Connection on back of laptop for power broken
Hi there , i have a major problem with the power connection for the mains adapter on the back of my samsung v25 laptop,i have taken it apart and it is broken ,i have no idea were to get 1 from and a part number for this item, can u tell me were i can get a drawing from so i can identify it on the drawing , please can u help me as samsung can not help me at the moment
  • ashiq_s Feb 28, 2009
    the power connector on the motherboard has broken and having trouble finding spare part . the power adapter is fine ..... batterys flat now ay using system again till i get a solution. seen one of the tips . how would i know the polarity of adapter ?
    Problem Solver:
  • 7 Answers
Hi, Simply can't get these things..
go to jaycar or any electronics bit retailer and get a female plug suitable for your AC adapter and attach/solder it to the mainboard with a 2 - 3 inch long cable or longer (2 wires). polarity is very important - can't afford to make a mistake.
Leave that female adapter loose & flexible at the back of your notebook, that way you won't break it again.
You are not he only one, Stats = 20% of notebooks die this way.
I am a techy and I see then every day..
I have done many of them, this way..
Hope you can do it too.
Posted on Jul 08, 2008
My laptop is not switching it just lights up the battery led when i put in the adapter.and it produces some sound where you connect the adapter
Remove main battery and try again, if no! sub out the ram memory one at a time and test each, if nothing! remove the hard drive and power up, remove CD/DVD drive and finally the wireless card, if none of these work! the motherboard has major issues.
Apr 22, 2012 | Computers & Internet
Hi my x58 won't start up, the light on the power adaptor just flashes when I connect the laptop to the power mains, please help
Hello.
The most common reasons for power issues are the battery, power jack and power adapter/cord.
Power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.
If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.
The power jack is inside the laptop and either needs soldering or replacement. If a power jack problem, it should be addressed by someone knowledgeable.
If no change, the power adapter is probably faulty and needs replacement.
Hope this helps.
Aug 13, 2011 | Computers & Internet
Hi i need help plz, i've my laptop do not power when i plug the ac adapter ther' is no ligth
You may have a DC connector problem:
Symptoms of a broken power jack
1. If you wiggle the power cord or the AC Adapter connector on the back of the laptop, the power LED and battery charge LED start to flicker.
2. Battery will not charge in the laptop.
3. Laptop runs fine off a charged battery.
4. With the AC Adapter connected the laptop appears to be dead.
No power LED or battery charge LED activity.
5. Laptop randomly powers off without any warning.
If your laptop is out of warranty, then you can fix the problem by re-soldering DC-IN jack on the system board. If it
May 23, 2011 | Dell Inspiron 2200 Notebook
My advent battery would not charge so i bought a new one and it still wont charge having to run my laptop from the mains
Mar 12, 2011 | Advent Netbook
Acer 2480 2247 won't power up -no lights no nothing, pwr supply is not the problem,lid close switch isn't stuck ,pwr. on switch seems fine and power supply jack on motherboard is not broken
Remove the main battery and the power supply, allow several minutes to get rid of any residual charge, now plug the power supply adapter back in and press power "leave battery out" is there any change? if not! remove power supply, now! press and hold power for 60 seconds to reset the laptop. Next install main battery back in and the power supply adapter, power up! if no change, the motherboard is the problem.
Mar 07, 2011 | Acer TravelMate 2480-2779 Notebook
Will not power up
FirewallAvat: Your problem is likely because your battery is dead and the adapter isn't charging it. This may be due to broken connections in the cable from the adapter. Flexing often causes the wire inside to break near the plug. Generic replacement adapters are available, or the wire can be cut back a bit and a suitable replacement soldered on. The cause might also be broken solder connections on the main board at the power jack, This is common from stress due to the power plug flexing. It is usually possible to open the computer and resolder these connections, although sometimes there's too much damage from arcing before the connection fails entirely.
DocBrown: Does the power LED on your computer come on when you connect the adapter? If not, try the adapter in another outlet anyway. Sometimes one outlet in a strip can go bad. Check the output of the adapter with a voltmeter. If it's bad, replace it or try repairing it as noted above. If the adapter is good but the light isn't on, you might have the bad power jack as well.
Nov 08, 2008 | Compaq Presario M2000 Notebook
Overheating and ac adapter disconnection
try to open laptop and clean the dust off the fan
Jul 18, 2008 | Sony VAIO PCG-K35 Notebook
ZE2000 No power issue
Check on the motherboard if there is a fuse. It may look like a diode or resistor.
Does it work on battery, if you have a charged one?
Jul 14, 2008 | HP Pavilion ze2000 Notebook
No power
Better to connect another AC adapter and check it.If ur laptop have Warranty then please take it from nearest Service centre.
Thanks,
Feb 12, 2008 | Tatung (TWNB12N01) PC Notebook
Computers & Internet Logo
David Payne
David Payne
