Question about Craftsman 2700 PSI Briggs Stratton Powered Pressure Washer
If i didnt have enough oil when using and broke it, can it be repaired or is it cheaper to get a new pressure washer
    Novelist:
  • 185 Answers
Hi, with lack of oil, I would say that the engine is ruined internally. This of course depends on what is broken internally. One can purchase another engine or what is called a long block. The long block consists of the engine without all the external parts. You would then transfer the parts from your old engine to the new one. I would check at a Briggs dealer near you as to what options they have. Sometimes the long block is a cheaper alternative and you reuse your pressure washer pump with it. Labor is a big factor in this as well. If you are able and can do the work then this is also a consideration. With a new complete unit however, you get a warranty. Another factor is the age of your unit. It might be better to get a newer one as to the usage of your existing pump.
Posted on Dec 29, 2010
What is oil type for my pressure washer pump (K2300G)?
PDF]Service Handbook High-Pressure Washer Pump 3.532-629.0
www.mymowerparts.com/...Pressure-Washer.../Karcher-Pressure-Washer...
Sep 28, 2001 - For Karcher Pressure Washer Parts Call 606-678-9623 or 606-561-4983 .... Oil Bath. The swash plate and pistons are bathed in oil. (oil type ...
Oct 21, 2015 | Garden
Have inherited the above mentioned pressure washer. It does run, but I do not have owner's manual. Need to know about maintenance. How will I change the oil?
Most of the pressure washers IF for professional use are using 1600 rpm motors and 15w40 oil after a first use of 40 working hours there is a speciaal penetrating oil there are possibilities with a plug to fill it and also left on it. after the first 40 hours the oil must left and chanced to 15w40 oil for the lifetime and there is an oil sight glass on it.
But there are also pressure washers in the budget class for home use that will not have this options on it and they are filled for timelife until it have a problem where is leakage, important to know that this kind of oil is a zinc-free hydraulics type of oil that can be sometimes expensive i have used after a repair by leakage a cheap equivalent of turmopol 20hd from Hilti for it what is used in demolition hammers of the brand Hilti thats very good and cheaper than the original oil sometimes Brand names are very different in prices , you should use this kind of oil but first information about the when you have a model that you can place upside down possible on his own motor most of the time induction motors are used. the pump is on the bottom and longlast-filled with special zincfree hydraulic oil like EFCO Nilfisk WAP ALTO and many more
Sep 07, 2015 | Garden
Won't Stay On
If it's brand new, the first thing I'd check is the oil level in the Honda motor. Most pressure washers are tested then the oil is drained out for shipment. Honda motors have an oil sensor in them that will shut the motor off if the oil level is low. When the motor is off, all the oil is in the bottom of the crankcase and the sensor 'thinks' all's OK. When you start it up and the oil is getting splashed around it will get low enough for the sensor to shut the motor down. Also make sure the gas is turned on at the carburator.
Sep 04, 2012 | Homelite Pressure Washer. Honda 2700 psi...
PRESSURE WASHER
Check your ignition, sounds like you are not getting fire. Also check to see if it has an instrument that want let it start if the oil is to low. It could have Malfunctioned. Also double check your oil and make sure there's enough in it.
Apr 01, 2012 | Briggs & Stratton Garden
I have DeWalt3750 psi pressure washer, its been long time since I used it, now that I wanted to use it, I can not start it. I already changed the oil and filled it up with new oil but still can not start,...
Here is the long answer with everything we learned while using a power washer twice a day for years::
This assumes you did not turn power washer over or on its side to drain oil, or dirty oil will flow into carburetor requiring complete carburetor cleaning.
It sounds like could be one of the problems listed below or a combination of those things.
1) The exhaust is partially blocked. Check the screen covering exhaust port for carbon and dirt build-up. High-speed exhaust air must pass freely. We finally broke the exhaust screen out with a screwdriver to get our machine going one day.
2) Gas is not flowing freely to carburetor > under gas tank, find the rubber hose connected to carburetor. Pull off rubber hose and make sure gas flows freely. You can use this hose to drain gas tank of old gas ... and then put in fresh gas.
3) Carburetor is partially gummed up and engine cuts off when gas flow slows down. Buy some gum out, and then don't store power washer with gasoline in the tank. Or put additive in gas when storing machine.
4) The choke is letting in too much gas or not enough gas. Try different adjustments. The choke-lever on our power washer got so bad that we could not set throttle at full open or the machine would die. We still use the machine at 2/3 throttle, and then start it each time using WD-40 as described below.
5) Dirty air filter that won't let engine breath enough air to keep up with combustion. Take off air filter and see if problem persists.
6) The spark coil is going bad?? Change spark plug to see if problem persists. Is spark plug wire pushed all the way onto the spark plug?
Now the nitty gritty: we're gonna start that thing right now
7) Take off air filter. Spray WD-40 directly into carburetor. Yes, we use WD-40 every time to start my power washer, and we use the washer twice a week.
Spray in the WD-40, Pull the engine cord. The engine will fire on WD-40. Guaranteed.
Once it starts, keep spraying WD-40 directly into carburetor to keep engine going.
If engine will not fire and keep going on WD-40, then your spark is suspect.
If your engine fires and runs on WD-40 but dies without it, then your gas supply or carburetor are suspect
8) Carburetor problem >>> try Gum out >>> and then take machine to small engine repair shop
9) Spark ... take out spark plug. Put spark wire back on. Hold spark plug by spark wire. Touch metal threads of spark plug to metal opening where plug came out. Metal to metal. Pull back start cord and look for spark between the metal.
If you have no spark, then spark coil is bad >>> take machine to small engine repair shop
Add a comment if you need more help
Nov 28, 2010 | Dewalt 3800 PSI Pressure Washer
Broke dome bolt at back filled hole with silicone but now leaks between head and dome 351w have to replace dome gaskets?
its probably not tightening down enough,if it broke when taking apart then its probably going to be tough to take the piece out,if it broke putting together,then it should come out fairly easy,drill a small hole in the bolt,and use an easy out and it will turn out.easy outs lock in when you turn it counter clockwise.Heres a tip if you didnt know--when you use old or used bolts,they are usually stretched a little,so the foot lbs should be a little lighter to avoid breaking them off,because they are weaker than new,but,when you put it any bolt new or used torque in to whatever foot lbs recommended but do it DRY,Free from oil or grease,because it causes them to turn easier or more free and they go in farther untill they bottom out and they could break.If you use oily or greasy bolts then lighten up the foot lbs about 5 foot lbs with new bolts and about 7 for used..these are approximately,every different bolt size recommends different torque pressure.So an answer to your question-Yes,replace the intake gaskets to keep coolant from getting into the oil or cylinders,i hope this helps you.
Feb 12, 2010 | 1988 Ford F 250
Oil pressure guage dropping
Sounds like the sensor is failing.Have oil pressure checked with a mechanical gage to confirm. A new sensor or wiring repair is allot cheaper then a new engine!!
Feb 01, 2009 | 2004 Chevrolet TrailBlazer
Low oil pressure
Hi ....... Have a look at your handbook and check the type of oil stipulated and that you have the correct amount & level, maybe another, thinner/cheaper oil has been used and when it's up to operating temp' the viscosity isn't enough to maintain pressure and fully open the pressure switch. If oil level is OK and correct oil filter has been fitted REPLACE the oil pressure switch, they're cheap and easy to do.
Let us know how you get on.
Jan 05, 2009 | 2000 Chevrolet Venture
Craftsman 2700 PSI  Briggs Stratton Powered Pressure Washer Logo
259 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
