Question about Jacuzzi R100-959 Cetra 536 RH R100 Whirlpool Bath, White
The button on the jacuzzi 536 RH will not start the motor when pushed. The motor is tested to work however.
  • 1,772 Answers
Sorry to read about your problem, I hope this helps you out.
The unit uses a air switch, you should see a plastic tube going from the switch to the power switch.
remove the tube at the power switch end, and then push the switch, you should feel air, come out.
If you feel air, then you must have a defective power switch.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
Posted on Dec 29, 2010
Jacuzzi majic touch won't turn on
Air Switch Repair
It sounds like you have a bad air switch located in your motor.
The air switch is what the air hose connects to on the back of the motor or on the box on top of the motor. The other end of the air hose is connected to the air button on the lip of the tub.
This is a latching air switch and when you push the air button it latches to send power to the motor. When the air button is pushed again it opens the latch in the air switch and stops power going to the motor shutting it off.
US Parts Center
Nov 28, 2013 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
Jacuzzi Asteria will not turn off
How do you turn this on? If it is an air button that you push, it may well be the air switch in the motor is bad. The air switch is latching so when you push the button on the tub it closes the switch and lets the power go to the motor. When the button is pushed a 2nd time the switch will open and shut off the power going to the motor.
An air switch will cost about $21 to purchase.
Rod
US Parts Center
Aug 23, 2013 | Jacuzzi EH0 / EH1 / EG9 Fuzion 6666 Corner...
Tub will not come on
When you say it will not come on let me ask you what you do to turn it on?
Is this an air button you push or an electronic button or wall timer?
Rod
US Parts Center
888-521-6183
Mar 23, 2013 | Jacuzzi Cetra 536 Whirlpool Plus...
I have a Jacuzzi whirlpool bath model U640 Espree 536 and it wouldn't shut off. I cut the air line off at the pump and nbow it won't stay on for more than a few seconds. Any ideas?
I assume you hooked the hose back up to the air switch on the motor.
There will only be a couple of things to check.
Make sure you have a good connection with the air hose to the air switch on the motor. Sounds like maybe the air switch may be bad.
The Air Switch is a latching air switch so if is broken then it won't latch when the air button is pushed.
Rod
www.uspartscenter.com
Jan 23, 2013 | Jacuzzi Home
My jacuzzi motor is not working
When you push the button and the motor does not turn on there a couple of things to check.
Is there power to the pump? check the circuit breaker
If there is power to the motor then the air button on the top of the tub may be bad or it could be the air switch inside the motor.
Rod
US Parts Center
521-6183
Jan 11, 2013 | Jacuzzi Home
When I push the button on my american standard jacuzzi tub I hear the hum of the motor but jets don't come on
In my case I took the motor out and used a screw driver to turn the impeller in the front of the pump and the fins inthe back. Put it back together and it worked. I then used 2 tablesoons of dishwashing detergent and 1/2 cup bleach and ran it for 20 minutes to clean and degrease the impellers
Jun 30, 2012 | Jacuzzi Fuzion Whirlpool
Whirlpool Jacuzzi with 10 jets one stopped working.
either one of ur hoses has come off or is stopped up get to the sides and see if one has come off
Feb 24, 2010 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
Jacuzzi whirlpool, air on/off button on tub
If it is a air button that pushes in and comes back up, there is a good chance that the switch (which is mounted on the pump/motor) is bad. If the switch is a touch button on a key pad, the problem is in the control box for the pump/motor.
Sep 05, 2009 | Jacuzzi Signa Whirlpool Tub B540
The Jacuzzi isnt recieving power
yes it could, it might even be the motor, take the electric suply and unplug it see if you can turn the shaft on the motor if not it froze up,, sometimes the get wet and seize, the you have to get a new motor
Feb 27, 2009 | Jacuzzi Allusion 7242 RH Whirlpool HTR...
Jacuzzi R100-959 Cetra 536 RH R100 Whirlpool Bath, White Logo
243 people viewed this question
Top Jacuzzi Home Experts
Mike
john h
Donni Steen
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
