Question about York Barbell Home Use Fold-Up Treadmill
My kettler treadmill M9778 is showing err:7 when i turn it on and then it trips the fuses
  • 3 Answers
SOURCE: Message in the display "err 2" and my kettler treadmill doesn't work
Hi Rendra,
Try this:
Switch the treadmill off and then on again.
Push the "minus" speed button and the "stop" button simultanuously.
If all is well you will now have entered the maintenance mode.
Next push the "plus" speed button and the "stop"button smultanuously.
Now you you've reached the error mode.
Push the "plus" or "minus" speed button to browse the error codes untill you've reached "L er".
The push start to erase the message.
Turn the power off and then on again to restart the treadmill.
With any luck the error has disappeared and the treadmill will function again. If not.....you'll have to contact Kettler.
Btw...This error occurs when the belt is "pushed" by the runner. For example when you put weight on the handlebar and the push your feet backwards.
Posted on Aug 30, 2009
maxtreadmill
  • 832 Answers
SOURCE: Err 22 keeps displaying on control panel
Error 22 indicates that the drive motor (running belt) has been instructed to start, by either manual or program control, and the monitoring system has not received any response from the speed sensing system indicating that the drive motor has started
Possible Causes 1. The treadmill utilizes an optical (infrared) speed sensor and the line of sight between the speed sensor and the speed sensor target is obstructed. 2. Drive motor brushes are bad. 3. The speed sensor position relative to the speed sensor target is incorrect. 4. The speed sensor potentiometer adjustment is incorrect (when equipped). 5. The speed sensor is inoperative. 6. The lower PCA is bad. 7. The lower PCA to upper PCA interconnect cable is bad. 8. The upper PCA is bad
Error 45 :The lift control system has detected that the lift is moving in the opposite direction of the issued
Possible Causes 1. Lift Motor hysteresis. 2. Bad lower PCA
Possible Remedies 1. This error would typically happen when the lift was already in motion (typically downward) when a lift command in the opposite direction (lift up) was issued. Some motors exhibited a very long turn around time and the lift motor would still be moving in the original direction (downward) while the control system was attempting to move the lift in the opposite direction. If the error 45 condition is persistent, replace the lift motor. 2. This is a very rare condition, if the lift moves in the opposite direction of the issued lift command, replace the lower PCA lift command.
Posted on Mar 02, 2010
maxtreadmill
  • 832 Answers
SOURCE: where is the circuit breaker or fuse message err 1
That error code mean you motor is not getting the correct signal to operate the drive motor. You will need unplug unit then take the motor shroud off visually inspect all connectors then make sure all of them are seating solid in their connectors. then plug the unit in check an see if the L E Ds have lit on lower electronics board then get on unit and with your foot proceed to move the belt while doing that hit your start button and see if that error code come up. At this point we are checking the speed sensor to see if it is functional. Now if your upper console is registering its showing speed and time moving forward this also tells us that the communication between the two boards are fine. Now stop this process and you should have the error 1 show on the console. If you have a multi meter handy find the two leads coming form the motor going to the board unplug them put the two leads into the connector switch the meter to dcv 100v range and proceed to move the belt in the previous now the motor has become a generator and if function you should be getting a dcv output if not the it telling either worn motor brushes or open winding in the motor now if you get a reading then that lower board is defective. Then call York and get pricing on the defective part.
Posted on Apr 11, 2010
  • 218 Answers
SOURCE: new balance 2500 treadmill shows e1 code and keeps
The motor controller weakens over time because of the excessive amperage draw of the motor do to lack of lubrication (which wears the walk belt and walking deck).
Take an amperage reading of the motor it should be 2-3 amps with no one on it, with someone walking on it it should be around 6-12 amps. I would bet yours is elevated above 6-12 amps.The controller is dropping output because of the friction problem.
The first thing to try after testing the amperage is to lubricate the walking platform. Then retest and see if the amperage comes down and it doesn't shut off.
If it does then the next step would be to replace the walking deck. If the amperage still is up you may need to replace the walk belt second and finally if after replacing the deck and belt, if the unit is still shutting down replace the motor controller.
Posted on Aug 14, 2010
SOURCE: What does Err 7 mean on the Fitnex t30 treadmill?
For the Fitnex T30 treadmill, the error 7 (listed err7 on the display) code means that there is a fault with the incline motor. My problem was the incline motor had burned out probably from usage, and during my research, this seems to be a weakness for the T30 model. You can remove the front plastic cover, unscrewing the 4 phillips head screws to reveal the electronics board, belt motor, and incline motor. With the power on (do not touch the board or wires 'cuz you could be electrocuted) check the board located next to the power switch. If the board's two lights are lit green, then your incline motor has probably ceased to live. Just in case, make sure to check with a flashlight, all those capacitors. One of them could have blown out and I'm not sure whether the green lights would indicate that. If one is blown the cylinder end will be bulged as if the cylinder 'popped'. You can see that the cylinders are stamped with a plus-sign. This is a built-in weakspot to allow an 'explosion' to puff out that plus-sign stamp. It will be fairly obvious if one has kaboomed. Make sure the wires are intact as well. Use a dustsprayer to blast all the grime and dust off the board and wires and motors. If all looks good, it's probably your incline motor itself that has gone kaput. Now let's get that motor out! Turn off the power and remove the power pIug from the outlet! First, I removed the grounding screw (green wire), unplugged the 4 prong main switch and 3 prong secondary switch from the motherboard that connect to the incline motor. [Just a footnote, inspect the connections of those wires into the incline motor just to be sure. If all is well, continue motor removal]. Next, use wrenches to remove the top nut and bolt securing the incline motor. Then, gently tip the entire treadmill on its side and do the same to remove the nut and bolt from the incline bar across the bottom of the treadmill. Now flip the treadmill rightside up. Remove the incline motor. I ordered the same motor, used and rebuilt, from sbarker (Ebay id), sbarker10 (Amazon id) for $54, shipping included. You're not going to get a better deal than that. A new replacement motor from a exercise equipment store online wanted $200 which is just not worth it. From order to arrival, took 4 days. Follow the same procedure in reverse order to install your new motor. Everything should work fine. If you're still getting the error than there must be a wiring issue between your board and the incline motor, or the board itself is faulty, but then that's beyond my knowledge of this particular problem. Don't worry though, with what I've found, the incline motors are poo-built, so if you're getting this error in the first place, I'd bet the farm it's a burnt incline motor. Good luck
Posted on Jul 28, 2011
My Kettler running machine keeps cutting out. Have lubricated the running belt but problem persists
Could be several things going on. I'm not familiar with your brand of treadmill, so I don't know how powerful the motor or how durable it is. Could be that it can't handle the load anymore. I had a cheap treadmill that would trip the breaker switch on me often after about 5-10 minutes of use. I needed to up the switch amp to get it to work, but that means your house wiring for your switch needs to conform to that load as well. Messing with electricity was not going to happen for me. I ended up getting a new treadmill. Try plugging in your treadmill in a different outlet that may have a fuse or breaker with a higher amp, like a 20 amp or so, and see if the problem persists. If your machine is more than 5 years old, it's motor is probably worn out. Of course, you could always dress warmer and just run outside. ;)
Jan 24, 2015 | Kettler Race Indoor Training Bike
I have kettler pacer treadmill it is not getting start,when I press start button the display shows system fault and also shows error dc6
Motor controller...these are typically motors that have speed controllers. When they fail, just test and replace. Call the manufacturer for parts.
Nov 25, 2014 | Kettler treadmill Pacer
Treadmill KETTLER PACER error code E7, what I have to do?
see the next steps and fix it. God bless you
ERROR CODE # 7
E7- 1) Alternative Elevation Motor
1)Cause: Elevation Motor not moving Solution:Check Elevation Motor connection
2)Cause: Elevation Elevation Motor screw binding Solution: Clean screw and lubricate
3)Cause: Elevation Motor Motor out of Range Solution: Check motor out of elevation
4)Cause: E-Motor Potentiometer: Solution: Replace Elevation Motor
2)Alternative:
Display Doesn't Light Up: a)Cause: On/Off switch Solution: Test unit is turned on b)Cause: Insufficient Power Source Solution: Plug dedicated120V, 20Amp Outlet
c) Cause: Line Cord Damaged Solution: Replace Line Cord
d)Cause: Fuse Solution: Check Fuse on MCB
Nov 28, 2012 | Kettler treadmill Pacer
Treadmill KETTLER PACER have error E7 when starting run. How to eliminate it?
see the following indications and fix it. God bless you
ERROR CODE # 7
2)Alternative:
TX3 folding treadmill. switch on says ERR how to fix is the question>
This is probably a 1) faulty speed sensor or
2)the speed sensor is not plugged in properly.
3)Its also possibly a faulty motor control board or
4) lower board. T
he error codes will differ between makes and models but could be e1.
However if you send the complete information, if can not fix you treadmill, how model, mark, serial number, I can handle more specific.
sincerely.
E.CUADRA
MANAGUA, NICARAGUA. C.A
Nov 16, 2011 | Kettler TX3 Folding Treadmill
ERR on the treadmill when I switch on. how do I fix and get working
Any other codes displayed? Safety key fit firmly in? Go to the front of the treadmill turn off the power switch off and unplugg the unit for at least 30 seconds then plug in the unit turn power switch back on. If this does not clear the error code your unit will most likely need to be serviced.
Kettler Treadmill TX 3 gives error 91 supplier told it was the Power supply print. We changed it including the motor and the problem was solved for a couple of weeks. Now it is back again? Please...
Problem with Trendmil TX-3 err-91 problem is solved ... speed sensor (photo transistro in photo cell is damaged).The palsis in colector is 5V Amplitud .
Apr 05, 2011 | Kettler TX3 Folding Treadmill
When I turn on the treadmill, I get the "Err 7"
hi,
check the speed sensor near the motor pulley. if the sensor is open this problem can occur.
ok
Feb 06, 2011 | Endurance T3 Treadmill
Hi Rendra,
Try this:
May 10, 2009 | Exercise & Fitness
York Barbell  Home Use Fold-Up Treadmill Logo
195 people viewed this question
Top York Exercise & Fitness Experts
Mikee
richie46
Are you a York Exercise and Fitnes Expert? Answer questions, earn points and help others
