Question about Samsung Televison & Video
How do i connect my samsung dvd recorder sh853m to my free sat box? Also is it possible to record a channel from free sat onto my samsung recorder while also watching a different free sat channel.
    President:
  • 1,140 Answers
If it's a Standard-Definition (SD) FreeSat box then a SCART cable would be the normal method of connection to your DVD recorder. This would connect to the SCART/EXT OUT socket on the back of the FreeSat box and the SCART/EXT IN on the DVD recorder. However, this depends on whether your FreeSat box has multiple SCART outputs and whether you are using a SCART cable to connect to the TV.
If there is no spare SCART output socket on the FreeSat box, then you need to use an alternative connection which is common to both devices, i.e. co-axial, and make sure you are connecting from an OUT socket on the FreeSat box to an IN socket on the DVD recorder.
If you have a FreeSat HD box, then you need to connect it to the DVD recorder using an HDMI cable or another cable type that will carry an HD signal.
You will only be able to record from a different Satellite channel if you have a Dual LNB with 2 feeds to the FreeSat box. The LNB is the receiver that attaches to the arm on the satellite dish. You can determine whether you have a Dual LNB as you will have 2 cables from the Dish to the FreeSat box. They may be joined as one cable, but there will be 2 F-plugs (threaded co-axial plug) on each end.
If you don't have 2 cables then you will only be able to record the same channel as you are watching. To record another channel, you need a FreeSat box that supports this feature and each channel needs also a separate feed from the dish.
Hope this helps. If you need any further assistance please post back with the brand model number of your FreeSat box and details of the connections you are using between the FreeSat box, the TV and the DVD recorder.
Regards,
BElectric
Posted on Dec 29, 2010
How to get all freeview channels-all i get is the first 5 channels
Go to menu, find "autoprogram" setting and select it. It will scan all available channels
Aug 17, 2009 | Panasonic DMR-ES30VS DVD Recorder/VCR
Recording from Sky
you need to connect the satellite box directly to the VCR and record
Sep 09, 2008 | Televison & Video
Can't record from tv
u have a cable/sateliite connection...cable from wall to cable box in...cable box out to vcr/dvd in....vcr/dvd out to samsung lcd in....(vcd/dvd and samsung must be tune to ch 3) now u should be able to record all channel (note HBO, and some others like it may not allow dvd recording) vhs yes.
if this helpful feel free to rate
Jun 16, 2009 | Sylvania DV220SL8 DVD Player/VCR
Samsung HDD SH853M doesn't work
What type of cable are u using to connect the TV and player.
Check those first, and reconnect if in doubt and post back
Rifaa
Nov 17, 2008 | Samsung DVD-HR735 DVD Recorder/HDD...
Libary view for Samsung DVD SH853M
No, I'm afraid not - this player simply does not offer that feature. Amazon reviews are very negative about the product.
Nov 07, 2008 | Samsung Televison & Video
Dvd recorder hard drive DVDR5350H
This depends on how your video signals are delivered to the box, in most cases terrestrial TV signals received by ariel, cable are passed through the recorder, then to your TV, this means you can record 1 channel on the box and view another, it appears that this recorder only has 1 tuner so you cannot record 1 station and watch another on the output of this box.
with regard to freeview / satellite tuning, these are connected directly to the DVR and they only have 1 channel to view at a time, so unless you acquire a satellite / cable tuner which allows for dual channels or if you acquire a second cable/sattelite box from your provider it is not possible to record 1 channel and view annother
so this problem can be circumvented with other products, but the expense may be more than you expected, as most cable / sattelite provders will charge to provide a second box. also you will also have to be aware of interfeerance with remotes if 2 sat boxes are used. as the remotes are likly to be similar.
Oct 03, 2008 | Televison & Video
Samsung DVD SH853M Freeview/HDD/DVR. Recorded list - cannot access
The Manual fro this machine is typically vague on the minutae of setting up and performing various functions.
Apparantly the 'standby button' on the handset should be in the 'off' position not the 'on'.
The logic of the layman can seee it as the opposite. This does work..... and thank you for your patience.
Mar 18, 2008 | Samsung Televison & Video
Cable hookup and av hookup
Connect your TV to AV1 and you SAT/Cable Decoder to AV2.
on the video select the AV2 channel and it will record whatever is connected to AV2. The AV channel selected it is the input the one not selected is the output.
Some PPV Movie channels are copy protected with some service providers. But most channels are recordable.
The aerial lead coming in your house connects to the SAT/Cable Decoder 1st, then connect the output socket on that to the Video/DVD then the output on that to the TV. As long as the leads you use have different ends on you CANNOT plug them into the wrong socket. As the the aerial passes through each device, the device adds its own RF channel to the feed, so you should be able to tune both a SAT/Cable and a Video/DVD channel onto the TV set aside from using AV/Scart.
Dec 27, 2007 | Panasonic DMR-EZ47V DVD Recorder/VCR
Durabrand dvd/video combi
There could be at least two ways to hook in your VCR. The common way is to hook your VCR inline (between) the sat box output (RF or antenna) and the TV RF/antenna input. This will allow you to play the VCR/DVD & record whatever channel the sat box is set to. I'm not real familiar with the newer sat boxes, but I assume they output one channel at a time, thus, you can only record that channel. On the older cable or outdoor antenna systems, you could record one channel while watching another. Perhaps some sat boxes have this capability. You might do a Google search with the box Model number to see if an online manual can be found. The other hookup possibility is if your TV set has audio/video inputs & outputs. Hook these to the matching input/output of the VCR/DVD.
Sep 30, 2007 | Televison & Video
Televison & Video Logo
339 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
