Question about IBM Wheelwriter 30 Typewriter
New ribbon but print is not dark. Also should I put in a new Printwheel II cartridge and if so how???
  • IBM Master
  • 3,594 Answers
First put in a miltipart form, if the carbons are good it is a ribbon problem if not then the print solenoid cap is probably broken. We sell them with shipping and instructions for 20.00.
DickyO
Cleveland business Machines
216-241-0027
Posted on Dec 29, 2010
Need help with wheelwriter 3 which is not printing. Works but nothing on paper
See page 3-5 @
http://www.national-elec.com/IBM%20&%20Lexmark%20Typewriter%20operating%20instructions/Wheelwriter-3sII.pdf
Sep 06, 2014 | IBM Wheelwriter 3 Series Ii Typewriter...
Canon ap350 typewriter
I believe there is a lever (maybe green on the lower part of the print head for copy adj.
DickyO
Jan 28, 2014 | Office Equipment & Supplies
Changed the typewriter ribbon because it snapped in two. At first the typewriter would not do anything and was beeping and the "store", 1 1/2 and 3 lights were on. I oiled the carriage as...
do you have a printwheel in this machine (round grey disk with "fingers" evenly spaced around it with the charachters on it)? If not - there's your problem. you can repair the ribbon with a small piece of tape (no wider than the ribbon. stuck to the backside (shiny) of the ribbon then turn the ribbon until the taped part goes into the cartridge a ways. if the ribbon is moving ok and you still have a printwheel installed, make sure the ribbon is not getting caught in the printwheel.
Dec 20, 2010 | Nakajima AX-150 Typewriter
Datacard sp55 printer won't recognize ribbon
PR-01726 Ribbon Out
Out of print ribbon.
Possible Cause 1 : The print ribbon Cartridge is empty.
Solution 1 : Reload the print cartridge. Change the cleaning sleeve and replace the cartridge in the printer. Run a cleaning card as soon as printing is completed.
Possible Cause 2 : The printer ribbon is not loaded correctly.
Soultion 2 :Load the printer ribbon correctly and then close the cover.
Possible Cause 3 : This ribbon has been completely used.
Solution 3 : Use a new roll of ribbon.
Tips for Success
* When this message appears, replace the old ribbon with the new ribbon of the same type. The printer has already prepared the card data for this ribbon type. You can change the colors of monochrome ribbon (such as from dark blue to gold).
* If you must change the type of ribbon (such as (YMCKT to KT) when this message appears, install the new ribbon, cancel any cards waiting to print, and change the ribbon type settings. Finally, return to the card creation program to send the card data to print.
* If the ribbon was repaired, the wrong take-up spool was used. Repair the ribbon again, using the correct take-up spool.
If you cannot fix the problem contact your service provider for assistance.
FTB
Nov 23, 2009 | Datacard Group SP55 Card Printer
Wheelwriter 6 - Was typing and it just stopped printing. The keys repsond, the printwheel responds but doesn't move forward to make contact with the paper. The ribbons advances, the correction ribbon...
Solenoid pad is worn out. Look below left of the printwheel down inside the carriage and you should see a little white or opaque rubber pad. It needs to be replaced. You have to take it to a shop for proper repair. I have in the past, replaced it by digging the old one out with tweezers and hook. Then fish the new one in there.
Sep 07, 2009 | IBM Wheelwriter 30 Typewriter
IBM Wheelwriter 10 Series II 6 Beeps 1,2,3 Blinking
Check in the area where the printwheel is installed for paper or other debris. If it does the same thing with the printwheel out then it is probably a printwheel sensor.
DickyO
Jul 14, 2009 | Lexmark Wheelwriter 10 Series II...
Typewriter is working fine but won't type anything on the paper - new ribbon / new printwheel - no impression. Appears to be stuck on a "stencil" setting.
Put in a mulit part form, if it prints on the copies the ribbon isn't lifting, if it dosen't the plastic cap on the print solenoid needs replaced.
DickyO
Apr 23, 2009 | IBM Wheelwriter 30 Typewriter
Wheelwriter 15 series II
The ribbon drive motor might be n/g. I think 6 beeps is the ribbon motor located under the gear on the ribbon cartridge.
Feb 08, 2008 | Lexmark Wheelwriter 1500 Typewriter
Light typing
What make and model typewriter do you have?
Jan 07, 2008 | Lexmark Wheelwriter 30 Series II...
IBM Wheelwriter 30 Typewriter Logo
47 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
CheckitRight
CheckitRight
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
