Question about GE GDS20SBS Stainless Steel Bottom Freezer Refrigerator
GE Refrigerator forms and Ice dam which stops the evaporator fan from turning.
I have a GE bottom mount refrigerator which keeps forming ice in the drain pipe. The ice freezes the evaporator fan blades and keeps it from turning. I have replaced the fan motor once already thinking that the motor had just blown out only to find out that the water doesn't drain after the defrost cycle. The pipe is clear. I suspect that the defrost cycle is not running long enough.
  • Anonymous Mar 17, 2014
    sce 170 - water just runs over the curtain, if you hit the manula harvest the evaporator works but no ice is formed
  • Anonymous Mar 22, 2014
    how do you replace the evaporator fan motor
    Scholar:
  • 148 Answers
Is it defrosting theres a glass tube which is the defroster bar,there known to have these fail
Posted on Jul 07, 2008
  • derek martin Jul 09, 2008
    sorry I answer so manty of these a day on fixya that I sometimes miss something ,so the fridge is defrosting,and the drain plug is clear ,then its the bi-metal switch,or some call it defrosting switch its about 1 inch thick about the size of a quarter and its clamped on the cooling coils in the freezer,it will have 2 wires coming out of it usally pink and brown,just unclip and replace it cost about 12 dollars,if you still have problems youl have to replace the defrost timer which is about 60 dollars but I would try the bi-metal its a common problem
ICE FORMS IN FREEZER BOTTOM,
Keep the bottom of your freezer free from ice. ... The water from the melted ice and frost drains through a short tube and into a pan beneath the refrigerator, where it evaporates. Should the drain line become clogged, the water has nowhere to go and it freezes, forming a layer of ice in the bottom of your freezer.
How to Fix an Iced Freezer Bottom ' Home Guides ' SF Gate
homeguides.sfgate.com/fix-iced-freezer-bottom-42777.html ICE FORMS IN FREEZER BOTTOM Google Search
Oct 23, 2017 | Refrigerators
Samsung refrigerator is freezing up on back panel of refrigerator . Will defrosting the whole unit do any good? The unit is 2 years old
well yes and no , defrosting it will temporally make it work , but main problem is there isn't proper air flow over evaporator coils id clean them with soap and water while defrosting out unit , if low airflow is allowed to continue then refrigerant gas will build to high press and escape and render unit a total replacement
Sep 29, 2016 | Samsung RB215ACBP 20.0 cu. ft. Bottom...
Freezer forming ice stalagtite under ice tray
Sounds like the ice maker is allowing too much water in to the tray. There is an adjustment screw under the front cover of the ice maker. A 1/8 turn at a time counter clockwise will shorten the time the water delivery solenoid is open. It is possible that something foreign is keeping the solenoid valve to stay open too long, so it should be inspected too.
Jul 28, 2017 | GE Profile PSS26PSTSS Stainless Steel...
A sheet of ice has formed on the bottom of the freezer. Why.
There is a drain port in the behind the freezer panel where all of the water drains when your evaporator coils defrost. It has gotten clogged with food, or ice. Thaw all of the ice and unplug the drain hole, and ice will stop forming on the bottom of your freezer.
Jan 30, 2011 | Whirlpool 24.8 Cu. Ft. Side-by-Side...
Ice forming around fan
You have a problem with the defrost circuit of your refrigerator. The parts of this circuit include the defrost timer/module, heater and thermostat. The function of the defrost circuit is to periodically stop the compressor and fan and turn on a heater mounted on the evaporator coil to melt any frost buildup. The fact that ice is building up and even stopping the fan indicates that the defrost circuit has failed for a while and the temperature in the refrigerator compartment is probally higher than it should.
Typical failures with the defrost are the timer/module and heater. Can't tell if you have a timer or module since you did not supply a model number. You can verify if the heater is bad if you have a meter. You will need to unplug the refrigerator and remove the panel in the freezer and use a hair dryer to melt the ice from the coil. Once the heater is exposed, a meter will be able to determine if the heater has failed.
If you are not able to troubleshoot the problem, recommend that you call a service company. Hope this helps you.
Jul 23, 2010 | Kenmore Refrigerators
Temp is rising and fridge is making noise
the problem lies with your evaporator fan motor, ice is forming underneath the fan blade, and as one customer told me, it sounds like a helicopter. when this fan stops altogether, no air flow to fresh food section is a result.
the cause could be the fan motor itself is bad, or if there is ice underneath the fan blade, the defrost drain is clogged with ice. after clearing the drain, i would highly suggest putting a defrost drain heater, to prevent ice build up in drain,, from obstructing fan blade. You can reply here or send me a question from my website: www.FixMyFridge.net
Mar 15, 2010 | GE Profile PDS20SFS Bottom Freezer...
Ice melting and frost forming on freezer side, funny sound coming from freezer side. No condensation in back of fridge. Help for a new home owner.
check that your flapper on the ice shut through the freezer door is fully closed,
make sure there is no ice forming around your evaporator fan, thats the fan in the freezer, if that gets glogged with ice and is forced to stop, it could blow your entire machine control......
the frost in the freezer leads me to believe you may have a defrost issue
Oct 14, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice forming at bottom of freezer
You are very bad. Of course the drain does something. Pour hot water over the ice. Use a sponge to pick up the water when it is not hot and do it again until the drain is clear. I use a Mr. Coffee as a quick source of very hot water.
Apr 27, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Monogram refrigerator/freezer problem/ice dam in ice maker
I have had the same problem with ice forming. I found the problem is from the ice maker. The water fill tube delivers water to a plastic piece that acts like a funnel. The water goes through this plastic piece into the ice maker. Ice forms in the plastic funnel piece causing the water to overflow into the ice bin and freezer.
Mar 26, 2009 | Refrigerators
Open Questions:
GE GDS20SBS Stainless Steel Bottom Freezer Refrigerator Logo
246 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
