Question about Maytag MDG9606 Dryer
The dryer squeals on start up and quiets after 40 seconds or so. I took it apart and the belt and pulley seem ok. How do I know if they are worn? I thought it was a problem with the felt liner at either end of the barrel. Is the belt relatively easy to replace? Thanks for your help.
  • 1,772 Answers
Sorry to read about your problem, I hope this helps you out.
you have a drum bearing, going bad, or your belt tension pully. it stops squealing because the unit heats up and the metal expands. you can also try spraying (WD40) the belt tension pulley..
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
Posted on Dec 29, 2010
Why does my Estate dryer sqeek or squeal so loud
I just had a similar problem with my Whirlpool dryer. It would squeek very loudly and then chirp a bit and then go quiet.
Took the back off and found that the belt tensioner arm pulley that drives the drum turning had stopped spinning. Sprayed some silicone on the hub a couple of times and it freed up and is working again. Everything is fine for now. I'm going to order a new part 'cause I know it will just happen again when the silicone wears out.
Apr 06, 2016 | Estate Dryers
My car makes a loud squealing sound when i start it
Mary,
This type of problem is best checked by a trusted mechanic. I doubt you'd hear squealing noises from the crankshaft or harmonic balancer; but it is likely to be heard from a belt tensioner pulley, water pump (or other belt-driven devices under the hood - such as the alternator, power steering pump, etc.). A loose or slipping belt can also cause this noise.
Spraying WD-40 on the source of the squeal may quiet the sound - but not solve the problem that is causing it. By simply masking the problem with WD-40 instead of fixing it - you run the risk of the squealing part failing catastrophically - probably at the least desirable place and time.
For your own safety and convenience, have this problem checked and repaired properly.
Feb 02, 2016 | Cars & Trucks
Dryer has very load high squeal at start, lasting few minutes, then high quieter sqeak rest of load. Spins and heats ok
Belt is stretched out and slipping on drum, pulley or both. Time to replace it.
Replacement Belt Part #33002535
http://www.repairclinic.com/PartDetail/Drive-Belt/33002535/791135?ss=c7-x6d646534303030&mr=1
RDU Appliance Repair Washing Machine and Dryer Repair
Jan 02, 2015 | Maytag Neptune MDE4000 Electric Dryer
How do I fix a squeaky belt on a minivan?
Post question is automotive section?
Is belt squealing? or is there a squeaky noise?
Squealing would denote belt slippage... belt might be loose, apply more belt tension at idler pulley (if possible). Consider trying a spray-on 'anti-slip" compound.
Squeaky noise could mean a bad pulley bearing.
Oct 13, 2014 | Dryers
Engine squeal when starting
Hi JoAnne,sounds like your belt is squilling,here's a link to the belt adjustment or removal.
Dec 22, 2012 | 2005 Kia Sportage
2002 Ford Mustang pulley squealing
Replace the crank pulley before it costs you an arm and a leg. It has caused this problem. don-ohio
Mar 26, 2017 | Ford Cars & Trucks
Squealing noise on start up drying still works
This dryer needs to be taken apart to lubricate any and all moving parts. Idler pulley and rollers, if they are worn out in any way, replace them.
Also, consider a new belt.
Nov 16, 2009 | AEG T58840 Dryer Electric
Loud squealing from power steering pump - do I need new PS pump?
Hi! The pulley could be worn or the belt is not properly adjusted.Causing the belt not to grip the pulley but slide on it,creating a friction.
Jan 15, 2009 | 1992 Toyota Celica
Dryers Logo
88 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
