I have a brand new york inverter air conditioner that does not want to cool!
  • 2,133 Answers
To get proper cold air set temp 23 degree and mode"cool". To get heat set temp 30 degree and mode in "Heat"
Now symbols:
1. fan leaves - Fan only
2. Rain drop- Dry mode
3. Snow flake-Cool mode
4. Sun- Heat
5. A or AU- Auto mode. First, check your compressor is working?
Posted on Dec 30, 2010
Have a Silverstorm split aircondtioner lost remote cant get cooling in summer periods.
split air cons come in both configurations and are mostly in the last few years with inverter systems
you can get cooling only or cooling and heating systems
some brands only have the cooling only on the smaller units ( 8000 btu units)
Sep 09, 2016 | Heating & Cooling
York everest inverter. What is meaning for po warning?
PO is phase overload. You are hooking something up to it that takes too much current.
Jan 29, 2016 | Heating & Cooling
York was working normally. Why is it now indicating code p4?
http://errorcodeairconditioning.blogspot.com/2010/10/york-error-code.html?m=1
This is a link. If you "Find in page P4" it shows a compressor inverter failure. Assuming this is your unit. Need a model and serial #?
May 27, 2015 | Heating & Cooling
What does error P1 means in pioneer heat pump
It means the power is off or went off to unit . Check for power then power cycle unit to try and restart .
Nov 14, 2014 | Pioneer Ductless Mini Split INVERTER Air...
York Air Conditioner unit doesn't turn on
jumper red to yellow on thermostat if it kicks on problem is in the thermostat.
Apr 22, 2012 | Heating & Cooling
Air conditioner does not cool
Well, letting things sit that long isn't good for them. It probably lost it's charge of freon.No way to fix that.
May 04, 2010 | Coleman Mach 15 Air Conditioner
Cold air not coming out. I JUST bought this the other day and it worked the first day just fine but now it will work fine for about 10 minutes and then the cold air will stop coming out. Air will continue...
Need to return this one where you got it. Sounds like compreesor or control problem. Do check outlet voltage to make sure it is not a low voltage problem first. Voltage should not drop below 10% of name plate voltage required. Voltage should be checked with unit running and cooling to see true voltage.
Jun 29, 2009 | Haier ESA306 Air Conditioner
My room is not getting cool. the air conditioner is brand new, out of the box, perfectly clean
It sounds like your air conditioner isn't big enough to cool the room you have it in. SInce it is brand new return it and get a larger one. Tell the store clerk the dimensions of your room and err on the side of bigger as opposed to smaller that the dimensions call for.
Jun 26, 2009 | Heating & Cooling
New split system blows only hot air
Assuming it is brand new, are you certain that the compressor does not run at all or is it simply not pumping? Even being new, it is possible that the main compressor capacitor is faulty, this is on the top of the outdoor unit, replace and check.
Jan 29, 2009 | Heating & Cooling
Heating & Cooling Logo
154 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
