Question about SanDisk 4GB microSDHC Memory Card
My phone doesnt detect its memory card but when i connect it to pc ,, my pc detects memory card but my mobile does not???? Phone: videocon V1422
    Problem Solver:
  • 16 Answers
The problem is, that you type of phone can only handle a maximum of 2 gigs.
When you connect it to your PC it detects it, because the PC uses them (phone and sd), like two separate drives, and that's because when there is SD -> Phone -> USB cable -> PC, the uses the as a simple "cable".
So unfortunately you will have to buy a 2 gigs SD.
Posted on Dec 29, 2010
My micromax q5fb mobile cant detect memory card
Hi
Now use the simple trick to detect the memory card, because in china phone no safely remove option. so while remove the memory please switch off the mobile and while putting the memory card you have to again restart you phone otherwise it can't detect. try this trick may solve you problem.
God Luck
Sep 09, 2011 | Cell Phones
NOKIA 2700C MEMORY CARD NOT FORMMATED SHOW PC NOT DETECTED MEMORY CARD WHAT CAN I DO PL HELP
Use a card holder to connect the memory card to the PC and if this is not detected check it out on another PC. If not detected then the card is defective. If not you can right click and format the card after removing all the files from the card.
If the card is not detected it is damaged and you can try if there is a free replacement from the dealer.
Sep 05, 2011 | Nokia Classic 2700 Cell Phone
My phone cannot access the memorycard.
There are so many cases when people can't access the memory of the SD memory card.When you get connect with your system then it may need the driver to recognize the connected device.
The mobile phone comes with a driver or suit any thing which is associated with the mobile phone during purchase.You can install the driver and easily get access to your mobile phone and card memory both.
Some of the mobile phones are not being detected without the proper driver.Samsung D780 drivers
You can access the memory of your card using the provided cable which can solve the problem.Just plug the cable into your phone and another end should be plugged with computer.
Wait for a while if it is not coming quick as you want.If the device is not being detected the you can use the device manager utility of the windows system.
Move to the My computer icon >Properties >Hardware tab> Device manager> .
Check your connected device in the list of Universal Bus Controller and if not find then move to the Control panel and use the Add new hardware wizard.
Another solution is:
Using Card Reader to access the files:
The memory can be accessed with one of the different methods but for this procedure you need to have another device called Card reader which is associated with a cable.
The memory can be accessed with this procedure :
1- Pull out the SD memory from mobile phone.
2- Use the card reader,insert the SD memory and plug this cable to computer.
3- Try to look, if the device is showing in the windows then it alright and your mobile phone has some disturbance regarding detection.
4- Just make the desired operation and if that is not being performed then you have to format the driver,I don't think any options is rest to try.
Oct 11, 2010 | Samsung D780 Cellular Phone
Menory card
How to connect your memory card with PC. Here's what u do:
1.In your mobile, go to Menu, then Settings, then Phone settings.
2.Scroll down to Pc connections.
3.Select "Mass storage" option.
Next time you connect your mobile to the PC via the USB, open Samsung Studio. Samsung Studio will automatically detect your memory card and then you can start transferring files.
Another simpler method is when you connect the mobile via the USB, go to My Computer. Click on Removable Disk. Then it's just a matter of dragging and dropping files from there on.
Note: When connecting your mobile, make sure it is in Idle Mode (i mean in the main screen mode)
Hope this helps.
Thanks for using Fixya...
Aug 28, 2009 | Samsung Modem Configuration Software...
Cannot detect my 4gb memory card
First you should format your 4gb card with your phone software so that itll create the file system.
then your phone will detect the memory card
Aug 06, 2009 | T-Mobile MDA Compact Smartphone
Can't use this card with phone
adapter is used to connect memory stick to direct to your PC without any media like mobile or any other device. But through mobile you need USBcable of mobile to connect to computers or laptops. There is a new drive detected on your MY COMPUTER. Do the Copy Paste function to transfer the required files.
Apr 18, 2009 | SanDisk 2GB microSD Memory Card
Formatted memory card of nokia N72 not detecting in the phone
See if the phone detects a different memory card. If it doesn't detect any cards at all, try to reset/update the phone firmware.
If that doesn't work the card slot might be damaged, maybe dust and dirt?
Feb 04, 2009 | Nokia N72 Cellular Phone
My nokia 5700 not detecting the memory card.
Check if your memory card is corrupted or not. If its not then just restart your handset once.
Dec 31, 2008 | Nokia 5700 Cellular Phone
Problem detecting data
Best way to copy songs themes & other application,remove your memory card & put in memory card reader.No need of software required.
Jan 10, 2008 | Sony Ericsson Z550i Cellular Phone
SanDisk 4GB microSDHC Memory Card Logo
342 people viewed this question
Top SanDisk Computers & Internet Experts
Sandy Moore
Sandy Moore
Cleverer2
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
