Question about Samsung SCX 4521F All-In-One Laser Printer
Buen dia. Tengo la impresora Samsung SCX-4521F, realiza todo bien, solo que hace un sonido como un chillido al imprimir o sacar copias. Ademas se calienta demasiado al final del dia y el cartucho se esta gastando mas rapido que antes. Que puedo hacer para solucionar estos problemas
4 Suggested Answers
pineworks
  • 4041 Answers
SOURCE: no permite imprimir
Hi you could try I found this I know your error not in here but it may work for It worth a try nothing to lose and it may work. I know your error code is not in this but it some times it clean the error with this type of error number you can gave it a go try not harm it Error code: 0xc18a0201, 0xc18a0206, 0xc18a0306, 0xc18a030a, 0xd0620130, 0x887dd03a, 0xd05d010d, 0xf0af8004, 0xc19ac3ff, 0xc18a050...
Reset the product:
1. Without turning off the product, disconnect the USB cable from the rear of the product.
2. Remove the cartridges from the product.
3. Wait for the 'Insert Cartridges ' message to display on the control panel.
4. Disconnect the power cord from the back of the product.
5. Wait 60 seconds.
6. Reconnect the power cord. If the product does not automatically turn on, press the Power button ( ).
7. Reinsert the cartridges, and then close any open doors on the product.
8. If you receive a prompt to print a calibration page, do so.
9. Reconnect the USB cable to the rear of the product, and then try printing again.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 08, 2010
  • 555 Answers
SOURCE: APARECE EL CODIGO C6020 Y
El codigo C6020 significa que hubo sobrecalentamiento en el Fuser. Si Ud. es tecnico en copiadoras, cheque la resistencia del THMS, ien caso de ser 0 ohms, reemplace. De otro modo, puede que la fuente de poder esté dañada. despues de hacer reemplazo de piezas, resetee la copiadora con el codigo U163.
En caso de no tener idea de que estoy hablando, le recomiendo solicitar servicio tecnico para la computadora ya que es un problema serio en el equipo.
Posted on Dec 07, 2010
  • 525 Answers
SOURCE: buen dia, el problema que
the scanner matrix is burned out, replace the matrix
Posted on Jan 22, 2011
Tengo un p9000t pero al iniciaqr DVD, TV o simplemente encenderlo aparesce una imagen que dice warning pleasa stop wacht video player en momentos trasmite el canal y el video pero posterior presenta...
Hola buen dia, mira tengo un stereo con pantalla marca planet audio, modelo P9762T. El probleme es que no funciona el touch y el control igual se descompuso, y no encuentro ni el control ni kien me lo arregle del toach, ayuda x favor saben kien lo puede arreglar y en cuanto saldria o ya de minimo el control. Gracias de antemano y saludos
Jul 02, 2011 | Planet Audio P9745B / P9740 Car Video...
Que se puede hacer cuando la impresora se cicla al encender y solo marca inicial izando sistema Samsung SCX-6122
tengo el mismo problema amigo, oye cual fue la solucion??? se que la tengo que llevar con un especialista, pero a lo mejor es algo sencillo y pueda repararse y ahorrar unos pesos, me encantaria saber cual fue tu solucion, de ante mano te mando un abrazo, Javier.
Apr 07, 2011 | Samsung SCX-5530FN All-In-One Laser...
Acaban de componer mi camioneta (pontiac montana sv6 1999) porque los buzos hidraulicos estaban pegados y no pasaban aceite (le pusieron nuevos), al siguiente dia de uso empezo a fallar la aguja del...
hola ayuda por favor. tengo una pontiac montana 97 y la falla es que en ocasiones da marcha pero no enciende a la primera. hace como que arranca pero se apaga. pero si acelero un poco al dar marcha si arranca y ya se mantiene normal. que sera. gracias. saludos
Nov 19, 2010 | 1999 Pontiac Montana
Tengo una montero sport 2003 y tiene un problema que no me pueden diagnosticar, humea con mucho olor de ves en cuando es un humo blanco, pero no lo hace toadas las veces solo en algunas ocaciones nada mas,...
tengo una montero 2003 y se le cambio la banda de distibucion y todo bien, solo que fui a una zona alta que esta de subida y a mitad del camino comenzo hacer lijeros tirones, y ahora en pendiente a baja velocidad lo hace
cosa cuirosa, cuando esta fria no lo hace, pero apenas se calienta lo comienza hacer
Oct 25, 2010 | 2003 Mitsubishi Montero Sport
ROS failure
Hola buen dia OKI B6500 la falla que presenta es ERROR DE ROS crei que era el laser scaner pero le puse el de otra impresora en buen estado y nada siguio al poco tiempo igual de hecho el que le quite lo puse en la impresora que esta en buen estado y sigue funcionando, este error OKI B6500 lo hacen muy comunmente este tipo de impresora,En OKIDATA me comentaron que lo provocan varios sensores sobre todo el de tapa superior pero aun que lo corrijas funciona pero al poco tiempo lo vulve hacer que mas puede ser si ya le cambien el sensor de tapa sup.,laser scaner,sensor de deteccion de toner., en OKI no especifican cual es el provoca este error nada mas dicen que son varios sensores.
NOTA: de hecho un colega hizo lo mismo y no le la corrigio lo que hace es la apaga varias veces sacando y poniendo el toner y a veces bingo funciona de hecho tiene una impresora que inicia bien pero al poner el toner se apaga o marca error que hacemos las tiramos tienen menos 80,000 paginas alguien tiene un buen TIP
Aug 19, 2010 | OKI B6500 Led Printer
TENGO UNA COPIADORA XEROX 1012, CUANDO TRATO DE SACAR UNA COPIA TARDA EN CALENTARSE Y NO HACE LA IMPRESION Y ASI UNA SEGUNDA OCACION, HASTA LA TERCERA VEZ QUE TRATO DE SACAR LA COPIA SALE, CUANDO INTENTO...
Esta maquina es viejo, pero si la quiere usar, buenos.
Hay algunos alambres en centro de abajo, limpa los. Tiene cuidado porque los alambres se cebran faci.
Otra cosa es la tinta. La tinta tiene una cosa que media la tinta en el roldono palo. Si esta cabado, no va poner tinta muy bien. Se puede acer copias malas.
Otra cosa tambien es si el papel se tora.
Las jantas pueden ser mal. O otra cosa es si la maquina esta cebrara. Cuando abre la machina, mira adetro donde los dos partes se pegan. Si estran cebranan, el cloche en la atras puede pegra la ariba del metale de ariba de la machina. Usa unas pinsa a planar el metala de el clotche.
Buen suerte! Ojala que entiende esta mensaje.
Aug 12, 2010 | Xerox FaxCentre 1012 Plain Paper Laser
TENGO UN MITSUBISHI DE 95 , LA TRANSMISION 1.8
quizas necesita revisar sensores de transmision,tambien el nivel de aceite,ya por ultimo quizas sea que ya empezo a resbalarse y va a necesitar una transmision nueva o usada.
Sep 19, 2009 | 1995 Mitsubishi Mirage
Problemas de transmision automatica
hola que tal, tengo un saab 9000 1988 y tengo problemas con la transmicion aveses me hace los cambios y abeses no, si abansa para atras y para adelante pero me abienta los cambios cada que quiere,,, alguin tiene idea de que pueda ser?? nesesito ayuda ya estoy desesperado...
Aug 02, 2009 | 2001 Hyundai Accent
Zebra Stripes s400
el codigo de barras sale corrido de su posicion
Oct 29, 2008 | Zebra Stripe S400 Label Printer
Samsung SCX 4521F All-In-One Laser Printer Logo
160 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
