09, 2010 | KitchenAid KAWS700L Top Load Washer
No heat
Your dryer needs 208 - 220 volts for electric heat. If you have determined (in some way) that you have sufficient voltage coming to the dryer, then your issue may be a defective heat element, thermostat, timer, etc. Contact an appliance service company.
Apr 14, 2010 | Amana NED5200TQ Electric Dryer
Kenmore electric dryer heat stays on when door open
Sounds like your thermistor/thermostats could be your problem.
They control the heat coming from the heating coil.
Unplug the dryer.
If you remove the back of the dryer, look for the air tube coming from the blower to the drum, normally inside the air tube you will find the heating coil and the thermistor/thermostats. Replace as needed.
Good luck,
Hope this helps
Oct 05, 2009 | Kenmore Dryers
Maytag dryer does not heat.
If the dryer comes on but doesn't heat, it is probably the heating element. If the dryer doesn't come on at all, it most likely is the dryer's motor.
Sep 18, 2009 | Maytag Dryers
LG Gas dryer will not keep heating
sounds like the heat sensor on side of heater pan is bad and needs to be replaced ,,, its mounted on side of pan the flame blows into and has 2 wires plugged onto it / larry
Dec 12, 2008 | LG DLG5932W Gas Dryer
Dryer no heat coming out
No heat coming out of my dryer it spins and there is good source of power...
Jul 21, 2008 | Whirlpool LER5636P Electric Dryer
Maytag Atlantis MDE7400AY Electric Dryer Logo
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
