Question about Dryers
The dryer no longer heats up and the timer no longer turns the dryer off .. .... the dryer works fine otherwise ... it is a gas dryer.
  • Dryers Master
  • 43,501 Answers
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Jan 03, 2011
I khave a Kenmore gas dryer 110-90 series. It no longer clicks off when the timer is set. Now, there is no heat coming from the dryer. The drum turns with air drying but no heat from any of the cycles.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jul 19, 2011 | Dryers
I have a LGR5636EQ3 Maytag dryer that will not heat up and the timer is not keeping correct time. Dryer will run but longer than preset time and no heat. No click noise when started. I had dryer set at 60...
heatman101
Oct 13, 2010 | Kenmore 73952 Gas Dryer
I cant get any heat and it works otherwise. What would be the problem. Would it be the thermal fuse and where is it located
It could be the heating element, a safety limit, a control problem, or an electrical problem. A heating coil is used to warm the clothes as they get tossed gently inside the drum. A blower mounted on the motor pulls air through the heating element into the drum and out the exhaust. The element gets old and briitle with use and eventually needs replacement. That is what you check first. On gas dryers vibration and age will cause the igniter to crumble and fail. If it turns out the element is fine then one of the safety's might be blown. These safety's are set to a certain temperature
for the dryer to operate safely. The drum temp control for cotton is 160f. A limit on the heater housing is 250f. If it fails another smaller limit is mounted nearby that blows at 300f. If that temp exceeds 350f a duct fuse mounted on the blower housing opens and kills most dryers. On gas dryers the duct fuse will kill the gas assembly but the dryer will still run. If all of those safetys are good the timer could be the problem. The timer has a terminal on it that runs down to the heating element. If you suspect it is bad you can check it with a meter. That leg of the timer should have continuity with other terminals on the timer at different spots on the timer. Turning the timer and checking for continuity will give a clue. If you cannot get continuity with any other terminal on the timer at any position on the dial then you have a burned contact in the timer. If that turns out to be good, you would need to inspect the electrical outlet for proper power to the machine. On American models the motor runs on 120 volts but the heating element must have 240 volts. If you have more questions just post a comment. Good luck on repairing your machine. I have some repair photos: HERE
Aug 05, 2010 | Dryers
No Heat
before working on any appliance-be sure to unplug it to keep from getting shocked & damaging your appliance
problem-runs but will not heat
1.loose wiring-check terminals & wiring
2.defective thermostat
3.defective centrifugal switch in motor(check linkage to motor)
4.defective timer-replace timer
5.open heater element--replace
Jul 27, 2010 | LG DLE3777 Electric Dryer
My roper gas dryer doesn't heat and the timer dial does not advance. I recently cleaned out the interior ductwork, it worked fine for a week, and then it seemed like the timer started becoming less and ...
heatman101
May 28, 2010 | Roper REX4634KQ Electric Dryer
The dryer runs but does not heat up
Depending on your heat source (gas or electric), your problem could be one of the following:
* if electric: heat element, thermostat or timer
* if gas: gas coils, radiant sensor, thermostat or timer
Note: In either case, check to ensure that the dryer is receiving the proper amount of electricity (110 volts for gas & 208-220 volts for electricity).
Feb 19, 2010 | Bosch Axxis WTA 3510 Electric Dryer
Dryer no longer heats up
Jan 18, 2010 | Whirlpool LER5636P Electric Dryer
Dryer doesn't get hot or turn off.
yes very possible timer but my guess on the times i seen the problem would be the heating element are the thermo fuse on the elemnt canister when the heater does not come on the timer will not move ck the heater and the fuses on the heater canister it will fix your problem
Feb 28, 2008 | Whirlpool LER4600 Electric Dryer
No Heat on Whirlpool Gas Dryer
The timer should advance in the time dry cycles if it does, it is fine Its common for them to not in automatic cycles when there is no heat I would call for service unless you have basic gas appliance knowledge , as it is dangerous If you decide attempt i can tell you what to look for Please rate my help .....Thanks
Oct 02, 2007 | Dryers
Dryers Logo
Top Dryers Experts
