Question about Multitech Systems OTC Genisys MultiTech 56K Pc. MCIA Modem Kit (WEOTC342107)
My otc genesys wont turn on. who can repair it?
Whats my otc ballance
https://www.archcare.org/health-plans/archcare-advantage/your-benefits/over-counter-otc-card
You can call the phone number or go to the web site shown.
CHECK YOUR BALANCE You can check the balance on your OTC card at any time by:
  • calling 1?888?682?2400. You will be asked to enter your OTC card number.
  • or by visiting www.otcmember.com. Once on the site, you will be asked to enter your OTC card number.
  • or by calling Member Services at 1?800?373?3177 (TTY/TDD: 1?800?662?1220), seven days a week from 8:00 A.M. to 8:00 P.M.
Mar 24, 2018 | OTC Computers & Internet
Sega genesis wont start up
I had had a problem with my old Sega Genesis console the red light would not turn on even though I had turned the power on after a few se the voltage regulator got very hot really fast you could have a similar issue like I had for this if it is stone cold then it is dead. Try another ac adapter too see if it works if it does work then the ac adapter was bad. If there is no power light being on and it gets really hot really fast then it could be the capacitors that are causing it not to work or the voltage regulator is not working right. So you could buy a new one then.
Dec 23, 2013 | Sega Genesis Console
My otc genisys scanner wont turn on ,even when plugged into car or with power plug
I took my smart cable off and it was fine after that. try taking cable off then turn on make sure your battery is good
Sep 15, 2011 | Computers & Internet
Wont come on
Man I haven't seen an actual Sega Genesis console in years. Anyways...
1) Make sure that everything is plugged into your system properly. 2) Check you make sure your TV is on the right channel 3) Check to make sure the fan is at least powering up when you turn on the Genesis. If it is then the Genesis is working. 4) Plug something else into the TV to make sure it works.
Remember, HDTVs and LCDs and this whole Al Gore's Gone Green thing wasn't around when they made the Sega Genesis, so conventional means to playing a Sega aren't your best option. Don't plug it into the wall either, make sure you are plugging it into a surge protector.
Hope this helps.
Jan 01, 2011 | Sega Genesis Console
Why my sega gen mobile wont turn on?
The Sega Genesis 2 Console requires Game Cartridges. The console is only a processor and has no pre-loaded games.
Apr 30, 2010 | Sega Genesis 2 Console
My abs lights are on and and the traction control lights keep flashing from time to time. why wont my otc scanner pick up any codes?
Are you using an ABS card? I have a Mac scanner by OTC and I have to use a separate pathfinder ABS card.
Feb 19, 2010 | 1998 Plymouth Voyager
My Sega turns on but it wont show a picture
Well it depends on the type of cable you got... if you got those red, white, yellow cables :) and it doesn't work try wiggling the cable in back of your genesis (common problem among most MAJORLY with the old style adapter) or chances are your cables broken or you have a shot av output
Apr 30, 2009 | Sega Genesis Console
Multitech Systems OTC Genisys MultiTech 56K Pc. MCIA Modem Kit (WEOTC342107) Logo
369 people viewed this question
Top Multitech Systems Computers & Internet Experts
Vladimir Frolov
Larry Fostano
Larry Fostano
Karen Gibson
Level 1 Expert
Are you a Multitech Systems Computer and Internet Expert? Answer questions, earn points and help others
