York 90 furnace\r\n\r\nindicator light is blinking 7 times the code shows a lock out due to no ignition but the furnace is igniting do I need a new control board ? or is there a less expensive fix? oh I have removed the ignition sensor and sanded it, and replaced it with no sucess
    Novelist:
    Champion:
  • 224 Answers
I believe you may have sanded the thermocouple, the sensor is usually a flame sensor and it will be round and look like a button. These will get dirty and not see the flame, you can try cleaning it with a soft cloth and glass cleaner once you locate it. This piece sends signal to the board letting it know there is flame. It should have wires that head to the board and plug in.
Posted on Dec 29, 2010
Error code= two red flashes, lockout/ no flame
Trane XV80 hard lockout, 2 flashes, Can't be reset - DoItYourself ...
www.doityourself.com > ... > Gas and Oil Home Heating Furnaces
Jan 10, 2013 - The only way I can get diagnostic Red LED light to reset is to switch ... a2 flash with absolutely no operation from the furnace does seem to ..... inducer gets a demand you should get a pressure switch error code 3. ... the flame sensor wire and giving the furnace a heating demand after resetting power twice. Luxaire Furnace Blowing Cold - 8 Red LED Flashes
Mar 1, 2010
Winchester furnace diagnostics
Feb 14, 2010
American Standard Freedom 80 - Cold Air - Getting Error Code 9 ...
Nov 20, 2009
York ignition lockout due to retries
Dec 29, 2008
More results from www.doityourself.com
7 Tips and Tricks to repair your Furnace DIY - YouTube
? 13:25
https://www.youtube.com/watch?v=rAtcvPqUsBA
Dec 18, 2012 - Uploaded by JRESHOW .
cause this fault. 2 RED FLASHES: This indicates that thenormally open pressure ... The furnace will lock out for one hour and then restart. 7 RED FLASHES: This fault code indicates that the flame could not be established. This no-light ... problem. Bothheating and cooling operations will be affected. Check
Jan 23, 2016 | Heating & Cooling
Furnace blinks seven times lockout do to retries will light up for 5 second then it turn off
7 blinks means unit is locked out it will stay locked out for one hour then try to light again it will try two times before lock out. Possible causes. Low gas pressure, Faulty gas valve, Faulty hot surface ignition or burner problem may cause this. Most common is Hot surface igniter.
Nov 18, 2014 | Heating & Cooling
York furnace code 7
The error 7 shows that the gas failed to ignite. That is because the sensor does not sense any flame. This can be because the sensor is dirty. You should look in the area of the jets for a wire that may be purple in color. It attaches to a bare metal probe that is shaped like the letter L This probe extends into the path of the flame from the jets. When it detects flame it tellls the controller that everything is good. When it gets sooty or dirty from use it cannot detect the small electric currents that are present. Clean it with scotchbrite. Error 7 means that the furnace is locked out and wont restart for an hour. You can shut the power off and turn it back on to reset it.
Feb 26, 2014 | Tools & Hardware - Others
12 year old HE York diamond 90 furnace burners ignite for a few seconds but won't remain lit. Hot surface igniter then glows and burners again light momentarily. Cycle repeats several times before blo
The flame sensor can still be faulty, replacing that is the cheapest. Other issues could be a faulty control board (if available), a faulty gas valve, thermostat lossing call, or a safety/pressure switch problem. There are alot of variables and it really helps to have a meter to check voltage and continuity through-out the system.
Dec 07, 2013 | Heating & Cooling
York diamond 90 furnace burners won't ignite ... igniter glows for a few seconds then clicks off, no burner ignition. Tried resetting the furnace by powering off and then setting thermostat to call for...
The thermocouple could be defective. If this is a high efficiency York furnace, the stack blower should start and run first. If it doesn't the blower controller may have failed.
Dec 06, 2013 | Heating & Cooling
The furnace control on a York furnace is locking out due to unable to ignite flame
possibilities are many, no spark due to ng ignitor, if draft induced , fan not coing on or has blocked flue, if unit is condensing type might have condensate in drian line, if standing pilot type thermo couple bad so not sensing pilot. so you see not enough info of what type unit you have to help narrow down possibilities
Nov 12, 2013 | Heating & Cooling
Ruud achiever 90 plus furnace will not start with door on.
I would try to check your return air first, making sure there is no blockage and that your air filters are clean. It almost sounds like when you take the cover off, you are pulling enough air into the system for it to run, but as soon as you close it off, it's not getting enough air flow, therefore, tripping a limit switch inside the furnace. Most furnaces will also have the codes for the flashing lights and what they mean on the inside of the door covers.
Feb 02, 2010 | LG LW1200ER Air Conditioner
Coleman furnace wont fire
Check inside the door panel next to the wiring schematic, you should find the diagnostic codes. Look up 7 blinks. This should narrow down the problem. ( It sounds like a bad hot surface ignitor).
Good luck.....
Mar 31, 2009 | Coleman Propane Forced Air Heater...
Heating & Cooling Logo
237 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
